    DWC Temperature Chart y axis is 2000 degrees
    • RRinOzundefined
      RRinOz
      I recently changed a 'normal' 100k ohm thermistor to a Pt1000 in my Voron 2.4 Mosquito hot-end.
      This required that I change the config.g M308 command from
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138 to
      M308 S1 P"e0temp" Y"pt1000"
      As a result, the y axis of the DWC Temperature Chart has re-scaled to an unusable 2000 degrees.
      The hot-end heater M143 command is M143 H1 S280
      How can I re-scale the chart or have I simply committed a firmware sin?
        Is it actually reading 2000c? This may indicate a temp fault.
        Is it actually a Pt1000?
        What DWC and firmware versions?
          I see you already have a thread discussing this. Let's keep it there.
          https://forum.duet3d.com/topic/32271/extruder-jams/10
          • Phaedruxundefined Phaedrux locked this topic
