    DWC fails to download plugin
    Plugins for DWC and DSF
    414
    • Nova1545undefined
      Nova1545
      Using DWC version 3.4.2. I have attempted to create a custom plugin, the only problem is, when I load it into DWC it fails to load. DevTools reports that the connection was reset (net::ERR_CONNECT_RESET) but, when loaded in the browser via it's link it loads fine without any issues. I have attempted to clear browser cache, clear cookies, etc with no such luck in solving this issue.
      Using a standalone version of DWC built from it's source also results in the plugin loading perfectly fine
      Any ideas on how to fix this? I can't seem to find anything I haven't already tried
        Can you update to DWC 3.4.5?
        Nova1545undefined 1 Reply Last reply Reply Quote 0
        • Nova1545undefined
          Nova1545 @Phaedrux
          @Phaedrux Just as I finished typing out a "It just fixed itself" reply, it breaks itself again. I have updated to 3.4.5 and it has not resolved the issue.
          The code used in the extension is below
          'use strict'
          console.log("Test");
          const x = async () => {
              const req = await fetch(`${window.location.origin}/rr_model?flags=d99fn`, {method: "GET"});
              if (req.status === 200) {
                  const data = await req.json();
                  console.log(data);
          x();
          //setInterval(() => {x()}, 1000);
          This code loads and runs fine when I run it in a instance built straight from the github Correction: It works when loaded as a built-in plugin
          • chrishammundefined
            chrishamm administrators @Nova1545
            @Nova1545 How do you built the plugin? Are you using the build-plugin command from DWC to generate a ZIP file? Note that external plugins cannot be loaded in dev mode.
            Duet software engineer
            • Nova1545undefined
              Nova1545 @chrishamm
              @chrishamm Yes it is built using build-plugin
                @Nova1545 If the connection is reset while loading a file, you probably have a problem with the connection between your PC and Duet. I guess you are operating your Duet in standalone mode? What board do you have? If it is a WiFi board, have you checked the WiFi signal yet?
                • Nova1545undefined
                  Nova1545 @chrishamm
                  @chrishamm Duet 3 Mini 5+ in standalone mode, connected via ethernet. The file also loads perfectly fine if I copy the link and open and view it in a normal browser tab.
                  To add insult to injury, other plugins (Such as the EndstopsMonitor and HeightMap) are showing a similar behaviour. However, it's only the plugins having any issues, the DWC interface otherwise loads and works perfectly fine.
                    @Nova1545 Maybe an issue with an adblocker? Try to disable your browser addons.
                    • Nova1545undefined
                      Nova1545 @chrishamm
                      @chrishamm Yes it was, didn't even think to try disabling that. Thanks!
                      stuartofmtundefined 1 Reply Last reply Reply Quote 1
                      • chrishammundefined chrishamm marked this topic as a question
                      • chrishammundefined chrishamm has marked this topic as solved
                      • stuartofmtundefined
                        stuartofmt @Nova1545
                        @Nova1545
                        FWIW - I moved away from using browser based add blockers and now use pihole. Because it blocks add requests before they leave for the internet it has multiple benefits.
                        • Nova1545undefined
                          Nova1545 @stuartofmt
                          @stuartofmt I currently use both (Pi-hole doesn't work for some sites, even after adding the domains they use for ads), I will just add an excpetion to the ad-block for the duet page
                          stuartofmtundefined 1 Reply Last reply Reply Quote 0
                            @Nova1545 said in DWC fails to download plugin:
                            Yeah - I hear you. And not much to be done when the adds are resolved at the server end. Personally, I was lucky to even get away with pihole. SWMBO still gets annoyed with the "sponsored" search results not being accessible, 🙄
