Duet 3HC SCH file compatibility
Hey Everyone,
I am trying to import the schematic files into fusion 360 so that it can linked to our current wiring diagrams.
Because the Schematic files are saved as a .pdf I am struggling to get them to load in. Is there any possibility that the files could be shared in a pure .sch format?
Any help or links would be amazing
@JimmyEvo3D they are shared as .sch, just Kicad.sch
https://github.com/Duet3D/Duet3-Expansion-3HC/tree/master/Expansion_3HC_v1.0/CAD
Maybe autodesk expects a different format with the same extension?
Sorry I should of specified that its the 6HC Mainboard and 3HC expansion that I was struggling with. I will try the 3HC one again as I hadn't seen that file on it's own, just the PDF variants.
The 6HC only has a PDF format saved in its v1.02 folder unlike the 3HC.
Thanks for replying so quickly Tony!
Just tried the 3HC board sch file and I believe you are correct that it wants a different format as got the same error as before.
I will try a different approach, thanks for the help.
