    Z probe setup for CNC
    CNC
    • djthuma
      djthuma last edited by
      Trying to setup a stationary Z probe, using a LED switch endstop, like I have on the other axes.
      I have been using
      https://forum.duet3d.com/topic/29771/fusion-360-cnc-and-laser-post-processors-with-tool-workflow?_=1678326759314
      as a reference and trying to recreate the macros for my machine.
      (I havent modified the comments yet)
      How can I setup an endswitch as a tool set probe?
      Thank you
      • djthuma
        This is on a Duet 3 6XD.
        • Referenced by  djthuma djthuma
        • T3P3Tony
          T3P3Tony administrators @djthuma last edited by
          @djthuma you are trying to us a switch as the Z endstop, or to set tool lengths?
          you can't have a single IO as both an endstop and as a zprobe which you have in the config above :
          M950 P2 C"io5.in"							; Allocate GPOP Port 1 to Z Probe in
          M558 P5 C"io5.in" H180 F700 T1000	        ; Set to Z probe type 5 and to switch and dive height + speeds
          This is wrong. If you look at the example you reference:
          https://forum.duet3d.com/topic/29771/fusion-360-cnc-and-laser-post-processors-with-tool-workflow/4?_=1679327030257
          You will see that the M950 command is commented out:
          ;M950 P2 C"io5.in"							; Allocate GPOP Port 1 to Z Probe in
          www.duet3d.com
          djthuma 1 Reply Last reply Reply Quote 0
          • djthuma
            djthuma @T3P3Tony last edited by
            @T3P3Tony
            I have a Z endstop at the top of my gantry head and a stationary endstop on the spoilboard 20+mm higher. I want the tool to touch that endstop and set the new Z height. Based on whatever tool I have setup.
            Even with the M558 P5 C"io5.in" H180 F700 T1000 only, I am not getting any response from the endstop to trigger the Z movement to stop.
            • T3P3Tony
              @djthuma are you using the same macros as in the referenced thread?
              www.duet3d.com
              • djthuma
                @T3P3Tony I have them uploaded. But I know they are not functioning properly for the endstop I want to use.
                How would you write a probe macro for this situation?
                Sorry, I don't have that much experience working with the reprap language for duet.
