Solved Strange behaviour XY moves
Strange behaviour
Hello , I'm fitting a duo 2 wifi board to my JGaurora a5 printer and after commissioning there is a strange behaviour no matter if I move the X or Y axis the other axis also starts to move . The same with Home all axes, is there anyone who knows where the problem lies?
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.3 on Mon Oct 04 2021 22:39:47 GMT+0200 (czas środkowoeuropejski letni); General preferences
M550 P"My Printer" ; set printer name
M669 K1 ; select CoreXY mode
M501; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 S0 ; physical drive 1 goes backforwards
M350 Z16 E16 I0 ; configure microstepping without interpolation
M350 X16 Y16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z400.00 E800 ; set steps per mm
M566 X700.00 Y700.00 Z30.00 E600.00 ; set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z200.00 E10000.00 ; set maximum speeds (mm/min)
M201 X5000.00 Y5000.00 Z30.00 E200.00 ; set accelerations (mm/s^2)
M906 X1500 Y1500 Z1500 E1700 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X300 Y300 Z200 S0 ; set axis maxima; Endstops
M574 X2 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin zstop; Z-Probe
M950 S0 C"exp.heater3"
M558 P9 C"^zprobe.in" H5 F100 T2000
G31 P500 X30 Y60 Z8 ; set Z probe trigger value, offset and trigger height
M557 X15:315 Y15:315 S20 ; define mesh grid; Heaters
M307 H0 R0.148 K0.195:0.000 D4.38 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 R4700 P"e0temp" Y"thermistor" T100000 B3950 C0 ; define E0 temperature sensor
M307 H1 R1.403 K0.258:0.000 D9.56 E1.35 S1.00 B0 V24.2 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S280 ; set temperature limit for heater 1 to 280C; Fans
M106 P2 S1 H1 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
T0 ; select first tool -
… strange behaviour no matter if I move the X or Y axis the other axis also starts to move . The same with Home all axes, is there anyone who knows where the problem lies?
Yes, in this line of your config.g:
Don't know your printer, but it can't be a coreXY. Try
M669 K0 ; select Cartesian mode
instead.
@bartekp said in Strange behaviour XY moves:
M501
Also this needs to go at the end of your config.g otherwise it will just get overridden by the commands in config.g.
ok Thanks for help topic closed
