    klicky probe setup help
    Third-party add-ons
    • frnknstn518
      frnknstn518 last edited by frnknstn518
      I want to see if i can get help properly installing my klicky. i have it installed already on voron 350
      its set at X 52 Y350
      Voron 2.4
      Duet3 6hc
      duet web control 3.4.5
      rrf
      frnknstn518 2 Replies Last reply Reply Quote 0
      • frnknstn518
        frnknstn518 @frnknstn518 last edited by
        @frnknstn518 i thought i was suppose to set this up as type 5 but its on expansion board and i get an error that says it has to be 8 or 9. i thought the switches were 5
        M208 X0 Y0 Z0 S1                             ; set axis minima
        M208 X350 Y350 Z350 S0                       ; set axis maxima
        ; endstops
        M574 X2 S1 P"121.io0.in"                     ; X min active high endstop switch
        M574 Y2 S1 P"io5.in"                         ; Y min active high endstop switch
        M574 Z1 S1 P"io6.in"                         ; Z min active low endstop switch
        M558 P5 C"!121.io2.in" I1 A5 H1.45 R0.1 F65 T7000 A5 S0.01 B1
          dc42 administrators @frnknstn518 last edited by
          @frnknstn518 use type 8 for a switch connected to an expansion board.
          frnknstn518 1 Reply Last reply Reply Quote 0
          • frnknstn518
            frnknstn518 @dc42 last edited by
            @dc42 just checking in. I checked my wirng to make sure I was g-g v-v and s-s. froom the 1lc to the euclid probe. I am assuming its my config.
            ; Z-Probe (Euclid)
            M558 P8 X0 Y0 Z1 H3F200 T5000
            G31 P500 X 11.0 Y0.5 Z1.65
            Is this suppose to be K8 and P5 for the NC switch?
            • frnknstn518
              @frnknstn518 ; Z-Probe (Euclid)
              M558 P8 C"!121.io2.in" X0 Y0 Z1 H3F200 T5000
              I added the pin back in but i am still wrong somewhere
              • frnknstn518
                @frnknstn518 So this is where im at. I have Euclid probe and i cant seem to get it to trigger. i checked the wiring, and when connected lights are on. When i press the switch it goes off. How do i set this to work with the probe display in DWC. Probe just stays at zero. Here are some of my g files
                ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
                ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sat May 13 2023 19:27:15 GMT-0400 (Eastern Daylight Time)
                M575 P1 S1 B57600                            ; enable support for PanelDue
                G90                                          ; send absolute coordinates...
                M83                                          ; ...but relative extruder moves
                M550 P"Duet 3"                               ; set printer name
                M669 K1                                      ; select CoreXY mode
                G4 S2                                        ; Wait for expansion boards to start
                ;M552 S1                                      ;Enable network
                ;M586 P0 S1                                   ;Enable HTTP
                ;M586 P1 S0                                   ;Disable FTP
                ;M586 P2 S0                                   ;Disable Telnet
                ; ----Z Drive Map----
                ,    | 0.2 | 0.3 |
                ,    | 0.1 | 0.4 |
                ,        FRONT
                ; Looking at the printer from the top
                ; Drive directions
                M569 P1.0 S1                                 ; physical drive 1.1 goes forwards Y DRIVE
                M569 P1.1 S1                                 ; physical drive 1.0 goes forwards X DRIVE
                M569 P0.1 S1                                 ; physical drive 0.1 goes forwards FL Z DRIVE
                M569 P0.2 S0                                 ; physical drive 0.2 goes forwards RL Z DRIVE
                M569 P0.3 S1                                 ; physical drive 0.3 goes forwards RR Z DRIVE
                M569 P0.4 S0                                 ; physical drive 0.4 goes forwards RF Z DRIVE
                M569 P0121.0 S0                              ; physical drive 0.0 goes forwards EXTRUDER DRIVE
                ; Motor mapping and steps per mm
                M584 X1.1 Y1.0 Z0.1:0.2:0.3:0.4 E121.0       ; set drive mapping
                M84 S3600                                    ; motor idle timeout
                M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
                M92 X160.00 Y160.00 Z400.00 E690.00            ; set steps per mm
                ; Drive currents and speeds
                M566 X900.00 Y900.00 Z60.00 E300.00          ; set maximum instantaneous speed changes (mm/min)
                M203 X6000.00 Y6000.00 Z180.00 E7200         ; set maximum speeds (mm/min)
                M201 X500.00 Y500.00 Z20.00 E3000.00         ; set accelerations (mm/s^2)
                M906 X1600 Y1600 Z1200 E500 I70              ; set motor currents (mA) and motor idle factor in per cent
                M84 S120                                     ; Set idle timeout
                ; endstops
                ; Z-Probe (Euclid)
                M558 P8 C"!121.io2.in" X0 Y0 Z1 H3F200 T5000                  ; K is probe type, P5 for NC switch, C input pin, H is dive height, F is probing speed, T is travel speed, A is number of probes
                ; Bed leveling params
                M671 X-65:-65:365:365 Y0:395:395:0 S20                         ; Define Z belts locations (Front_Left, Back_Left, Back_Right, Front_Right)
                M557 X30:270 Y30:270 P5                                        ; Define bed mesh grid (inductive probe, positions include the Y offset!)
