    Voron 2.4 with 6HC & 3HC
    716
    • wbrokow1undefined
      wbrokow1 @Phaedrux
      @Phaedrux OK , I see it thanks. Same error, It was fixed though. Thanks
        Can you send M122 and M122 B1 in the console and then copy and paste the results here please?
        wbrokow1undefined 1 Reply Last reply Reply Quote 0
        • wbrokow1undefined
          wbrokow1 @Phaedrux
          @Phaedrux 3/24/2023, 3:09:16 PM m122
          RepRapFirmware for Duet 3 MB6HC version 3.4.5 (2022-11-30 19:35:23) running on Duet 3 MB6HC v1.01 (standalone mode)
          Board ID: 08DJM-9P63L-DJ3T8-6JKDL-3SN6Q-KS7BA
          Used output buffers: 3 of 40 (14 max)
          Static ram: 152760
          Dynamic ram: 97332 of which 184 recycled
          Never used RAM 100324, free system stack 138 words
          Tasks: NETWORK(ready,30.0%,210) ETHERNET(notifyWait,0.1%,561) HEAT(notifyWait,0.0%,328) Move(notifyWait,0.0%,259) CanReceiv(notifyWait,0.0%,799) CanSender(notifyWait,0.0%,336) CanClock(delaying,0.0%,339) TMC(notifyWait,8.5%,57) MAIN(running,61.3%,925) IDLE(ready,0.1%,30), total 100.0%
          Owned mutexes:
          Last reset 00:01:28 ago, cause: power up
          Last software reset at 2023-03-24 13:40, reason: User, GCodes spinning, available RAM 100324, slot 0
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x00
          Aux0 errors 0,0,0
          Step timer max interval 126
          MCU temperature: min 23.0, current 35.6, max 35.8
          Supply voltage: min 24.1, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
          12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
          Events: 0 queued, 0 completed
          Driver 0: standstill, SG min 0, mspos 1016, reads 31060, writes 16 timeouts 0
          Driver 1: standstill, SG min 0, mspos 24, reads 31060, writes 16 timeouts 0
          Driver 2: standstill, SG min 0, mspos 1016, reads 31057, writes 19 timeouts 0
          Driver 3: standstill, SG min 0, mspos 24, reads 31060, writes 16 timeouts 0
          Driver 4: standstill, SG min 0, mspos 130, reads 31057, writes 19 timeouts 0
          Driver 5: standstill, SG min 0, mspos 598, reads 31057, writes 19 timeouts 0
          Date/time: 2023-03-24 15:09:12
          Slowest loop: 16.87ms; fastest: 0.05ms
          === Storage ===
          Free file entries: 10
          SD card 0 detected, interface speed: 25.0MBytes/sec
          SD card longest read time 4.4ms, write time 0.0ms, max retries 0
          DMs created 125, segments created 3, maxWait 17600ms, bed compensation in use: none, comp offset 0.000
          === MainDDARing ===
          Scheduled moves 10, completed 10, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
          === AuxDDARing ===
          Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is idle in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          SBC is idle in state(s) 0
          Daemon is idle in state(s) 0
          Aux2 is idle in state(s) 0
          Code queue is empty
          === CAN ===
          Messages queued 795, received 715, lost 0, boc 0
          Longest wait 1ms for reply type 6018, peak Tx sync delay 10, free buffers 50 (min 49), ts 444/443/0
          Tx timeouts 0,0,0,0,0,0
          === Network ===
          Slowest loop: 16.54ms; fastest: 0.03ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
          HTTP sessions: 1 of 8
          = Ethernet =
          State: active
          Error counts: 0 0 0 1 0 0
          Socket states: 5 2 2 2 2 0 0 0
          === Multicast handler ===
          Responder is inactive, messages received 0, responses 0
          3/24/2023, 3:07:56 PM Connection established
          3/24/2023, 2:00:37 PM Connection interrupted, attempting to reconnect...
          m122 b1
          Diagnostics for board 1:
          Duet EXP3HC rev 1.01 or earlier firmware version 3.4.4 (2022-10-14 11:45:56)
          Bootloader ID: not available
          All averaging filters OK
          Never used RAM 158932, free system stack 200 words
          Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,108) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.4%,99) MAIN(running,91.2%,407) IDLE(ready,0.0%,40) AIN(delaying,1.3%,263), total 100.0%
          Last reset 00:02:28 ago, cause: software
          Last software reset data not available
          Driver 0: pos 0, 1746.2 steps/mm,standstill, SG min 0, mspos 2, reads 46407, writes 16 timeouts 0, steps req 0 done 0
          Driver 1: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 46413, writes 11 timeouts 0, steps req 0 done 0
          Driver 2: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 46413, writes 11 timeouts 0, steps req 0 done 0
          Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
          Peak sync jitter -2/10, peak Rx sync delay 177, resyncs 0/0, no step interrupt scheduled
          VIN voltage: min 24.2, current 24.3, max 24.3
          V12 voltage: min 12.3, current 12.3, max 12.3
          MCU temperature: min 26.4C, current 31.6C, max 31.6C
          Last sensors broadcast 0x00000000 found 0 165 ticks ago, 0 ordering errs, loop time 0
          CAN messages queued 1216, send timeouts 0, received 1339, lost 0, free buffers 37, min 37, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
          • T3P3Tonyundefined
            T3P3Tony administrators @wbrokow1
            @wbrokow1 what is the issue at this point? I don't see any phase errors from the drivers in those M122 reports and the 3HC is responding to can messages.
            www.duet3d.com
            • wbrokow1undefined
              wbrokow1 @T3P3Tony
              @T3P3Tony thanks for responding. basically the extruder was not extruding. I swapped to the second driver on the 3hc (1.1) and it worked. So I guess I have a bad driver on the 3hc board. Which is disappointing. I thought that spending extra for a quality board like the Duet would be w/o as many headaches as chinese crap.
                Can you setup the extruder motor on that original driver again and try to extrude? Do you get any error messages? After trying to extrude, send M122 and M122 B1 again and copy paste the results here please.
                When and where did you purchase the Duet boards? If we can verify the driver has failed and you're within the warranty period and the boards were purchased from an authorized vendor you would be entitled to warranty replacement.
                • wbrokow1undefined
                  wbrokow1 @Phaedrux
                  @Phaedrux I still get the phase A error . I purchased the boards from printed solid in August of 2022.
                  • wbrokow1undefined
                    wbrokow1 @wbrokow1
                    @wbrokow1 oops I purchased in 2021. But I actually couldn't install for over a year due to being in the hospital for. Kidney transplant!
                      dc42 administrators @wbrokow1
                      @wbrokow1 although our warranty is normally 1 year we'll make an exception in this case. Please email warranty@duet3d.com and include a link to this thread.
                      • wbrokow1undefined
                        wbrokow1 @dc42
                        @dc42 Thank you so much. With support like this all my future boards will be Duet!
