    Reboots/resets randomly - RRF 3.5.0-b4
    Beta Firmware
    12
    112
    7.8k
    • Exerqtorundefined
      Exerqtor
      EDIT 21th October 2023:
      The reboot/crash/reset issues carry on to 3.5.0.rc.1, though they're seemingly less often, updated thread title.
      EDIT 10th June 2023:
      The extruder issues from the original post was resolved with the updated binaries @dc42 supplied.
      After that RRF 3.5.0-beta4 got released and I updated, but the restart/reset issues persist over to RRF beta4, hence the name change of the post.
      (Original title: "Extruder stops extruding (again) & reboots randomly - RRF 3.5b3+")
      So i've finally gotten my printer up and running again after my Revo heater core shit the bed.
      Now i'm doing the first prints to tune in the new High flow goodness, and guess what the damned extruder stopped again after an object finished a layer.
      And not only that, i let the print finish and it didn't run stop.g!? I just halted the extruder dead in it's tracks and skipped a bunch of steps, didn't even power down the heater etc. or report that a print finished in either DWC or PD console.
      PD even had the same status screen like it was stil printing, so i pushed pause to see what happened, then it went to parking position (X/Y0) which should be something like 200mm down and away from where the printhead was when i pushed pause, BUT it only moved like 60mm lol. So when i finally pushed Cancel in paused state it ofcourse rammed the X/Y max because it wanted to move 355mm in each direction.
      I managed to snag M122's from both the mobo and toolboard while printing though:
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.3+ (2023-05-09 10:59:17) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL
      Used output buffers: 24 of 40 (40 max)
      Static ram: 101720
      Dynamic ram: 130064 of which 36 recycled
      Never used RAM 5812, free system stack 122 words
      Tasks: NETWORK(nWait,19.2%,193) HEAT(nWait,0.0%,327) Move(nWait,0.7%,238) CanReceiv(nWait,0.0%,772) CanSender(nWait,0.0%,327) CanClock(delaying,0.0%,341) TMC(nWait,1.2%,74) MAIN(running,77.5%,314) IDLE(ready,0.5%,29) AIN(delaying,0.8%,266), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 01:05:20 ago, cause: software
      Last software reset at 2023-05-26 19:44, reason: User, Gcodes spinning, available RAM 13816, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 3920887, completed 3920885, timed out 0, errs 0
      MCU temperature: min 36.9, current 45.8, max 46.0
      Supply voltage: min 23.1, current 23.9, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 198/42, heap memory allocated/used/recyclable 2048/1024/328, gc cycles 177
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 165, reads 28699, writes 33, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 165, reads 28699, writes 33, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 117, reads 28710, writes 22, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 117, reads 28710, writes 22, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 116, reads 28711, writes 22, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 28722, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 28722, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Date/time: 2023-05-26 20:49:55
      Slowest loop: 233.58ms; fastest: 0.08ms
      === Storage ===
      Free file entries: 16
      SD card longest read time 9.5ms, write time 14.3ms, max retries 0
      DMs created 83, segments created 32, maxWait 2562565ms, bed compensation in use: mesh, comp offset 0.000
      next step interrupt due in 323 ticks, enabled
      === DDARing 0 ===
      Scheduled moves 16116, completed 16083, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state 3
      === DDARing 1 ===
      Heater 0 is on, I-accum = 0.4
      Heater 1 is on, I-accum = 0.0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 3
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is doing "G4 S1        " in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0, sync state 1
      Queue2 is idle in state(s) 0
      Q0 segments left 1, axes/extruders owned 0x0000807
      Code queue 0 is empty
      Code queue 1 is empty
      === CAN ===
      Messages queued 49901, received 78656, lost 0, boc 0
      Longest wait 5ms for reply type 6024, peak Tx sync delay 275, free buffers 18 (min 8), ts 19605/19604/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 73.37ms; fastest: 0.00ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      = WiFi =
      Network state is active
      Firmware version 2.1beta4
      MAC address bc:ff:4d:e6:b1:62
      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42828
      WiFi IP address 192.168.10.50
      Signal strength -51dBm, channel 1, mode 802.11n, reconnections 0
      Clock register 00002001
      Diagnostics for board 121:
      Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-beta.3+ (2023-05-09 13:40:30)
      Bootloader ID: SAMC21 bootloader version 2.4 (2021-12-10)
      All averaging filters OK
      Never used RAM 4208, free system stack 38 words
      Tasks: Move(nWait,0.4%,93) HEAT(nWait,0.6%,57) CanAsync(nWait,0.0%,57) CanRecv(nWait,0.1%,74) CanClock(nWait,0.0%,67) ACCEL(nWait,0.0%,53) TMC(delaying,3.1%,57) MAIN(running,90.9%,346) IDLE(ready,0.0%,27) AIN(delaying,4.9%,142), total 100.0%
      Last reset 01:05:07 ago, cause: software
      Last software reset data not available
      Driver 0: pos 0, 568.8 steps/mm,standstill, SG min 2, read errors 0, write errors 0, ifcnt 42, reads 6258, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
      Moves scheduled 8067, completed 8067, in progress 0, hiccups 0, step errors 0, maxPrep 908, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter -2/7, peak Rx sync delay 202, resyncs 0/0, no timer interrupt scheduled
      VIN voltage: min 24.3, current 24.4, max 24.5
      MCU temperature: min 44.5C, current 72.8C, max 72.8C
      Last sensors broadcast 0x00000012 found 2 3 ticks ago, 0 ordering errs, loop time 1
      CAN messages queued 282, send timeouts 0, received 234, lost 0, free buffers 37, min 37, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 311, adv 35748/74627
      Accelerometer: LIS3DH, status: 00
      I2C bus errors 0, naks 0, other errors 0
      For reference here is the print file.