                M308 S0 P"temp0" Y"thermistor" T100000 B3950 A"BedTemp"        ; configure sensor 0 as thermistor on pin temp0
                M950 H0 C"out1" T0 Q10                                         ; create bed heater output on out0 and map it to sensor 0
                M307 H0 R4.843 K1.017:0.000 D1.55 E1.35 S1.00 B0               ; disable bang-bang mode for the bed heater and set PWM limit
                M140 H0                                                        ; map heated bed to heater 0
                M143 H0 S120                                                   ; set temperature limit for heater 0 to 120C
                M308 S1 P"121.temp1" Y"thermistor" T100000 B4725 A"NozzleTemp" ; configure sensor 1 as thermistor on pin temp1
                M950 H1 C"121.out0" T1                                         ; create nozzle heater output on 121.out0 and map it to sensor 1
                M307 H1 R5.006 K0.971:0.000 D1.64 E1.35 S1.00 B0 V23.9                             ; disable bang-bang mode for heater  and set PWM limit
                M143 H1 S280                                                   ; set temperature limit for heater 1 to 280C
                M950 F0 C"121.out1" Q500                                       ; create fan 0 on pin 121.out1 and set its frequency
                M106 P0 S0 H-1                                                 ; set fan 0 value. Thermostatic control is turned off
                M950 F1 C"121.out2" Q500                                       ; create fan 1 on pin 121.out2 and set its frequency
                M106 P1 S1 H1 T45                                              ; set fan 1 value. Thermostatic control is turned on
                M563 P0 D0 H1                                                  ; define tool 0
                G10 P0 X0 Y0                                                   ; set tool 0 axis offsets
                G10 P0 R0 S0                                                   ; set initial tool 0 active and standby temperatures to 0C
                T0
                ; Euclid Probe homez.g Example Macro
                ; RRF3.X Firmware Example
                ; saveas system/homez.g
                ; comments and echo statements throughout are provided for convenience
                if !move.axes[0].homed || !move.axes[1].homed     ; If the printer hasn't been homed, home it
                   M98 P"0:/sys/homexy.g"
                M561                                            ; clear any bed transform
                M290 S0 R0                                      ; clear baby steps
                G91                                             ; relative positioning
                G1 H2 Z6 F6000                                  ; lift Z relative to current position to clear any obstructions
                M400
                G90                                             ; absolute positioning
                ; echo "Call deployprobe.g macro"
                M401 P0                                         ; This runs macro file deployprobe
                ; echo "Return"
                G1 X175 Y175 F9000                            ; go to center of bed in advance of probe that point
                M400
                ; echo "G30 Command"
                G30                                             ; Probe the bed at the current XY position. When the probe is triggered,
        ; adjust the Z offset of the current tool to make the current position Z=0.
                G1 Z10                                          ; raise Z=10
                M400
                G4 P500
                ; echo "Call bed4point.g macro"
                M98 P"0:/sys/bed4point.g"                       ; tram bed
                ; echo "Return"
                G1 X145 Y162.5 F9000                              ; go back to the first probe point and reprobe 0 in case it moved
                G30
                ; echo "Call retractprobe.g macro"
                M402 P0                                         ; retract probe
                ; echo "Return"
                G1 Z10 F600                                     ; lift Z relative to current position
                M564 S1 H0                                      ; reset the bounding limits
                ; G1 X150 Y0 F9000                              ; move carriage to center front
                ; Euclid Probe Fixed Dock Retract Probe Macro M402
                ; RRF3.x Firmware Example
                ; saveas system/retractprobe.g
                echo "running retractprobe.g macro"
                ; uncomment next line to echo the probe deploy state
                ; echo "Object Model Deployuser token =" ^sensors.probes[0].deployedByUser
                ; Dock side position is at X0 Y30
                ; Docked probe postion is at X0 Y0
                ; Dock entry/exit point is at X65 Y0 Z10 **USER MUST ESTABLISH EXIT HEIGHT Z
                M564 S0                       ; allow beyond limit axis to print area
                if sensors.probes[0].value[0]!= 0
                    echo "Probe Value =" ^sensors.probes[0].value[0]
                    abort "retractprobe: Probe not currently picked up!"
