    Initial Config Query
    1.3k
    • 900turboundefined
      900turbo
      I have uploaded my config.g had a error code for bed compensation which I have corrected. However I have Error codes for both heaters. I have read the commissioning guide checked for incorrect wiring , grounding and incorrect firmware. If anyone can help I would greatly appreciate it. Thank You.17bf1b0c-9a30-435e-838c-5a4a52997ae2-image.png
      M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
      M143 H0 S70 ; set temperature limit for heater 0 to 70C
      M308 S1 P"121.temp0" Y"pt1000" ; configure sensor 1 as PT1000 on pin 121.temp0
      M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
      M143 H1 S300 ; set temperature limit for heater 1 to 300C
      jay_s_ukundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @900turbo
        @900turbo nothing looks odd there. can you show photos of your wiring?
        900turboundefined 1 Reply Last reply Reply Quote 1
        • 900turboundefined
          900turbo @jay_s_uk
          @jay_s_uk 745D6032-2434-4ADF-8E70-60682AD75DAA.jpeg 5D95F5EC-F5DC-40FA-BE53-74513CF94FD1.jpeg
          Here are photos of the MB , And tool board ( current printer head bracket is only a temporary mock up )
            jay_s_uk @900turbo
            @900turbo said in Initial Config Query:
            this is incorrect as you're using a revo and that uses a 104NT-4 thermistor, not a PT1000
            It should be
            M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8
            And your wiring looks right for the bed however, are you sure you've selected the correct type? can you use a multimeter to see what value you get?
            • 900turboundefined
              900turbo @jay_s_uk
              @jay_s_uk I have sorted the beds issues unplugged then replugged it and now reads 17.3 degrees so that is sorted. I did select the 104NT-4 on the RepRap site , I think it may be a little buggy will try what you have suggested and report back.
              Thank You.
              • 900turboundefined
                900turbo
                @jay_s_uk t=Thank you so much for the help , that worked perfectly!
                • 900turboundefined
                  900turbo @900turbo
                  @jay_s_uk Going through commissioning my extruder heater works perfectly and I have run it through Tuning successfully . However my bed will not change temperature despite the sensor now reading a realistic Temp SSR is wired into out 0 as recommended , current config is below. Also cannot move any axis despite sending M564 S0 H0 no warnings or errors come up however not sure why this is.
                  If you could help it would be greatly appreciated.
                  Thank You.
                  M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
                  900turboundefined 1 Reply Last reply Reply Quote 0
                  • 900turboundefined
                    900turbo @900turbo
                      jay_s_uk @900turbo
                      @900turbo that mostly looks right although its more then likely a B3950 rather than a B4138.
                      If using an SSR add Q10 to the end of the M950 command.
                      Have you tried tuning the Bed with M303 H0 S60?
                      What drivers are you using? how have you wired them? post your complete config
                      900turboundefined 3 Replies Last reply Reply Quote 0
                      • 900turboundefined
                        900turbo @jay_s_uk
                        @jay_s_uk 02d0ad8c-b0d8-42d9-a95f-0a712ce69de0-image.png This is what i receive when trying to tune.
                        Will take photos and post config.
                        • 900turboundefined
                          900turbo @jay_s_uk
                          @jay_s_uk ; Configuration file for Duet 3 MB 6XD (firmware version 3.3)
                          ; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Apr 17 2023 13:03:57 GMT+0100 (British Summer Time)
                          M550 P"Duet 3" ; set printer name
                          M669 K1 ; select CoreXY mode
                          M569 P0.5 S1 ; physical drive 0.5 goes forwards
                          M569 P0.4 S1 ; physical drive 0.4 goes forwards
                          M569 P0.1 S1 ; physical drive 0.1 goes forwards
                          M569 P0.3 S1 ; physical drive 0.3 goes forwards
                          M584 X0.5 Y0.4 Z0.1 E0.3 ; set drive mapping
                          M92 X53.33 Y53.33 Z53.33 E436.54 ; set steps per mm
                          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
                          M906 X3000 Y3000 Z3000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30 ; Set idle timeout
                          M208 X700 Y700 Z1700 S0 ; set axis maxima
                          M574 X1 S1 P"121.io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io2.in
                          M574 Y1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io0.in
                          M574 Z1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io1.in
                          M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
                          M558 P9 C"121.io0.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                          M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                          G31 P500 X0 Y23.56 Z2.5 ; set Z probe trigger value, offset and trigger height
                          M557 X0:700 Y23.56:700 S34.4; define mesh grid
                          M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency
                          M950 F1 C"121.out2" Q500 ; create fan 1 on pin 121.out2 and set its frequency
                          T0 ; select first tool
                          • 900turboundefined
                            900turbo @jay_s_uk
                            @jay_s_uk 321BFC1A-7541-4A8A-B377-7DA22D0DBF7F.jpeg C3D695D0-83EE-463F-86E4-4439A8BDDC4A.jpeg
                            Here are my drivers and how I’ve wired them as recommended by Duet
                            • chrishammundefined
                              chrishamm administrators @900turbo
                              @900turbo Try to add Q10 to your config as @jay_s_uk suggested. The default PWM frequency is way too high for an SSR:
                              M950 H0 C"out0" T0 Q10 ; create bed heater output on out0 driven at 10Hz and map it to sensor 0
                              Bang-bang control may be even better for an SSR.
                              Duet software engineer
                              900turboundefined 2 Replies Last reply Reply Quote 0
                              • 900turboundefined
                                900turbo @chrishamm
                                @chrishamm Thanks for the advice added this to my config but Im still having the same issue.
                                • 900turboundefined
                                  900turbo @chrishamm
                                  @chrishamm I should note I do also currently have bang-bang mode enabled on the config.
                                    @900turbo Please check your SSR, it looks like it does not turn on. If it does, the connection between SSR and your heated bed may be dodgy. Also, you should tune your heaters before you actually try to use them or you will get more heater faults.
                                    Note that the heater should turn on as well as soon as you start heater tuning.
                                    • 900turboundefined
                                      900turbo @chrishamm
                                      @chrishamm Checked my SSR with a multimeter and its reading 0.8 which suggests it Is not burnt out. I have gone back over the connection to the heated bed and there is no damage or exposed wiring or a open circuit. So I am a bit lost as to what's wrong.
                                        @900turbo Does the LED next to out0 turn on when you start heater tuning? And do you measure Vin or 12V across the inputs of the SSR while it's lit?
                                        • 900turboundefined
                                          900turbo @chrishamm
                                          @chrishamm The LED next to out0 does turn on. I should note the heated bed is extremely big 700x700mm could this have any effect? What do you mean by that is in take those measurements whilst the SSR is on?
                                            @900turbo It depends on the power of your bed heater but there should be at least some temperature rise, which is not detected by the firmware. Hence my suspicion that the control signal from the Duet does not turn on your SSR. That's why I suggest to check if there is enough voltage across the control input of the SSR to make it turn on.
