dual extruder
Bonjour a tous
J'aimerais brancher 2 extrudeurs orbiter en parallèle pour la faire tourner sur mon imprimante railcore . sachant que la carte mère de mon imprimante ne sait que un seul moteur est connecté , est ce qu'elle pourra supporter ? MerciHello to everyone
I would like to connect 2 orbiter extruders in parallel to run on my railcore printer. Knowing that the motherboard of my printer only knows that one motor is connected, will it be able to support it? Thank you -
@ronaldo why not connect them to 2 drivers and then map them both together in your config?
in fact I don't know how to configure 2 drivers
@ronaldo Are the two extruders feeding two separate filaments (so can be set up as two separate tools, or a mixing tool if you have a mixing nozzle), or is it to drive one filament, with one remote extruder and one direct extruder (eg for filament swapping)?
It is mechanically difficult to have two extruders pushing on one filament at the same time, because you would have to carefully match their speeds so they work together, rather than fight each other.
It may help if you explain the problem you are hoping to solve with this setup.
@ronaldo I see you have another thread with the same question, but with a bit more information; https://forum.duet3d.com/topic/32313/dual-extruder-orbiterv2
Please keep your questions to a single thread. I'm locking this one.
undefined droftarts locked this topic
