Connected motors with M584
is it possible to move motors independently of each other?
I have the motors connect like this in the config.g
M584 X0.2:0.3 Y0.0:0.1 Z0.4:0.5 E1.0
Move separate from each other withe a G1 command?
G1 X-3:5
@tkln no, you need to define each motor as a separate axis, and move that. So for the X axis, define an extra axis U which has the motor you want to move independently:
M584 X0.2:0.3 U0.3
Then you can move the U axis with G1 U5 (relative rather than anbsolute axis movements will probably work best). I’m not sure exactly what will happen when you send a subsequent G1 X… movement, though. It should keep the spacing you have set. You will also need to home the U axis first, or give it a position with G92.
RRF does not natively support a six axis delta, so it will rely on the slicer to send appropriate commands if using more than the standard 3 axes.
