    DWC 3.5b2 - Autofill changing typed values
    Beta Firmware
    259
      jay_s_uk
      When editing or creating a macro etc and you press enter to move to the next line, if you aren't careful, the last value you've typed will be changed.
      E.g. If you type the following line
      G1 X100 F1000
      and then the next line you type
      G1 X1
      If you press enter at the end of the line, autofill will change the value to X100 as its appeared before in the file.
      This could result in incorrect file contents being created
      jay_s_ukundefined chrishammundefined 2 Replies Last reply Reply Quote 1
        jay_s_uk @jay_s_uk
        this is also affected by using Tab at the end of a line too
        MintyTreborundefined 1 Reply Last reply Reply Quote 0
        • MintyTreborundefined
          MintyTrebor @jay_s_uk
          @jay_s_uk It may be better to change the auto-complete to TAB only and not TAB or Enter?
          NodeDSF - Native Node-Red integration with Duet boards.
          BtnCmd - Customise DWC with user defined buttons/layouts/panels (DWC Plugin)
          ReleaseMgr - Duet update info inside DWC.
          Repo
            jay_s_uk @MintyTrebor
            @MintyTrebor i would agree that makes sense
            @chrishamm this is still an issue with 3.5b3
            • oliofundefined
              oliof @jay_s_uk
              @jay_s_uk can I disable autofill completely?
                jay_s_uk @oliof
                @oliof unfortunately not. not at the moment anyway
                • oliofundefined
                  oliof @jay_s_uk
                  @chrishamm then I am kindly requesting an option to disable autofill. It's difficult enough to figure out my own darn mistakes, I don't need machine-generated ones on top.
                  deckingmanundefined 1 Reply Last reply Reply Quote 3
                  • deckingmanundefined
                    deckingman @oliof
                    @oliof said in DWC 3.5b2 - Autofill changing typed values:
                    ...............It's difficult enough to figure out my own darn mistakes, I don't need machine-generated ones on top.
                    That made me smile - so true.
                    • chrishammundefined
                      chrishamm administrators @jay_s_uk
                      @jay_s_uk Word-based suggestions (autocomplete) will be disabled in the next version. I may add real G/M-code auto-completion to v3.6, but if I do, I'll probably add a new setting to disable it as well.
                      Duet software engineer
