    Trigger not executed
    Gcode meta commands
    • Rodrigue Richallandundefined
      Rodrigue Richalland
      I want to execute "trigger2.g" when e2stop rising.
      Config.g
      M591 D2 P1 C"duex.e2stop" S0
      M950 J2 C"duex.e2stop" ; Configurer la broche GPIO pour le capteur
      M581 T2 P2 S1 R0 ; Surveiller la broche GPIO J2, déclencher la macro 2.g lorsqu'elle passe à l'état haut
      0:/sys/trigger2.g
      M106 P1 S1
      The trigger work when i send M98"0:/sys/trigger2.g" but not with E2stop value
      Thanks
        Can you confirm what firmware version you are running? Send M115 in the gcode console.
        What exactly are you trying to accomplish?
        You have a filament sensor defined to a pin, and then are trying to use the same pin for a trigger?
        You can find information about using triggers here:
        https://docs.duet3d.com/en/User_manual/Tuning/Triggers
        And filament sensors here:
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_filament
        Rodrigue Richallandundefined 1 Reply Last reply Reply Quote 0
          Rodrigue Richalland @Phaedrux
          @Phaedrux
          I'm running 3.4.4 firmware version.
          I want to use the filament sensor as input for close the enclosure door.
          I've no filament sensor on pin e2stop, there is my door sensor.
          M106 P1 S1 run a pwm fan to 100% for powered an electric magnet
          through a DC static relay .
          OwenDundefined 1 Reply Last reply Reply Quote 0
          • OwenDundefined
            OwenD @Rodrigue Richalland
            @Rodrigue-Richalland
            You don't need to define a filament sensor
            Just use the pin and define a trigger
            See here
            https://docs.duet3d.com/User_manual/Tuning/Triggers
