    Wire guage for smart effector v2
    272
    • Uzi3Lundefined
      Uzi3L
      Re: Cant calibrate good first layer.
      Ok so i need to re-wire the smart effector from my mini 5+ wifi.
      Its the black 2x3 plug, the one that has that hotend heating wires need to be replaced the first owner put what looks like 14 or 12 guage wire on it so its very stiff, this has caused it to weaken the connection to the pin in the plug.
      im just wondering if i can use a wire, either the same type (braided) as the heater cartridge ones that come with the heater cartridges, or the same thickness but sillican coated?
      this printer is a Anycubic Predator, so distance is about 1mtr to 1.5 mtrs...
      • Phaedruxundefined Phaedrux moved this topic from General Discussion
        dc42 administrators @Uzi3L
        @Uzi3L what are the heater voltage and heater power? From those you can work out the heater current, which determines the minimum wire size.
        Uzi3Lundefined 2 Replies Last reply Reply Quote 0
        • Uzi3Lundefined
          Uzi3L @dc42
          @dc42 Hi thanks for reply.
          its 24v system,is that what you ment?
          the psu is 24v, the mini 5+ is set to 24v
          and i have 24v heater, bed and fans
          • Uzi3Lundefined
            Uzi3L @dc42
            @dc42 the heater cartridges are 24V50W
              @Uzi3L then that's a little over 2A heater current. Use an online table such as https://www.engineeringtoolbox.com/wire-gauges-d_419.html to find the minimum suitable wire gauge.
              • Uzi3Lundefined
                Uzi3L @dc42
                @dc42 said in Wire guage for smart effector v2:
                Than you, will do.
                • Uzi3Lundefined
                  Uzi3L @dc42
                  @dc42 So if i read that link right (not sure i did, lol but heres hoping.) the wires could be a 22 or 24 awg?
                    @Uzi3L 24awg might be marginal but 22awg or thicker should be OK.
                    Uzi3Lundefined 1 Reply Last reply Reply Quote 0
                    • Uzi3Lundefined
                      Uzi3L @dc42
                      ok thanks. i has some silicone coated 22awg. just got to find and buy some new connectors.
                      Cheers
