    Error: Number of calibration factors
    1.6k
    • antoine.voiryundefined
      antoine.voiry
      All,
      I just upgraded to latest firmware and when I try to do 4 points bed probes, I am getting
      Error: Number of calibration factors (4) not equal to number of leadscrews (2)
      The commands I sent are
      [[language]]
      ; BED PROBE SIMPLE
      M561
      G28 X0 Y0 Z0
      G30 P0 X30 Y30 F100 Z-99999       ; define 4 points in a clockwise direction around the bed, starting near (0,0)
      G30 P1 X30 Y270 F1500 Z-99999
      G30 P2 X200 Y270 F1500 Z-99999
      G30 P3 X200 Y30 F1500 Z-99999 S0
      M84
      My config is as follow, I am having since quite a while and there may be some old stuffs that are now causing issues.
      I am especially wondering about the M671 but there may be something else.
      [[language]]
      ; Communication and general
      M111 S0                             	; Debug off
      M550 pp3steel		; Machine name and Netbios name (can be anything you like)
      ;M551 Ppreprap                        	; Machine password (used for FTP)
      ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
      ; M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED 	; MAC Address
      ;*** Wifi Networking
      M552 S1				; Enable WiFi
      ; misc settings
      M555 P2                           	; Set output to look like Marlin
      M575 P1 B57600 S1			; Comms parameters for PanelDue
      ; setting for all axis
      G21                                 	; Work in millimeters
      G90                                	; Send absolute coordinates...
      M83                                 	; ...but relative extruder moves
      ; Axis and motor configuration
      M569 P0 S0				; Drive 0 goes forwards (x)
      M569 P1 S1				; Drive 1 goes forwards (Y)
      M569 P2 S1				; Drive 2 goes forwards (z)
      M569 P3 S0				; Drive 3 goes forwards (e1)
      M569 P4 S1				; Drive 4 goes forwards (E2)
      ; microstepping and homing switch config
      M350 X16 Y16 Z16 E16 I1             ; set 16x microstepping with interpolation
      M574 X1 S0		    ; set homing switch configuration (X homing switch only, at low end, active high)
      M574 Y1 S0		    ; set homing switch configuration (Y homing switch only, at low end, active high)
      M574 Z0 S1		    ; set homing switch configuration (z homing switch only, at low end, active high)
      ; Motor current and acceleration
      M906 X1000 Y1100 Z1000 E1100 I60		; Set motor currents (mA) and increase idle current to 60%
      M84 S60 ; Set idle timeout
      M201 X600 Y600 Z10 E600		; Accelerations (mm/s^2)
      M203 X5000 Y5000 Z100 E9000		; Maximum speeds (mm/min)
      M566 X1200 Y1200 Z30 E200		; Maximum instant speed changes mm/minute
      M210 X6000 Y6000 Z10  			; set hming feedrate
      ; steps per mm
      M92 X80 Y80 Z4000  ; Set axis steps/mm
      M92 E492.45:492.45                          ; set extruder 0 and 1 steps/mm
      ; max travel and origin
      M208 X210 Y305 Z200
      ; Thermistors
      M305 P0 R4700 T100000 B4388   ; set bed thermistor parameters
      M305 P1 R4700 T100000 B4388   ; set E0 thermistor parameters
      M307 H1 A474.7 C114.3 D5.5 B0; PID settings for extruder 0
      M143 H1 S270 ; Set maximum heater temperature to 270C
      M307 H0 D20
      M106 P1 H-1 				; disable thermostatic mode for fan 1
      ; Tool definitions
      M563 P0 D0 H1                       	; Define tool 0
      G10 P0 S0 R0                        	; Set tool 0 operating and standby temperatures
      ; Z probe and compensation definition
      M558 P1 X0 Y0 Z1 H3 F200 T3000    ; smart IR Z probe, used for homing Z axis only, dive height 3mm, probe speed 200mm/min, travel speed 5000mm/min
      G31 P500 X10 Y24 Z1.90        ; set threshold and offsets
      ;*** If you are using axis compensation, put the figures in the following command
      M556 S78 X0 Y0 Z0                   	; Axis compensation here
      M208 X0 Y0 Z0 S1 				; set minimum Z
      T0					; select first hot end
      M671 X--60:270 Y45:45
        You have included a M671 command in config.g, so G31 and bed.g will do leadscrew calibration. If you want to implement bed compensation, use G29 mesh bed compensation.
          antoine.voiry
          Thanks
          So I should really only use M671 when I want to do a leadscrew calibration or a bed adjustment. In such case, how do I start the process, is that a G32?
          Antoine
            Yes, if you use M671 then G32 does leadscrew calibration or manual adjustment calculation.
              antoine.voiry
              Thanks,
              Is there a user guide on G32 and M671?
              I basically get
              G32
              12 points probed, mean error 0.002, deviation 0.144
              Height map saved to file heightmap.csv
              Antoine
                If you are getting that message, you must have a G29 command in bed.g.
                Instructions for using M671 are at https://duet3d.com/wiki/Bed_levelling_using_multiple_independent_Z_motors and https://duet3d.com/wiki/Using_the_manual_bed_levelling_assistant.
                  antoine.voiry
                  Thanks a million! that works
                  • madhunmundefined
                    madhunm
                    @dc42 said in Error: Number of calibration factors:
                    Hi @dc42 ,
                    I am trying to use the manual bed levelling assistant and I am getting the same error as above.
                    Here is my bed.g and config.g; any help would be appreciated.
                    Thanks,
                    Madhu.
                    1_1539258361848_config.g
                    0_1539258361847_bed.g
                      You have only 2 mounting screw points defined in the M671 command in config.g, but you have S4 on the last g30 command in bed.g. If there really are only 2 mounting points for the bed (unlikely!), use S2. Otherwise, add the coordinates of the other mounting screws to the M671 command.
