Help with a Short to Ground that is occurring
@abindarraez1 which driver is reporting a short to ground?
@jay_s_uk 1Generally Driver 1. It also sends me a high temp alert.
Driver 2 also sends me an error. -
@abindarraez1 if you swap the motor on driver 1 with say driver 0, does it report the error?
@jay_s_uk I am worried it might burn that driver as well
But I will try it. -
@jay_s_uk Error moved. Now it is on driver 2 and 3. Also, the printer moved but with a lot vibrations.
@abindarraez1 so you have a problem with your stepper motors and/or motor wiring. Nothing wrong with the board
@jay_s_uk Thanks a lot. But any clue what could be causing it? The motors seem to work well with the DRV8825
@abindarraez1 poor or failing crimps would be my guess
@abindarraez1 Thanks, I will revise them.
