Connecting multiple duets to one SBC
Hey,
for one of our printers (which basically is two separate printers in one enclosure) we were wondering if it's possible to use the SBC SPI connection with multiple controllers and one pi.
If not, are there any plans to support this in the future? (Currently we run USB but are in the process of switching to SBC for a few reasons and would like to do so on this model as well)
Could not find any information about this. Neither that it's supported nor that it can't be done. From my understanding SPI by itself should be capable of it.Thanks
@benecito Yes, it is possible in theory, but I have never tried it in practice before. You can have two instances of DuetControlServer/DuetWebServer running on the same system, but then of course with different configs for each of them. For the second Duet you will need to configure a different SPI port or at least a different CS line and a different TfrRdy GPIO pin. In addition, the second DCS instance needs to use a different base path (virtual directory of the first SD card used by RRF), a different UNIX IPC socket directory, and the second DWS instance has to be configured to use it then. See here for further details about the SPI link.
The UNIX IPC socket path directory is configured by property
SocketDirectory
and the virtual SD directory base path is set byBaseDirectory
in/opt/dsf/conf/config.json
. The same UNIX socket path has to be set using the--SocketPath <SocketDirectory>/dcs.sock
argument when launching the second DWS instance as well as a different URL to listen to using the--urls http://*:8080
argument.DCS can be started using the
-c <configPath>
argument to specify a different config file, so maybe just copy/opt/dsf/conf/config.json
to/opt/dsf/conf/config2.json
and make a second service instance to use that. -
@chrishamm Thanks for the quick reply! Would this concept (in theory) be expandable to as many instances as needed until the pi runs out of power at some point?
Will try it and report back (but might take a bit)
@benecito Each DSF instance requires some CPU + memory to keep the OM updated and sharing the same SPI port may introduce extra lags, so I'd only connect independent SPI ports if possible. Please let me know how it goes!
@chrishamm Will report back after some experimenting, or when running into some issues
@chrishamm
I just figured out the wiring but can't start a second DCS instance.I duplicated
/opt/dsf/
in/opt/dsf2/
to keep things separate but also tried theconfig2.json
. As neither of them worked I also tried to start the first (regular) DCS instance withsudo systemctl start duetcontrolserver -c /opt/dsf/conf/config.json
but it returns:
systemctl: invalid option -- 'c'
Are you sure this works, or do I need to duplicate something else as well?
I managed to start one instance on spi4, but figured spi1 und 4 don't work together - will need to search for an alternate wiring scheme I guess...
@chrishamm
Managed to rewire to spi3 and have spi0 and spi3 running at the same time now. So just need to figure out how to start the second DCS -
@benecito You need to duplicate the service file and edit it (/usr/lib/systemd/system/duetcontrolserver.service) to start with a different config. Same applies to the duetwebserver service.
@chrishamm all right - duplicated both of them. Do I need to edit anything but line 6?
[Unit] Description=Duet Control Server StartLimitIntervalSec=0 [Service] ExecStart=/opt/dsf2/bin/DuetControlServer TimeoutStopSec=15 Restart=always Type=notify User=dsf Group=dsf UMask=0002 CapabilityBoundingSet=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH CAP_SYS_TIME AmbientCapabilities=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH CAP_SYS_TIME [Install] WantedBy=sysinit.target
@benecito It won't work that way, because DCS defaults to
. UseExecStart=/opt/dsf/bin/DuetControlServer -c /opt/dsf2/conf/config.json
instead. There is no need to copy the entire dsf directory but just
conf
andsd
in it, although it should work nevertheless. You'll need to edit the second duetwebserver service in a similar way, too. -
@chrishamm unfortunately it still does not work for me...
