Deamon.g execution wait time to handle event triggers
The current wait time for RRF to execute daemon.g file is 10 seconds. I have the following code in daemon.g with the global variables declared in config.g
;daemon.g while {global.alert} = 1 M42 P30 S0.2 ; beeper on G4 P100 ; wait 200ms M42 P30 S0.8 ; beeper on G4 P100 ; wait 200ms M42 P30 S0 ; beeper off G4 S1 ; delay 1 second while {global.warning} = 1 M106 P9 S255 ; LED 1 on M106 P10 S255 ; LED 2 on M42 P30 S0.7 ; beeper on G4 P100 ; delay 100ms M106 P9 S0 ; LED 1 off M106 P10 S0 ; LED 2 off M42 P30 S0 ; beeper off G4 P100 ; delay 100ms
For example with an event, let's say a filament runout event that will send,
set global.alert = 1
It will potentially take up to 10 seconds for the command in daemon.g to execute even though it is in a while loop. Before RRF 3.3 the wait time was 1 seconds which is ideal but may potential take up precious computing resources. Is there anyway for a user to decrease the wait time? Or even better for it to be a configurable amount of time in gcode or Duet Web Control for future RRF and DWC releases.
@presto put them in a loop so something like
while true while {global.alert} = 1 ...
then they will run continuously
undefined presto marked this topic as a question
undefined presto has marked this topic as solved
