    6 Axis linear Delta
    Firmware installation
    • tklnundefined
      tkln
      Hello community,
      I am in the process of building a 6 axis delta. Construction and material sourcing is complete. Now comes the fun part, the programming.
      I want to test the delta first and use it as a normal linear delta (3 axis).
      First I would switch the motors together using the command:
      M584 X0:4 Y1:5 Z2:6 E3; two motors for x, y, z connected to driver outputs
      As described in the "Bed leveling using multiple independent Z motors" section. Can I adopt the same procedure for x/y/z (Delta: Tower 1/2/3)?
      As a next step, if the delta is running well, I would separate the 6 motors and run them individually. Does anyone have any advice?
      Best Regards
      Tim
      T3P3Tonyundefined breedundefined 2 Replies Last reply Reply Quote 0
      • T3P3Tonyundefined
        T3P3Tony administrators @tkln
        @tkln AFAIK that approach should work for the axis - one way to find out - give it a go without the effector attached and see if the motor move as expected!
        You will need a new version of the delta kinematics class for 6 axis.
        www.duet3d.com
        • breedundefined
          breed @tkln
          @tkln nonlinear printing?
          tklnundefined 1 Reply Last reply Reply Quote 1
          • tklnundefined
            tkln @breed
            @breed
            Yes 😍
            breedundefined 1 Reply Last reply Reply Quote 0
            • breedundefined
              breed @tkln
              @tkln very interesting. Think this could be the future if they ever get a good slicer.
              • tklnundefined
                tkln
                Hey,
                here are some updates from the project "6 Axis linear Delta".
                The connected motors works well.
                @tkln said in 6 Axis linear Delta:
                So the first test was successful and the 6 axis linear delta does exactly what a 3 axis linear delta should do.
                My plan is that the Effector can tild 45° over a 300 mm Printbed.
                Fun fact the diagonal Rod length is much much longer compared to a 3 axis linear delta to achieve the 45° tilt. 😄
                Now I have to separate the 6 motors.
                -> My next step is to modify the kinematics for 6 Axis.
                Does anyone here have any information and/or ideas?
                Is it possible to modify the files (LinearDeltaKinematics.cpp, LinearDeltaKinematics.h) and add 3 axes or is it better to create a completely new kinematic?
                • LinearDeltaKinematics.cpp GithubDuet3d
                • LinearDeltaKinematics.h GithubDuet3d
                Can I use the Denavit-Hartenberg transformation (DH Transformation) to build the Inverse Kinematic or doesn't the RepRapFirmware support it?
                I'm happy about every idea and support ❤