Also can't really find anything helpful in there.pi@CR-3D-Server:~ $ sudo systemctl start duetcontrolserver2 Job for duetcontrolserver2.service failed because the control process exited with error code. See "systemctl status duetcontrolserver2.service" and "journalctl -xe" for details. pi@CR-3D-Server:~ $ systemctl status duetcontrolserver2.service ā duetcontrolserver2.service - Duet Control Server Loaded: loaded (/lib/systemd/system/duetcontrolserver2.service; disabled; vendor preset: enabled) Active: activating (start) since Wed 2023-05-03 19:00:23 CEST; 1s ago Main PID: 14140 (DuetControlServ) Tasks: 9 (limit: 3597) CPU: 907ms CGroup: /system.slice/duetcontrolserver2.service āā14140 /opt/dsf/bin/DuetControlServer -c /opt/dsf/conf/config2.json May 03 19:00:23 CR-3D-Server systemd[1]: Starting Duet Control Server... May 03 19:00:24 CR-3D-Server DuetControlServer[14140]: Duet Control Server v3.4.1 May 03 19:00:24 CR-3D-Server DuetControlServer[14140]: Written by Christian Hammacher for Duet3D May 03 19:00:24 CR-3D-Server DuetControlServer[14140]: Licensed under the terms of the GNU Public License Version 3 May 03 19:00:24 CR-3D-Server DuetControlServer[14140]: [info] Settings loaded pi@CR-3D-Server:~ $ journalctl -xe May 03 19:00:57 CR-3D-Server systemd[1]: duetcontrolserver2.service: Failed with result 'exit-code'. āā Subject: Unit failed āā Defined-By: systemd āā Support: https://www.debian.org/support āā āā The unit duetcontrolserver2.service has entered the 'failed' state with result 'exit-code'. May 03 19:00:57 CR-3D-Server systemd[1]: Failed to start Duet Control Server. āā Subject: A start job for unit duetcontrolserver2.service has failed āā Defined-By: systemd āā Support: https://www.debian.org/support āā āā A start job for unit duetcontrolserver2.service has finished with a failure. āā āā The job identifier is 180062 and the job result is failed. May 03 19:00:57 CR-3D-Server systemd[1]: duetcontrolserver2.service: Scheduled restart job, restart counter is at 2629. āā Subject: Automatic restarting of a unit has been scheduled āā Defined-By: systemd āā Support: https://www.debian.org/support āā āā Automatic restarting of the unit duetcontrolserver2.service has been scheduled, as the result for āā the configured Restart= setting for the unit. May 03 19:00:57 CR-3D-Server systemd[1]: Stopped Duet Control Server. āā Subject: A stop job for unit duetcontrolserver2.service has finished āā Defined-By: systemd āā Support: https://www.debian.org/support āā āā A stop job for unit duetcontrolserver2.service has finished. āā āā The job identifier is 180128 and the job result is done. May 03 19:00:57 CR-3D-Server systemd[1]: Starting Duet Control Server... āā Subject: A start job for unit duetcontrolserver2.service has begun execution āā Defined-By: systemd āā Support: https://www.debian.org/support āā āā A start job for unit duetcontrolserver2.service has begun execution. āā āā The job identifier is 180128. lines 3564-3600/3600 (END)
this is my duetcontrolserver2.service:
[Unit] Description=Duet Control Server StartLimitIntervalSec=0 [Service] ExecStart=/opt/dsf/bin/DuetControlServer -c /opt/dsf/conf/config2.json TimeoutStopSec=15 Restart=always Type=notify User=dsf Group=dsf UMask=0002 CapabilityBoundingSet=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH CAP_SYS_TIME AmbientCapabilities=CAP_SYS_PTRACE CAP_DAC_READ_SEARCH CAP_SYS_TIME [Install] WantedBy=sysinit.target
@benecito That log doesn't show quite a lot. Please run
journalctl -u duetcontrolserver2 -ef
and post the bit that keeps repeating. It may be a good idea to share your second config file as well (config2.json). -
@chrishamm Sorry for the delay - was out of office yesterday.
I figured one part out: I messed up the SPI addresses in the config file
May 03 20:35:20 CR-3D-Server systemd[1]: duetcontrolserver2.service: Main process exited, code=exited, status=74/IOERR May 03 20:35:20 CR-3D-Server systemd[1]: duetcontrolserver2.service: Failed with result 'exit-code'. May 03 20:35:20 CR-3D-Server systemd[1]: Failed to start Duet Control Server. May 03 20:35:20 CR-3D-Server systemd[1]: duetcontrolserver2.service: Scheduled restart job, restart counter is at 6981. May 03 20:35:20 CR-3D-Server systemd[1]: Stopped Duet Control Server. May 03 20:35:20 CR-3D-Server systemd[1]: Starting Duet Control Server... May 03 20:35:20 CR-3D-Server DuetControlServer[26915]: Duet Control Server v3.4.1 May 03 20:35:20 CR-3D-Server DuetControlServer[26915]: Written by Christian Hammacher for Duet3D May 03 20:35:20 CR-3D-Server DuetControlServer[26915]: Licensed under the terms of the GNU Public License Version 3 May 03 20:35:21 CR-3D-Server DuetControlServer[26915]: [info] Settings loaded May 03 20:35:21 CR-3D-Server DuetControlServer[26915]: [info] Environment initialized May 03 20:35:21 CR-3D-Server DuetControlServer[26915]: [fatal] Failed to open IO device: Error 2. Can not open SPI device file '/dev/spidev4.0'. May 03 20:35:21 CR-3D-Server systemd[1]: duetcontrolserver2.service: Main process exited, code=exited, status=74/IOERR May 03 20:35:21 CR-3D-Server systemd[1]: duetcontrolserver2.service: Failed with result 'exit-code'. May 03 20:35:21 CR-3D-Server systemd[1]: Failed to start Duet Control Server. May 03 20:35:21 CR-3D-Server systemd[1]: duetcontrolserver2.service: Consumed 1.017s CPU time. May 03 20:35:21 CR-3D-Server systemd[1]: duetcontrolserver2.service: Scheduled restart job, restart counter is at 6982. May 03 20:35:21 CR-3D-Server systemd[1]: Stopped Duet Control Server. May 03 20:35:21 CR-3D-Server systemd[1]: duetcontrolserver2.service: Consumed 1.017s CPU time. May 03 20:35:21 CR-3D-Server systemd[1]: Starting Duet Control Server... May 03 20:35:21 CR-3D-Server DuetControlServer[26968]: Duet Control Server v3.4.1 May 03 20:35:21 CR-3D-Server DuetControlServer[26968]: Written by Christian Hammacher for Duet3D May 03 20:35:21 CR-3D-Server DuetControlServer[26968]: Licensed under the terms of the GNU Public License Version 3 May 03 20:35:22 CR-3D-Server DuetControlServer[26968]: [info] Settings loaded May 03 20:35:22 CR-3D-Server DuetControlServer[26968]: [info] Environment initialized May 03 20:35:22 CR-3D-Server DuetControlServer[26968]: [fatal] Failed to open IO device: Error 2. Can not open SPI device file '/dev/spidev4.0'.
