    Tool and probe offset to variabne
    Gcode meta commands
    macro variable
    • Shokiundefined
      Shoki
      Is there a way to get the result of a gcode command inside a variable.
      I'm writing a few macros and I would need to store the offsets of different tools to a variable. These are the results from G10 P0, G10 P1 and G31 that appear in the console.
      I tried to find them in the object model description, but without success.
      https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation
      Thanks in advance for pointing me in the right direction.
      • T3P3Tonyundefined
        T3P3Tony administrators @Shoki
        @Shoki there is currently not a way to get replies from gcode commands into variables. That said the tool offsets are in the object model:
        tools[n].offsets[m]
        when "n" is the tool number and "m" is the axis index.
        www.duet3d.com
        Shokiundefined 1 Reply Last reply Reply Quote 1
        • Shokiundefined
          Shoki @T3P3Tony
          @T3P3Tony Thanks a lot ! I missed them when I read through the object model I don't know why.
          • T3P3Tonyundefined T3P3Tony marked this topic as a question
          • T3P3Tonyundefined T3P3Tony has marked this topic as solved
