    X Home to -ve value
    Laser Cutters
    329
    • CNCModellerundefined
      CNCModeller
      Hi All,
      I think I know what's going on here but don't know for sure I'm doing the right thing to compensate for it.
      If I home X at y0 it homes to 0.0, if I home X at y220 it homes to -1.6.
      I'm using axis compensation to allow for my inability to correctly align the laser path in my K40 laser.
      So I believe I'm seeing this due to compensation working as intended.
      So to get the laser to home to Y max where my home sensors are I'm just adding a g0 x0 to the end of the home macros.
      Is this sensible or am I missing something?
      Many thanks
      Barry M
      Polar Duet3 Mini + 1HCL
      https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
      Wanhao D4S: Duet2
      https://forum.duet3d.com/post/296755
      K40 Laser, Duet2
      https://forum.duet3d.com/post/312082
      Wanhao D5S
      https://www.youtube.com/CNCModellerUK
        dc42 administrators @CNCModeller
        @CNCModeller said in X Home to -ve value:
        Won't that mean that the homing position is wrong if you home X other than at Ymax?
        Can you change your homeall.g file to home Y before homing X? Or to home X and Y together to start with, then fine-home Y, then fine-home X?
        CNCModellerundefined 1 Reply Last reply Reply Quote 0
          CNCModeller @dc42
          @dc42 said in X Home to -ve value:
          So I'm homing to the switches at xmin ymax, which leaves the X axis at a -ve value due to skew compensation. Then I moved the head to the indicated X0.
          Then when it moves to X0 Y0 I assume the compensation pushes the axes to X+1.6, but because of the laser skew it hits the bed at 0,0.
          I'll check that everything is still in calibration, but that's what I assume is happening...
          Wanhao D4S: Duet2
          K40 Laser, Duet2
          Wanhao D5S
          • o_lampeundefined
            o_lampe @CNCModeller
            @CNCModeller When you cut a square do you see true angles? If not, you can adjust the frame in the housing. IIRC the mounting holes in the housing are bigger than the frame holes, so you can push the front and back of the frame in different directions until it's true.
              CNCModeller @o_lampe
              @o_lampe said in X Home to -ve value:
              The frame is square, it's my lack of ability to align the laser mirrors properly that is causing the drift.
              But with skew compensation enabled I'm getting geometry and dimensions which are accurate enough for my purposes.
              Wanhao D4S: Duet2
              K40 Laser, Duet2
              Wanhao D5S
              • o_lampeundefined
                I hear you! That's the most annoying task, but I found a good german discord channel where i found help.
                The mistake most people do is trying to align the near and far points when they use the tape-method.
                But in fact you have to "overcompensate". Can't describe it, due to lack of vocabulary. Maybe you find an engish video describing the CDA-method
                Here's the german video that helped me
                  Thanks @o_lampe, my partner is a fluent German speaker so hopefully she can translate 🙂
                  Wanhao D4S: Duet2
                  K40 Laser, Duet2
                  Wanhao D5S
                    CNCModeller
                    After doing some googling I've found this which I'll try after the current sweet of upgrades...
                    https://youtu.be/rYX0zfWFnIM
                    Wanhao D4S: Duet2
                    K40 Laser, Duet2
                    Wanhao D5S
