Solved 3.4.5 wifi password bug - lower case only ?
I have duetwifi 2 and it is not possible to use lower case letters in wifi password.
on the router i have added configuration:
SSID: D3D
password d3dd3dd3dnext is M587 S"D3D" P"d3dd3dd3d"
this leads to
Error: WiFi module reported: Timed out while trying to connect to D3D<LF> M587<LF> Remembered networks:<LF> D3D IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF>
however, if i change wifi password on the router to "D3DD3DD3D" and issue
M587 S"D3D" P"D3DD3DD3D"
i immediately get connected.M587<LF> Remembered networks:<LF> D3D IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0<LF> ok<LF> WiFi module is connected to access point D3D, IP address 192.168.11.233<LF> M115 FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.4.5 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2022-11-30 19:36:12<LF>
I thought that is could be misconfigured terminal (pronterface), installed YAT with default settings and got same results.
Is it a real bug, or there something wrong with my configuration?
Please read the notes on case sensitivity.
@Phaedrux thank you! resolved
