Accelerometer causes Duet 2 Wifi to crash?
Hi there- I have a strange error:
I connected an Accelerometer.
As soon as I post a M956 command the Board "crashes" (nothing happens and after a few seconds the board reboots). I can also find the file created in the accelerometer folder but it is empty...?
Any suggestions what I am doing wrong?greetings kuhni
Just tried the other duet board I own (a cartesian printer) - there a file is created with the message
Sample,X,Y,Z
Failed to collect data from accelerometervery strange...?
another strange behavior:
I can adress the Accelerometer with the command:M955 P0 I46 C"spi.cs4+spi.cs3"
but if I then want to change something and post the code again (e.g. to change the Frequency)
M955 P0 I46 C"spi.cs4+spi.cs3" Q500000
I get the error
M955: Accelerometer not found on specified port
is this normal? Do you have to reset the Board to "re-activate" the possibility to declare an M955 command?
@kuhnikuehnast I'm not sure why that is happening, however you don't need to repeat the M955 C parameter or I parameter when you just want to change the data collection parameters.
If the board reboots unexpectedly, please run M122 as soon as DWC has reconnected, and post the output here.
tried it:
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SN-6J9F2-3S46K-1UYRD Used output buffers: 1 of 26 (15 max) === RTOS === Static ram: 23860 Dynamic ram: 76056 of which 168 recycled Never used RAM 9140, free system stack 186 words Tasks: NETWORK(notifyWait,9.1%,242) HEAT(notifyWait,0.0%,339) Move(notifyWait,0.0%,363) MAIN(running,81.8%,320) IDLE(ready,9.0%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:10 ago, cause: software Last software reset at 2023-02-16 18:00, reason: HeatTaskStuck, GCodes spinning, available RAM 7200, slot 1 Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20018d84 Task ACCE Freestk 336 ok Stack: 0045d69d 0045d0f6 6100f000 00000000 0045d69d 2001871b 00000000 00000000 2001871b 2001871b 2000d334 200187e8 00000006 00000028 a5a5a5a5 00000001 0045d797 400a0000 00000001 200186f8 0045b02b 400a0000 00456cb3 0c000000 200186f8 00000007 00000007 Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 32.7, current 33.3, max 33.5 Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/24/24, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-02-16 18:00:29 Cache data hit count 386562846 Slowest loop: 11.66ms; fastest: 0.19ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 0.9ms, write time 5.7ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 37.22ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address 84:f3:eb:42:7a:a5 WiFi Vcc 3.40, reset reason Power up WiFi flash size 4194304, free heap 25784 WiFi IP address 192.168.178.80 WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0 -
@kuhnikuehnast I suspect that there may be a problem with the INT connection from the accelerometer to the Duet spi.cs3 pin.
@dc42 so what should I do? When i connect the same board (and cable) to the other board it "works" - as mentioned above... "failed to collect data"
I now tried something else:- I switched the CS and INT1- Pin (so I declared the M955 to:
M955 P0 I46 C"spi.cs3+spi.cs4"
instead of
but as soon as I ran the code:
M956 P0 S1000 A0
I got another crash. In this time this was the M122:
=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SN-6J9F2-3S46K-1UYRD Used output buffers: 1 of 26 (18 max) === RTOS === Static ram: 23860 Dynamic ram: 76056 of which 168 recycled Never used RAM 9140, free system stack 184 words Tasks: NETWORK(notifyWait,9.4%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,82.0%,320) IDLE(ready,8.6%,30), total 100.0% Owned mutexes: === Platform === Last reset 00:00:10 ago, cause: software Last software reset at 2023-02-17 08:38, reason: HeatTaskStuck, GCodes spinning, available RAM 7200, slot 0 Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20018da4 Task ACCE Freestk 344 ok Stack: 00435245 00435248 61000000 00000001 200186f8 00000001 0000002f a5a5a5a5 00000001 20004c60 00456cab 0c000000 20018dff 200186f8 00000007 00000010 00456cd5 0c000000 200186f8 00000007 00456f17 200186f8 c3000007 00000007 000003e8 2000119c 00456723 Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 23.5, current 24.2, max 24.5 Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/24/24, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-02-17 08:38:07 Cache data hit count 405364224 Slowest loop: 10.11ms; fastest: 0.19ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 0.9ms, write time 5.9ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 37.57ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address 84:f3:eb:42:7a:a5 WiFi Vcc 3.40, reset reason Power up WiFi flash size 4194304, free heap 22360 WiFi IP address 192.168.178.80 WiFi signal strength -54dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
Do you see something different? So is my Duet broken? Or how could I solve this problem?
Hope you can help me!
greetings kuhni
@kuhnikuehnast it could be that writing to the SD card is taking too long. You could try a new SD card. Alternatively, reduce the number of samples you are collecting, for example to 500.
@dc42 tried now only 10 samples by
M956 P0 S1000 A0
same crash...=== Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.4 (2022-10-20 16:17:41) running on Duet WiFi 1.02 or later Board ID: 08DGM-9T6BU-FG3SN-6J9F2-3S46K-1UYRD Used output buffers: 1 of 26 (16 max) === RTOS === Static ram: 23860 Dynamic ram: 76056 of which 168 recycled Never used RAM 9140, free system stack 188 words Tasks: NETWORK(ready,9.6%,242) HEAT(notifyWait,0.0%,329) Move(notifyWait,0.0%,363) MAIN(running,81.5%,320) IDLE(ready,8.8%,30), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:00:10 ago, cause: software Last software reset at 2023-02-17 17:11, reason: HeatTaskStuck, GCodes spinning, available RAM 7200, slot 2 Software reset code 0x4143 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f80f BFAR 0xe000ed38 SP 0x20018d84 Task ACCE Freestk 336 ok Stack: 0045d69d 0045d0f6 6100f000 00000000 0045d69d 2001871b 00000000 400a0000 2001871b 2001871b 2000d334 200187e8 00000006 00000028 a5a5a5a5 00000001 0045d797 400a0000 00000001 200186f8 0045b02b 400a0000 00456cb3 0c000000 200186f8 00000007 00000007 Error status: 0x00 Aux0 errors 0,0,0 Step timer max interval 0 MCU temperature: min 33.3, current 33.9, max 34.1 Supply voltage: min 23.8, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/24/24, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min n/a Driver 1: standstill, SG min n/a Driver 2: standstill, SG min n/a Driver 3: standstill, SG min n/a Driver 4: standstill, SG min n/a Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2023-02-17 17:12:23 Cache data hit count 396566500 Slowest loop: 12.22ms; fastest: 0.19ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 0.9ms, write time 3.9ms, max retries 0 === Move === DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty === Network === Slowest loop: 32.53ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 = WiFi = Network state is active WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.27 WiFi MAC address 84:f3:eb:42:7a:a5 WiFi Vcc 3.40, reset reason Power up WiFi flash size 4194304, free heap 25384 WiFi IP address 192.168.178.80 WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem Clock register 00002002 Socket states: 0 0 0 0 0 0 0 0
@dc42 btw what is the biggest size possible for the SD-Card? So I'll get to grab a new one...
sorry, got it already- so I'm out now heading to a store to get a SanDisk Extreme Pro 32 GB mircoSD
cross fingers for me that this will solve the problem!
I think I solved the problem:
- it wasn't the SD-card- but as I changed the cable and re-crimped an USB-3-cable everything now seems to work!
yihaaa
