Deut3 Mini5+ unable to connect to wifi network
I am trying to connect to WiFi but having no luck.
I have managed to connect via serial tool
The board version is 1.0.2
I am using FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.4.0 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2022-03-15 18:59:17Her is what I get when I use
M552
WiFi module is connected to access point , IP address 255.255.255.255
okand this what i get for remembered networks
M587
Remembered networks:
TNCAPF2FD81 IP=192.168.1.14 GW=0.0.0.0 NM=0.0.0.0
) IP=0.41.2.0 GW=254.8.2.0 NM=0.41.2.0
okNot even close to my network even after i have set the SSID and Wireless password
perform an M552 S0
give network idlebut when I try to enable with M552 S1
I get
WiFi module is idle
WiFi reported error: network scan failed
WiFi module is idle
Error retrieving WiFi status message: SPI timeout
WiFi module is idle
Failed to change WiFi mode: SPI timeoutAny thoughts on what I mighbt be doing wrong?
use
M588 S"*"
to clear all currently saved SSIDsand then use
M587 S"networkname" P"password"
to re-add your SSIDIf that doesn't work, please try sending
M997 S1
to reflash the wifi module.Does your board have an external antenna?
Fantastic, clearing the the SSID worked nicely
Yes it has the external antenna. Thanks for your help
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
