    3.5.0 beta 3 minimum PWM frequency
    Beta Firmware
    • PascalMundefined
      PascalM
      I upgraded my Duet 3 6HC from 3.5.0 beta 2 to beta 3 and found out that my bed heater turned on permamently.
      I have configured the bed heater output to 1Hz PWM and up until now it worked flawlessly. The output controls a 230V solid state relay that switches on zero-crossings of the 50Hz mains supply, therefore I want a slow enough PWM frequency to have reasonable resolution of bed heater power.
      I tested 2Hz and the problem remains, at 3Hz the output seems to be working again as intended.
      Therefore, as a workaround, 3Hz is ok, but my effective PWM resolution is really bad.
      Fortunately, at 60°C bed temperature, its still acurate enough to have the bed temperature rock solid at 60.0°C even without fluctuations to 60.1 or 59.9. Might get worse at lower temperatures.
      I guess it is a result of the changed PWM resolution in beta 3
      ("[Duet 3 MB6HC] [Duet 3 MB6XD] [Duet 2] [Duet Maestro] PWM resolution when using outputs connected to the PWM peripheral is increased")
      Is it possible to have an option to enable/disable the higher PWM precision, or automatically use reduced resolution PWM, when requested PWM is too low?
      At least, for safety, I would advise to disable the output and give an error if a too low frequency is requested. I protected my bed with a thermal switch and a thermal fuse, but it might not be on every printer.
      My configuration of the heater:
      In sys config.g
      M308 S0 P"temp0" Y"thermistor" T100000 B4583 C1.022833e-7
      M950 H0 C"out0" T0 Q1
      M307 H0 B0 S1.00
      M140 H0
      M143 H0 S130
      Override with the tuning at 60°C for the filament I tested with, in filaments config.g
      M307 H0 R0.15 K0.161:0.000 D9.31 E1.35 S1.00 B0
      dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
        dc42 administrators @PascalM
        @PascalM thanks for reporting this. I'll try to fix it in 3.5beta4.
        https://github.com/Duet3D/RepRapFirmware/issues/854
        dc42 created this issue in Duet3D/RepRapFirmware
        closed New PWM code in RRF 3.5 doesn't allow PWM frequencies as low as 3.4 did #854
        • prestoundefined presto referenced this topic
        • T3P3Tonyundefined
          T3P3Tony administrators @PascalM
          @PascalM please can you test to see if this issue is resolved with the pre release here:
          https://www.dropbox.com/sh/in0t2j68ic66oa8/AADv_6WzRy07H6MhBOrkDt23a?dl=0
          www.duet3d.com
          PascalMundefined 1 Reply Last reply Reply Quote 0
          • PascalMundefined
            PascalM @T3P3Tony
            @T3P3Tony I testet with the pre release. It is working at 1Hz again.
              @PascalM thanks for confirming.