but hat SPI 3 enabled.
Figured out one or two more things but am stuck at starting DWC now
[Unit] Description=Duet Web Server Wants=duetcontrolserver.service After=network.target duetcontrolserver.service [Service] WorkingDirectory=/opt/dsf2/sd/www ExecStart=/opt/dsf/bin/DuetWebServer --SocketPath /run/dsf/dcs2.sock --urls http://*:8080 TimeoutStopSec=15 Type=notify User=dsf Group=dsf CapabilityBoundingSet=CAP_NET_BIND_SERVICE AmbientCapabilities=CAP_NET_BIND_SERVICE [Install] WantedBy=multi-user.target
and the corresponding config2.json:
{ "AutoUpdateFirmware": true, "PluginSupport": true, "RootPluginSupport": false, "PluginsFilename": "/opt/dsf/conf/plugins.txt", "LogLevel": "info", "SocketDirectory": "/run/dsf", "SocketFile": "dcs2.sock", "StartErrorFile": "/run/dsf/dcs.err", "Backlog": 4, "SocketPollInterval": 2000, "BaseDirectory": "/opt/dsf/sd2", "PluginDirectory": "/opt/dsf/plugins", "NoTerminateOnReset": false, "HostUpdateInterval": 4000, "MaxMessageAge": 60, "SpiDevice": "/dev/spidev3.0", "SpiBufferSize": 8192, "SpiTransferMode": 0, "SpiFrequency": 8000000, "SpiConnectTimeout": 500, "SpiTransferTimeout": 500, "SpiConnectionTimeout": 4000, "MaxSpiRetries": 3, "GpioChipDevice": "/dev/gpiochip0", "TransferReadyPin": 27, "BufferedPrintCodes": 32, "BufferedMacroCodes": 16, "MaxBufferSpacePerChannel": 1536, "MaxCodeBufferSize": 256, "MaxMessageLength": 4096, "FirmwareComments": [
but also tried
[Unit] Description=Duet Web Server Wants=duetcontrolserver.service After=network.target duetcontrolserver.service [Service] WorkingDirectory=/opt/dsf2/sd/www ExecStart=/opt/dsf/bin/DuetWebServer -c /opt/dsf/conf/http2.json TimeoutStopSec=15 Type=notify User=dsf Group=dsf CapabilityBoundingSet=CAP_NET_BIND_SERVICE AmbientCapabilities=CAP_NET_BIND_SERVICE [Install] WantedBy=multi-user.target
with
{ "Logging": { "LogLevel": { "Default": "Information" } }, "Kestrel": { "Endpoints": { "Http": { "Url": "http://*:8080" } } }, "KeepAliveInterval": 30, "SessionTimeout": 8000, "ModelRetryDelay": 5000, "UseStaticFiles": true, "DefaultWebDirectory": "/opt/dsf/sd2/www", "MaxAge": 3600, "SocketPath": "/var/run/dsf/dcs2.sock", "WebSocketBufferSize": 8192 }
both fail with
pi@CR-3D-Server:~ $ systemctl status duetwebserver2.service ā duetwebserver2.service - Duet Web Server Loaded: loaded (/lib/systemd/system/duetwebserver2.service; disabled; vendor preset: enabled) Active: failed (Result: signal) since Fri 2023-05-05 10:29:11 CEST; 5s ago Process: 4310 ExecStart=/opt/dsf/bin/DuetWebServer -c /opt/dsf/conf/http2.json (code=killed, signal=ABRT) Main PID: 4310 (code=killed, signal=ABRT) CPU: 1.121s May 05 10:29:11 CR-3D-Server DuetWebServer[4310]: at Microsoft.AspNetCore.Hosting.GenericWebHostService.StartAsync(CancellationToken cancellationToken) May 05 10:29:11 CR-3D-Server DuetWebServer[4310]: at Microsoft.Extensions.Hosting.Internal.Host.StartAsync(CancellationToken cancellationToken) May 05 10:29:11 CR-3D-Server DuetWebServer[4310]: at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token) May 05 10:29:11 CR-3D-Server DuetWebServer[4310]: at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.RunAsync(IHost host, CancellationToken token) May 05 10:29:11 CR-3D-Server DuetWebServer[4310]: at Microsoft.Extensions.Hosting.HostingAbstractionsHostExtensions.Run(IHost host) May 05 10:29:11 CR-3D-Server DuetWebServer[4310]: at DuetWebServer.Program.Main(String[] args) in /home/christian/Duet3D/DuetSoftwareFramework/src/DuetWebServer/Program.cs:line 25 May 05 10:29:11 CR-3D-Server systemd[1]: duetwebserver2.service: Main process exited, code=killed, status=6/ABRT May 05 10:29:11 CR-3D-Server systemd[1]: duetwebserver2.service: Failed with result 'signal'. May 05 10:29:11 CR-3D-Server systemd[1]: Failed to start Duet Web Server. May 05 10:29:11 CR-3D-Server systemd[1]: duetwebserver2.service: Consumed 1.121s CPU time.
