COM port won't show up with SD card inserted
When I start my board with my SD card inserted, the com port won't show up. It doesn't connect to wifi either. I reinstalled the firmware (double click reset and upload) and I also flashed the SD card and put a backup of the old files back into it. I'm not sure what I changed or what happened but it was really random. I am using the DUET3d 5+ mini board.
Some debugging: As soon as I take the SD card out even if it is already on, I see the COM port and can send serial commands.
@osli try a different SD card please. also please post a clear high res picture of the SC card socket on the mini 5+.
@T3P3Tony I tried a different SD card. I also booted it without the SD card first then sent M21 to force mount it via serial and that mounted it. However when running M20, no files are detected and when running M39 I get this:
SD card in slot 0: capacity 7.95GB, partition size 7.94GB, free space 7.92GB, speed 22.50MBytes/sec, cluster size 32kB
I will attach an image of the SD card slot soon when I get home but no visible damage or solder faults.
When and where did you purchase?
Can you send M122 before and after mounting with M21 and copy paste the results here?
