    Duet3Bootloader compilation
    Firmware developers
    379
    • Arplyuundefined
      Arplyu
      Hi, could anybody confirm if the compilation instructions available in the bootloader repository's readme are still valid? Or if not, are there correct instructions available anywhere else? To me it looks like the instructions from readme are outdated, or I do something wrong. Thanks!
      droftartsundefined dc42undefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @Arplyu
        @Arplyu Do you mean here? https://github.com/Duet3D/Duet3Bootloader#build-instructions
        Are you getting error messages when compiling?
        Possibly cross reference installation and usage with the RRF instructions https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware
        Arplyuundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @Arplyu
          @Arplyu do you mean the bootloader for CAN-connected expansion boards, or the bootloader for the Mini5+ ?
          • Arplyuundefined
            Arplyu @droftarts
            @droftarts Thanks for reply! Yes, I used those instructions. I chose the branches as said in the instructions. I don't remember, where I saw the build configs for bootloader, but AFAIR there should be non-RTOS configs. So I selected SAMC21_nonRTOS for CANLib, SAMC21 for RRFLibraries and SAMMYC21 for the main project. The target board for which I want to build the bootloader is SAMMYC21. So, as a result I get the following error when compiling RRFLibraries:
            ../src/Math/Isqrt.cpp:7:11: fatal error: Core.h: No such file or directory
                7 | # include <Core.h>
            which possiblyt refers to Core.h from CoreN2G (???), however nothing is said that this should be added to the workspace (anyways, adding CoreN2G didn't help and induced even more errors). In turn, error in RRFLIbraries doesn't allow to compile the main project.
            • Arplyuundefined
              Arplyu @dc42
              @dc42 sorry, I missed your reply while was writing my response to @droftarts . Yes, I mean bootloader for CAN-boards, more precisely for SAMMYC21
                @Arplyu yes you need to include CoreN2G in your workspace. I have updated the build instructions at https://github.com/Duet3D/Duet3Bootloader/blob/master/README.md to reflect this and also to correct the current branch names of the various projects.
                What changes are you looking to make to the bootloader?
                • Arplyuundefined
                  Arplyu @dc42
                  @dc42 thank you for the reply.
                  My goals are 1. research interest 😃 2. adding own configuration to the expansion board firmware and a corresponding binary name to the bootloader (to update via CAN). The new config will be based on SAMMYC21, therefore I try to build first the standard SAMMYC21 configuration.
                  I tried with adding CoreN2G project (config SAMC21_nonRTOS) and setting branch names according to the updated instructions. However, compilation failed again. I've tried in both Linux and Windows (I used to work with RRF3 in Linux during last 1.5 years and everything has always been ok; I haven't had any problems with compilation for expansion board firmware in Linux neither).
                  The errors were similar in both systems:
                  ../src/Bootloader.cpp: In function 'void GetBlock(uint32_t, uint32_t&)':
                  ../src/Bootloader.cpp:211:19: error: no matching function for call to 'CanMessageBuffer::CanMessageBuffer()'
                    211 |  CanMessageBuffer buf;
                  In file included from ../src/Bootloader.cpp:22:
                  /mnt/NTFSD/DEV/DUET_BOOTLOADER/CANlib/src/CanMessageBuffer.h:28:2: note: candidate: 'CanMessageBuffer::CanMessageBuffer(CanMessageBuffer*)'
                     28 |  CanMessageBuffer(CanMessageBuffer *prev) noexcept : next(prev) { }
                  /mnt/NTFSD/DEV/DUET_BOOTLOADER/CANlib/src/CanMessageBuffer.h:28:2: note:   candidate expects 1 argument, 0 provided
                  /mnt/NTFSD/DEV/DUET_BOOTLOADER/CANlib/src/CanMessageBuffer.h:25:7: note: candidate: 'constexpr CanMessageBuffer::CanMessageBuffer(const CanMessageBuffer&)'
                     25 | class CanMessageBuffer
                  /mnt/NTFSD/DEV/DUET_BOOTLOADER/CANlib/src/CanMessageBuffer.h:25:7: note:   candidate expects 1 argument, 0 provided
                  /mnt/NTFSD/DEV/DUET_BOOTLOADER/CANlib/src/CanMessageBuffer.h:25:7: note: candidate: 'constexpr CanMessageBuffer::CanMessageBuffer(CanMessageBuffer&&)'
                  make[1]: *** [src/subdir.mk:26: src/Bootloader.o] Error 1
                  make: *** [makefile:56: all] Error 2
                    @Arplyu there is an incompatibility between the branches or versions of files in CANlib and Duet3Bootloader. Check that you are using the latest commits on the branches that I listed in the readme file.
                    • Arplyuundefined
                      Arplyu @dc42
                      @dc42 thanks, and sorry for taking your time with this problem. I've double checked, I'm pretty sure I use the latest commits on exactly those branches. Just in case:
                      CANLib
                      d2210cd9cdde4e40c4c575b273b58ddc75600b91
                      CoreN2G
                      de512d3ce8c7add8c7230a102086b652f036f26e
                      Bootloader
                      a3a9567a427e9749796ec037e2c989d7ff571005
                      RRFLibraries
                      a7260b7073f5b0a7e6940587ae34a0584f8ceee7
                        @Arplyu I'm sorry, Eclipse was showing that my working copy of Duet3Bootloader was in sync with the remote, but in fact it wasn't and the remote was missing a change. Please update Duet3Bootloader and try again.
                        Arplyuundefined 1 Reply Last reply Reply Quote 1
                        • Arplyuundefined
                          Arplyu @dc42
                          @dc42 Thanks a lot! Now it compiles 👍
                          • T3P3Tonyundefined T3P3Tony marked this topic as a question
                          • T3P3Tonyundefined T3P3Tony has marked this topic as solved