@benecito Are you certain that /dev/spidev4.0 exists? Perhaps you need /dev/spidev3.0 instead.
It looks like the
--urls
parameter doesn't work as documented, I just checked this. You need to change the second service file to something likeExecStart=ASPNETCORE_URLS="http://*:8080" /opt/dsf/bin/DuetWebServer --SocketPath /run/dsf/dcs2.sock
. Also, it looks like theKestrel
section in/opt/dsf/conf/http.json
overrides theASPNETCORE_URLS
setting. I suggest you remove that section in that file and changeduetwebserver.service
(preferably after copying it to/etc/systemd/system
first to avoid issues on upgrade) toExecStart=ASPNETCORE_URLS="http://*:80" /opt/dsf/bin/DuetWebServer
instead. -
@chrishamm this throws
May 05 11:20:26 CR-3D-Server systemd[1]: /lib/systemd/system/duetwebserver2.service:8: Neither a valid executable name nor an absolute path: ASPNETCORE_URLS=http://*:8080 May 05 11:20:26 CR-3D-Server systemd[1]: duetwebserver2.service: Unit configuration has fatal error, unit will not be started.
@benecito Sorry, systemd requires a different format for environment variables:
Environment=ASPNETCORE_URLS="http://*:8080" ExecStart=/opt/dsf/bin/DuetWebServer --SocketPath /run/dsf/dcs2.sock
@chrishamm
Hey,
finally managed to get to it again and without printers connected it is working right now.
Now just need to sort things in my head and make sure it also works fine with two machines actually printing at the same time.You mentioned I should copy some files to be safe in case of an update here:
@chrishamm said in Connecting multiple duets to one SBC:
Kestrel
instead.Can you please point out again which files you would recommend to copy where?
Over all I created:
/etc/systemd/system/duetcontrolserver2.service
/etc/systemd/system/duetwebserver2.service
/opt/dsf/sd2/ (as a duplicate of /opt/dsf/sd/)
/opt/dsf/conf/config2 .json (as a mostly duplicate of /opt/dsf/conf/config.json)and edited:
/etc/systemd/system/duetwebserver.serviceI assume the ones I edited but did not duplicate should be duplicated as well?
@benecito That structure sounds reasonable to me. The service files come from /usr/share/systemd/system AFAIR.
@chrishamm quick update (and question)
We finally finished the test setup with actual printers connected. Unfortunately on pretty much any print one of the looses it's connection with a "Waiting for transfer ready pin" message.
Right now the wires are about 25cm long but well away from any other cables. We're trying to rearrange the setup to be able to use shorter cables but not sure if that's actually the issue.Can it be somehow related to two SPI connections running at quite a bit of throughput on the same pi and thus some timing errors or so happening? In all cases the connection is back less than a second after.
Happy to hear any thoughts and maybe still get them running reliably! -
@chrishamm Any thoughts on this?
We now tried to run the Duets over SBC but print over USB. This went well so far but haven't run any long term tests.
Therefore to me it sounds like a timing issue related to the transfer ready pin with the increased throughput of printing over SBC.
Can you confirm if the USB print does not go trough the SBC connection back and forth?Still we would prefer to also print over SBC as we would have the whole ObjectModel available here.
