    1st multi colour thingy
    Example setups and prints
    1.4k
    • deckingmanundefined
      deckingman
      Getting my new printer dialled in. Here are some pics
      https://drive.google.com/open?id=0B_MwtHtQR_ZvMjBDcUdRNmt2NTA
      It's not my design. It's this http://www.thingiverse.com/thing:126567. I used Slic3r to scale it up overall by 200% then scaled the height about another 25%. Height is about 320mm, and it fits in a cylinder about 220mm diameter. Sliced at 0.3mm layer height, 0.5mm nozzle, 3 bottom layers, 4 perimeters, no infill or top layers. Translucent PLA, Red, Yellow and "Clear" (well "natural" anyway). Diamond hot end. Wrote a python script to post process the g-Code file. Basically, it inserts an M567 after every 5th G1 Z to change the mixing ratio so that it changes from 100% Red, though Yellow to clear. Cold bed, blue tape. No print cooling. Perimeter speed 80mm/s, outside perimeters 75%. Total print time around 17 hrs.
      • Dougal1957undefined
        Dougal1957
        That's mighty impressive print there,
        Doug
          deckingman
          @Dougal1957:
          Doug
          Thank you kind sir. Still getting the machine dialled in. There are slight defects on layer change to address. I need to refine retraction which'll probably fix it.
          • T3P3Tonyundefined
            T3P3Tony administrators
            Fantastic Ian! Is that using the external driver I sent you?
            www.duet3d.com
              deckingman
              @T3P3Tony:
              Sure is Tony. I had to tweak the current down from how you supplied it as I have very small 0.4Amp steppers on the E3d Titans but other than, it's working fine (at least good enough to start dialling the machine in). I was just about to send you an email - check your inbox in about half an hour. Cheers. Ian
