    confusion about carriage offsets in IDEX mode
    Using Duet Controllers
    idex copy-mode offsets
    612
    • oliofundefined
      oliof
      Hello everyone,
      I am finding time again to work on my IDEX printer and I want to get copy and mirror mode going again, but I am getting confused about copy mode and mirror mode.
      The IDEX printer is a quite custom one. X carriage idea taken from RatRig V-Cast, bedslinger using an Ender3 style Y carriage, Dual Z.
      Now, I am trying to set the offsets for copy mode. One thing that seems to complicate this is since I started out with a delta, I like to set my print area zero-centered. So my standard axis limits are
      M208 X-139.8:105 Y-105:110 U-80:140.7 Z0:200         ; axis limits.
      This way I do not need tool offsets for single/dual head mode because everything aligns via the magic of X endstop position, Y endstop position, and symmetry.
      Now, if I want to do copy mode, things get weird. My naive assumption is:
      a) I change the slicer to slice for a half width bed that now the slicer assumes goes from 0 to 110 (good enough for copy mode, because if X goes to the right, U goes to the right, and the print heads should always be 110mm apart from each other. They have a clearance of 81mm -- i.e. I can move U 81mm to the right of X and they are just not touching at the fan ducts. Very orderly).
      What's not working at all is setting offsets for X and getting expected results when I am going into copy mode (I have not looked into mirror mode).
      Now, my naive assumption was that I can do
      G10 P2 X110 U0 Z0
      for tool 2 and basically have X just offset 110mm to the left, and everything should work.
      What happens though is the following: If I run T2 P0 to enable copy mode after homing, the X position shifts from -139.8 at the homing position to 55.5 at the homing position. But -139.8+110 should be -29.8 .... EDITED to add: When I do run G10 P0 X110 I get the expected change to -29.8.
      Here is my tpost2.g which isn't doing anything to the coordinate system
      M106 R2      ; restore print cooling fan speed
      M116 P2      ; wait for tool 2 heaters to reach operating temperature
      M83          ; relative extruder movement
      M567 P2 E1:1 ; set tool mix ratio
      M568 P2 S1   ; turn on mixing
      G1 E2 F3600  ; extrude 2mm from both extruders
      I am pretty sure I have a thinko somewhere in my setup, but I cannot figure it out. Any input is welcome.
      For what it's worth, this is running on a Duet 3 mini 5+ 3.5b2 with two SB2040 based toolheads (which tend to lose sync on mainboard reset and require a full powercycle to come back, a minor annoyance which probably deserves another thread).
      • config.g
      • tpost2.g
      • tfree2.g
      • oliofundefined
        oliof @oliof
        Now I am even more confused. Out of over abundance I did not dare move the print heads with the wrong X position displayed in DWC. But copy/mirror mode actually do move the print carriages correctly. So maybe one for @chrishamm? PS I love that DWC3.5 does only show copy/mirror mode once and switches to the (last) selected one automagically. Nice save of screen estate (-:
        • T3P3Tonyundefined
          T3P3Tony administrators @oliof
          @oliof are you still having this issue?
          www.duet3d.com
          • oliofundefined
            oliof @T3P3Tony
            @T3P3Tony I have not updated to 3.5-beta3 yet, but will do that in a hot minute. I will report back after that.
            oliofundefined 1 Reply Last reply Reply Quote 1
            • oliofundefined
              oliof @oliof
              @T3P3Tony okay, updated Duet 3 mini 5+, DWC, and toolboards to 3.5-beta.3, and Wifi to 2.1b4. Thanks to @jay_s_uk for sorting the RPico firmware with two different addresses quicker than I could have set up a working build environment.
              I am still confused about certain things, and there may be bugs about my tool changing macros (Sometimes active/standby temps are set to 1/0; I probably would need to set the temps for T2/T3 but I could swear at least one occurrence I did set the tool temps with G10 and they were reset to 1/0 ... but that's for another discussion)
              Here is how things go when I activate tool 0, then switch to tool 1, then tool 2, then tool 3, then tool 0 again. Logs below, as you see X position changes to unexpected values when switching tools.
              Also, when I switch from T0 to T1, T1 tries to go to the X position from T0 -- but that is beyond the axis minimum I did send for U axis. How would I make sure that does not happen? I am aware that usually yes, I want T1 to take the position of T0 for a multicolor print; but I would expect T1 to keep within the axis limits of the U axis. How would I do that?
