    Delta semi-automatic calibration (M558 P0) along X axis instead of Z
    1.0k
    • roboduetundefined
      roboduet
      I'm using delta printer without z-probe. I used to use semi-automatic calibration many times before (using DWC, where popup with up-down controls for Z axis shown). Today I replaced hotend heater block and decided to re-calibrate printer, but I ran into an incomprehensible problem - instead of up/down (Z axis) controls DWC shows me controls for X axis:
      [[language]]
      Adjust height until the nozzle just touches the bed, then press OK
      Use the following controls to adjust X:
      Seems like I should change something in configs after upgrading to firmware version 1.19, but I don't understand where I'm wrong.
      Current firmware version is:
      [[language]]
      Firmware Name: 	RepRapFirmware for Duet WiFi
      Firmware Electronics: 	Duet WiFi 1.0
      Firmware Version: 	1.19 (2017-08-14)
      WiFi Server Version: 	1.19
      Web Interface Version: 	1.19
      bed.g:
      [[language]]
      M561						; clear any bed transform, otherwise homing may be at the wrong height
      G31 X0 Y0					; don't want any probe offset for this
      G30 P0 X0 Y75 Z-99999
      G30 P1 X64.95 Y37.5 Z-99999
      G30 P2 X64.95 Y-37.5 Z-99999
      G30 P3 X0 Y-75 Z-99999
      G30 P4 X-64.95 Y-37.5 Z-99999
      G30 P5 X-64.95 Y37.5 Z-99999
      G30 P6 X0 Y0 Z-99999 S6
      G1 X0 Y0 Z150 F4000			; get the head out of the way of the bed
      config.g:
      [[language]]
      M111 S0                                 ; Debug off
      M550 PMiniKossel                        ; Machine name and Netbios name (can be anything you like)
      M552 S1                                 ; Enable WiFi
      M551 Preprap                            ; Machine password (used for FTP)
      M555 P2                                 ; Set output to look like Marlin
      G21                                     ; Work in millimetres
      G90                                     ; Send absolute coordinates...
      M83                                     ; ...but relative extruder moves
      M569 P0 S1                              ; X
      M569 P1 S1                              ; Y
      M569 P2 S1                              ; Z
      M569 P3 S0                              ; E
      M574 X2 Y2 Z2 S1                        ; set endstop configuration (all endstops at high end, active high)
      M92 X100 Y100 Z100 E450                 ; Set axis steps/mm
      M201 X3000 Y3000 Z3000 E3000            ; Accelerations (mm/s^2)
      M203 X12000 Y12000 Z12000 E4200         ; Maximum speeds (mm/min)
      M350 X16 Y16 Z16 E16 I1                 ; Set 16x microstepping with interpolation
      M566 X600 Y600 Z600 E600                ; Maximum instant speed changes mm/minute
      M906 X1500 Y1500 Z1500 E1000 I60        ; Set motor currents (mA)
      M665 R105.70 L214.35 H239.36 B85.00 X-0.48 Y-0.80 Z0.00
      M666 X1.51 Y-1.03 Z-0.48
      M563 P0 D0 H1                           ; Define tool 0
      G10 P0 S0 R0                            ; Set tool 0 operating and standby temperatures
      M106 P1 T50 H1                          ; Thermostatic fan
      M558 P0                                 ; No Z probe present
      M556 S100 X0 Y0 Z0                      ; Axis compensation here
      M208 S1 Z-0.3                           ; set minimum Z
      M106 P0 L0                              ; Minimum fan speed
      M143 H0 S130                            ; Maximum bed temperature
      M143 H1 S270                            ; Maximum hotend temperature
      M305 P0 T100000 B4388 R4700 H0 L0       ; Put your own H and/or L values here to set the bed thermistor ADC correction
      M305 P1 T100000 B4725 R4700 H0 L0 C7.060000e-8
      M307 H0 A250.8 C426.6 D7.7 B0           ; Heater 0 model: gain 250.8, time constant 426.6, dead time 7.7, max PWM 1.00, in use: yes, mode: PID
      M307 H1 A681.8 C179.0 D7.0 S1.00 B0     ; Heater 1 model: gain 681.8, time constant 179.0, dead time 7.0, max PWM 1.00, mode: PID
      M570 H0 T25                             ; Permitted temperature excursion from the setpoint for this heater
      M570 H1 T25                             ; Permitted temperature excursion from the setpoint for this heater
      M501                                    ; load sys/config-override.g
      T0                                      ; select first hot end
        I think you are using incompatible versions of DWC and RRF. Use a more recent version of RRF or an older version of DWC.
        • roboduetundefined
          roboduet
          It seems for me that I'm using latest available release version:
          https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi/Stable
          But anyway I will try to re-upload & update, thank you.
          • roboduetundefined
            roboduet
            Upgrading to latest stable firmware files that available on github (1.19) did not fix this issue.
            But latest edge version is working OK (1.20beta10). I hope beta10 stable enough for production printing 🙂
            Thank you!
              Latest stable firmware uis 1.19,2, not 1.19. See https://github.com/dc42/RepRapFirmware/releases.
              There have been reports of some layer shift issues with 1.20beta10. I haven't been able to reproduce these yet.
              • roboduetundefined
                roboduet
                Oh… thank you again. I thought that latest version is available here: https://github.com/dc42/RepRapFirmware/tree/dev/Release/Duet-WiFi/Stable
                I did not think of looking at the releases page at github at https://github.com/dc42/RepRapFirmware/releases
                I will try to downgrade back to 1.19.2.
                  Yes, I need to remove the "Stable" folders, because stable versions are now released using the Github Release mechanism.
                  • roboduetundefined
                    roboduet
                    @dc42:
                    By the way, this was useful for those who know about [c]git pull[/c] command. I'm one of those who used this command - just two words to get latest available firmware, readmes and source code together. But I agree that releases page is more appropriate place for binary files.
