    Simple Stepper Driver Test?
    • rdsmith24undefined
      rdsmith24
      Been working on a 3D printer for quite a while but have put it down several times....
      Now finally trying to finish but when I command the printer to move it sometimes moves very smoothly and sometimes makes a horrible noise. This is a CoreXY kinematic movement and
      I'm making movements via the Duet3D web interface.
      Even thought I thought I had bad cables and replaced them, I'm not so sure that in all the times trying to get the thing to move correctly that I might have not powered down the printer prior to unplugging stepper motor cables.
      Is there a way to test the steppers so I can see if they might need to be replaced? For information, this is a Duet2.
      Thanks
        You can disconnect the belts and move the motors individually to see if they move correctly. If they do, reconnect the belts and try these tests.
        https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_coreXY#testing-motor-movement