                ; echo "pass first logic loop"
                ; uncomment next line to echo the probe value and probe deploy state
                ; echo "Probe Value =" ^sensors.probes[0].value[0]
                G1 X150 Y350 Z10 F3000         ; move to ready position
                G1 X100 Y350 Z10F 3000           ; move to the entry position for the dock
                G1 X50 Y350 Z10 F300             ; move into the dock position
                G4 P250                       ; pause 250 usecs
                G1 X50 Y300 Z10 F6000           ; move to the side adjacent to the dock swiping the probe off
                M400
                G1 X175.0 Y175.0 Z10 F6000        ; move to the center of the bed
                M400
                M564 S1                       ; limit axis to print area
                ; echo "complete movement commands"
                if sensors.probes[0].value[0]!= 1000
                    abort "retractprobe.g Probe not correctly dropped off in dock!"
                M564 H1 S1                    ; Restrict movement to within axes boundaries (for normal Y movement)
                echo "Macro retractprobe.g complete"
                ; Euclid Probe Moving Z Dock Deploy Probe Macro M401
                ; saveas system/deployprobe.g
                ; echo "Running deployprobe.g"
                ; if !move.axes[0].homed || !move.axes[1].homed     ; If the printer hasn't been homed, home it
                ;    M98 P"0:/sys/homexy.g"
                M564 H0 S0                    ; Allow movement BEYOND axes boundaries (for Y to reach probe dock)
                echo "Lift Z in advance of deploy"
                G1 H2 Z15 F3000               ; move Z 15 for clearance above dock.
                ;                             ; need to figure out some safety check on this
                if sensors.probes[0].value[0]!=1000    ; if sensor is value other than 1000 do this
                  ; echo "deployuser token = " ^sensors.probes[0].deployedByUser
                  ; echo "Probe State = " ^sensors.probes[0].value[0]
                  abort "deployprobe start value Probe already picked up.  Manually return probe to the dock"
                ; if we're here we know it's because the above is true which I assume is because you have an NC switch as a probe.
                ; echo "Passed first logic test to deploy probe"
                ; Docked probe position is at X0 Y0
                ; Dock exit point is at X65 Y0
                G1 X50 Y300 F6000             ; move adjacent to probe dock location
                M400                          ; wait for moves to finish
                G91                           ; relative coordinates
                G1 Z-15                       ; recover the z clearance
                ; echo "Probe Pickup while loop running"
                ; echo "Object Model Deployuser token (before while loop) = " ^sensors.probes[0].deployedByUser
                G90                           ; absolute coordinates
                G1 X50 Y350 F3000                ; move over dock
                G4 S1                         ; pause for pickup
                while sensors.probes[0].value[0]=1000
                  G1 Z-0.25 F600              ; jog bed up 0.25mm change to suit user preference
                  M400                        ; wait for moves to finish, allow polling interval to trigger and check probe value
                  ; echo sensors.probes[0].value[0]
                  ; echo iterations
                  if iterations=100           ; if probe has moved 100*step increment without pickup detection, exit loop
                     break
                G4 P250                       ; pause 1/4 seconds
                G91
                G1 Z-0.5 F600                  ; move probe down in the dock to clear the roof. adjust as needed
                G90
                G1 X100 Y350 F1200               ; slide probe out of dock - slowly example exit is to the +X direction
                G1 Z10                        ; move bed to clear probe from build surface
                M400
                G4 P250                       ; pause 1 seconds
                echo "Probe Pickup while loop complete"
                ; uncomment to echo the probe deploy state
                ; echo "Object Model Deployuser token (after while loop) = " ^sensors.probes[0].deployedByUser
                G1 X175 Y175 F3000            ; move to center of bed for ready position
                if sensors.probes[0].value[0]!=0
                  echo "Object Model Deployuser token (in abort if section)= " ^sensors.probes[0].deployedByUser
                  abort "Deployprobe endvalue not 0 Probe not picked up!  Deploy cancelled."
                echo "Macro deployprobe.g complete"
                  dc42 administrators @frnknstn518 last edited by dc42
                  @frnknstn518 said in klicky probe setup help:
                  Which lights are on when the probe is connected, and go off when you press the switch?
                  What Z probe values does DWC report, when the switch is pressed and when it is not pressed?
                  Please send M558 with no parameters to check whether the configuration you provided was accepted.
                  The comment says it is a NC switch, however you have used a ! at the start of the pin name, which would be correct for a NO switch.
