    InputShaping UI accelerometer picker broken
    Plugins for DWC and DSF
    481
    • gnydickundefined
      gnydick
      When I'm trying to record a motion profile, it won't let me select any accelerometer other than the first one.
      You can see the dropdown here, but when I click 123.0, the value never changes and it is still 121.0.
      • achrnundefined
        achrn
        I get that sometimes, except for me it's more normally won't let me pick the first one (I have two - one directly connected to the mainboard so just '0' in the picker, one 121.0, and it insists on 121.0). When it gets stuck the only way I've found to unstick it is to disable the plugin and then re-enable it and start again.
        Mine is Board: Duet 3 Mini 5+ (Mini5plus)
        Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.4.5 (2022-11-30)
        Duet WiFi Server Version: 1.27
        Toolboard is Duet TOOL1LC rev 1.1 or later firmware version 3.4.4 (2022-10-14 11:46:33)
        Accelerometer is a dodgy Chinese LIS3DH on a board that claims it's a LIS3DSH but isn't.
        gnydickundefined 2 Replies Last reply Reply Quote 0
        • gnydickundefined
          gnydick @achrn
          @achrn, thanks, I'll try that.
          • gnydickundefined
            gnydick @achrn
            @achrn I've tried it, still doesn't work.
              We're looking to reproduce this, but not everyone has multiple accelerometers at the ready at the moment. But it is on the list.
              gnydickundefined 1 Reply Last reply Reply Quote 0
              • gnydickundefined
                gnydick @Phaedrux
                @Phaedrux I imagine someone has 2 toolboards somewhere at Duet. This can't possibly be a reasonable "stable" release. It's starting to go beyond the pale with how basic the bugs are getting.
                T3P3Tonyundefined 1 Reply Last reply Reply Quote -2
                • T3P3Tonyundefined
                  T3P3Tony administrators @gnydick
                  @gnydick yes I can confirm this is an issue, thanks for reporting it.
                  www.duet3d.com
                  • chrishammundefined
                    chrishamm administrators
                    It's fixed in the 3.5 code base.
                    Duet software engineer
                    gnydickundefined 1 Reply Last reply Reply Quote 1
                    • gnydickundefined
                      gnydick @chrishamm
                      @chrishamm I'm guessing I can't install it until 3.5 is available for the whole system?