              4/16/2023, 9:40:17 PM 	T-1
              4/16/2023, 9:40:23 PM 	M114
              X:-139.800 Y:-105.000 Z:16.000 U:140.700 E:0.000 E0:0.0 E1:-1.5 Count -11184 -8400 25600 11256 Machine -139.800 -105.000 16.000 140.700 Bed comp 0.000
              4/16/2023, 9:40:46 PM 	T0
              4/16/2023, 9:41:05 PM 	M114
              X:-139.800 Y:-105.000 Z:16.000 U:140.700 E:0.000 E0:2.0 E1:-1.5 Count -11184 -8400 25600 11256 Machine -139.800 -105.000 16.000 140.700 Bed comp 0.000
              4/16/2023, 9:41:50 PM 	T1
              4/16/2023, 9:42:05 PM 	G28 U
              4/16/2023, 9:42:16 PM 	M114
              X:140.700 Y:-105.000 Z:16.000 U:140.700 E:0.000 E0:0.0 E1:-1.0 Count -11184 -8400 25600 11256 Machine 9999.900 -105.000 16.000 140.700 Bed comp 0.000
              4/16/2023, 9:42:47 PM 	T2
              4/16/2023, 9:43:55 PM 	G10 P2 S200 R180
              4/16/2023, 9:44:00 PM 	M114
              X:55.450 Y:-105.000 Z:18.000 U:140.700 E:0.000 E0:2.0 E1:-1.0 Count -11184 -8400 28800 11256 Machine -54.550 -105.000 18.000 55.450 Bed comp 0.000
              4/16/2023, 9:44:39 PM 	T3
              4/16/2023, 9:45:34 PM 	M114
              X:-85.250 Y:-105.000 Z:21.000 U:-140.700 E:0.000 E0:0.0 E1:-3.0 Count -11184 -8400 33600 11256 Machine -195.250 -105.000 21.000 85.250 Bed comp 0.000
              4/16/2023, 9:46:07 PM 	T0
              4/16/2023, 9:46:24 PM 	M114
              X:-85.250 Y:-105.000 Z:21.000 U:140.700 E:0.000 E0:2.0 E1:-3.0 Count -6820 -8400 33600 11256 Machine -85.250 -105.000 21.000 140.700 Bed comp 0.000
              T3P3Tonyundefined 1 Reply Last reply Reply Quote 1
              • T3P3Tonyundefined
                @oliof
                Interesting observations, its been a while since I have used an Idex machine so i may need to check back and forth with you a bit to get to the bottom of this.
                change from T0 to T1:
                T1 uses U as X, as expected to the X user position is showing the U position (the Machine Coordinates look like they are reported oddly by M114, X being 9999.9 is odd, one for @dc42 ). The reason why its trying to move to the X position could be because of a restore position (G1 R2) in your tool change macros somewhere?
                Change from T1 to T2. X is now both X and U in copy mode. With 109.1mm between the two "X" axis machine positions of the heads (54.550 *2) that's also a bit strange unless you have updated your config.g to change the distance between the two tools from the 110 you have in the config.g posted a few days ago in your first post in this thread?
                Also i think you may have missed this point from the documentation:
                In this example we want to print one object using the X carriage and another identical object 100mm further along using the U carriage. So we specify X and U offsets of 50mm in opposite directions. However, tool offsets are given as the offset of the nozzle relative to the print head reference point, so the signs are opposite to what you might expect because tool offsets are subtracted from the required printing locations during printing. So we need to use an X offset of +50mm to force the X carriage to be 50mm lower along the X axis, and a U offset of -50mm to force the U carriage to print 50mm higher along the X axis.
                in your config.g you have:
                G10 P2 X110 Y0 U0 S0 R0
                when i think you should have
                G10 P2 X55 Y0 U-55 S0 R0
                T2 to T3 mirror mode, lets look at that after sorting T2.
                www.duet3d.com
                • oliofundefined
                  oliof @T3P3Tony
                  @T3P3Tony
                  T0 to T1) yes, second head tries to move to the restore point, but its going out of bounds for the axis second head actually sits on. It's not a problem during most normal operations except for very wide prints since the first head does not clear the printable area completely
                  T[01] to T2 -- the documentation note does not apply this way in my case since my original bed dimensions are zero centered.
                  Same with T3, only difference is the U axis is mirrored and I lose some Y to keep the print heads from crashing into each other.
                  The main issue here is that the displayed X position is wrong, the axes work as expected (I did a combined print and a print in copy mode to verify this).
                  Anyways, here are my config.g and my tool change macros for completeness sake.
                  • config.g
                  • tfree0.g
                  • tpre0.g
                  • tpost0.g
                  • tfree1.g
                  • tpre1.g
                  • tpost1.g
                  • tfree2.g
                  • tpost2.g
                  • tfree3.g
                  oliofundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
                  • oliofundefined
                    oliof @oliof
                    • tpost3.g
                    • T3P3Tonyundefined
                      @oliof said in confusion about carriage offsets in IDEX mode:
                      ahh right, that may explain the odd reporting. i am not sure that zero centering the bed means that the two tool offsets should be different through. ultimately you want the heads to be evenly split around 0. no matter if 0 in in a corner or in the middle.
                      www.duet3d.com
                      • oliofundefined
                        oliof @T3P3Tony
                        @T3P3Tony I thought about why my setup is working, and the missing piece of information is that the slicer setting for the copy/mirror mode is not using zero centered coordinates and simply splits Y length in half. So the X head needs to be offset from zero to the left hand side, and the U head runs unmodified, and by magic ... err ... two errors canceling each other out, things work.
                        If I were to use zero centered setup in the slicer for copy/mirror mode, your offset definition would be correct. I will adjust that for consistency's sake (and it should allow me to take prints to copy/mirror mode without needing an extra slicer profile).
                        • T3P3Tonyundefined
                          @oliof thanks for confirming what was going on!
                          www.duet3d.com
