    How to set and use variables
    Gcode meta commands
    • Rodrigue Richallandundefined
      Rodrigue Richalland
      For a multiples sub-assembly of my DIY printer, i need to create custom fonctionality using macros.
      But i dont really understood how to use variables whith in duet3D environement.
      in this exemple below, i want to create flash light macro. After many try, the syntaxe look's good, but the macro never stop.
      var nbr_de_cycles=50
      var i = 0
      while var.i < var.nbr_de_cycles
      M106 P4 S255 ; Allumer la sortie ventilateur à 100%
      G4 P100 ; Attendre 50 millisecondes
      M106 P4 S0 ; Éteindre la sortie ventilateur
      set var.i = [var.i + 1]
      endwhile
      In general, i want to know :
      -How to create a variable ?
      -How to use a variable value in a calcul ?
      -How to make a counter ?
      Thanks for your help,
      Rodrigue
        Have you seen this? https://docs.duet3d.com/en/User_manual/Reference/Gcode_meta_commands
        Rodrigue Richallandundefined 1 Reply Last reply Reply Quote 0
          Rodrigue Richalland @Phaedrux
          @Phaedrux
          Of course. After others try today, i think the macro calculation is much slower when the mainbord printing.
          Is it possible that the processor is saturating?
          infiniteloopundefined 1 Reply Last reply Reply Quote 0
          • infiniteloopundefined
            infiniteloop @Rodrigue Richalland
            @Rodrigue-Richalland said in How to set and use variables:
            Sure! The limited resources of a micro-controller are first and foremost allocated to the job it has to perform, not to a light show to illuminate the job in iterations of some (50) milliseconds. Also, please take into account the nature of scripts: they are interpreted, which imposes additional load on the MCU just to "understand" the meaning of the code.
            To generate really fast visual effects, you should use a dedicated controller like an Arduino or ESP. This one might then be triggered by (or synchronised with) certain events on the Duet.
            Rodrigue Richallandundefined 1 Reply Last reply Reply Quote 1
              dc42 administrators @Rodrigue Richalland
              var i = 0
              endwhile
              Here is what I believe to be a corrected version (not tested) - note that the indentation is important because it defines the scope of the while-command
              var i = 0
                G4 P50       ; Attendre 50 millisecondes
                set var.i = var.i + 1
              Here is a simpler version that makes use of the built-in variable 'iterations':
              while iterations < var.nbr_de_cycles
                Rodrigue Richalland @infiniteloop
                @infiniteloop said in How to set and use variables:
                Thanks for your reply. I understand the issue. I will work on new way with arduino and GPIO port of duet.
                  Rodrigue Richalland @dc42
                  Thanks you so much for your help and your so detail reply. It's work's. I can use variable now 😊
