MKS thr32/thr42 usb toolboards and duet2 wifi
Are the mks thr32/thr42 usb toolboards in amy way compatible with a duet2 wifi running Klipper FW?
@manne_sahne connect them to klipper via a UTOC or similar
On the github they write:
USB communication Keep the usb connection is ok between the MKS THR36/42 and your Klipper host board, and power on. SSH login to your Klipper console and run ls /dev/serial/by-id/*
If this should work, is it possible to use a USB Hub to connect the toolboard and the Raspberry Pi to the duet?