      I'm trying out OrcaSlicer for the first time too, so it might be that it's not exporting stuff like it should but it looks right at least?
      Standalone Duet 3 Mini / 3.5b3+, 1LC v1.2 / 3.5b3, 5" PD v3 / 3.5rc6
      Exerqtorundefined 1 Reply Last reply Reply Quote 1
      • Exerqtorundefined
        Exerqtor @Exerqtor
        @Exerqtor
        I just tried to slice another file, this time in PrusaSlicer and now it won't run the extruder AT ALL.
        Unless if i pause the print, and manually extrude, i'm lost as to what can be the reason for this.
        The new print file.
        EDIT:
        Fully restarted the printer (power toggle), and now the "new file" completed without issues.
        Can the fact that i updated the PD firmware have something to do with the issue? Because i didn't do any other changes than that between the last good print and the issues came up 🤷‍♂️
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @Exerqtor
          Tried running the flow calibration again, and it still stops. So something is still "broken" with RRF 3.5b3+.
          Here is the M122's while the print is going but extruder standing still / going backwards:
          M122
          Used output buffers: 1 of 40 (40 max)
          Static ram: 101720
          Dynamic ram: 130888 of which 24 recycled
          Never used RAM 5000, free system stack 134 words
          Tasks: NETWORK(ready,106.7%,193) HEAT(nWait,0.9%,329) Move(nWait,1.6%,270) CanReceiv(nWait,1.7%,772) CanSender(nWait,0.0%,327) CanClock(delaying,0.3%,341) TMC(nWait,42.1%,74) MAIN(running,480.3%,314) IDLE(ready,14.8%,29) AIN(delaying,29.1%,266), total 677.4%
          Last reset 09:49:11 ago, cause: software
          Last software reset at 2023-05-27 12:27, reason: HardFault imprec, Gcodes spinning, available RAM 5856, slot 1
          Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011b98 Task NETW Freestk 482 ok
          Stack: 2002be78 00000000 0000000a 0000019d 20032c8a 0002f6d1 00034064 810f0000 0002f6bd 00000000 00000000 00000000 20030a84 00000800 2002be60 2002be60 00000002 2002bd05 20018250 2001e438 0002f857 00000000 00000000 00000000 20011c48 00000014 00000000
          Error status: 0x04
          Aux0 errors 0,0,0
          MCU revision 3, ADC conversions started 35351654, completed 35351653, timed out 0, errs 0
          MCU temperature: min 35.5, current 45.6, max 46.0
          Supply voltage: min 23.1, current 23.8, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 198/41, heap memory allocated/used/recyclable 2048/1256/568, gc cycles 1401
          Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 67, reads 2458, writes 33, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 67, reads 2457, writes 33, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 45, reads 2468, writes 22, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 45, reads 2468, writes 22, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: ok, SG min 0, read errors 0, write errors 1, ifcnt 45, reads 2469, writes 22, timeouts 0, DMA errors 0, CC errors 0
          Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 2480, writes 10, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x41
          Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 2480, writes 10, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2023-05-27 22:16:47
          Slowest loop: 235.21ms; fastest: 0.08ms
          === Storage ===
          SD card longest read time 8.9ms, write time 12.4ms, max retries 0
          DMs created 83, segments created 32, maxWait 34476115ms, bed compensation in use: mesh, comp offset 0.000
          next step interrupt due in 15 ticks, enabled
          === DDARing 0 ===
          Scheduled moves 10011, completed 9988, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
          === DDARing 1 ===
          Heater 0 is on, I-accum = 0.3
          File is doing "G1 X232.625 Y210.177 E1.87917" in state(s) 0
          Q0 segments left 0, axes/extruders owned 0x0000807
          === CAN ===
          Messages queued 327074, received 707304, lost 0, boc 0
          Longest wait 4ms for reply type 6024, peak Tx sync delay 276, free buffers 18 (min 8), ts 176758/176757/0
          === Network ===
          Slowest loop: 213.59ms; fastest: 0.00ms
          = WiFi =
          Module reset reason: Power up, Vcc 3.40, flash size 2097152, free heap 43000
          Signal strength -54dBm, channel 1, mode 802.11n, reconnections 0
          	M122 B121
          Tasks: Move(nWait,1.9%,93) HEAT(nWait,18.4%,57) CanAsync(nWait,0.0%,48) CanRecv(nWait,0.8%,74) CanClock(nWait,0.7%,67) ACCEL(nWait,0.0%,53) TMC(delaying,115.8%,57) MAIN(running,38.4%,344) IDLE(ready,0.0%,27) AIN(delaying,185.2%,142), total 361.3%
          Last reset 22:52:44 ago, cause: power up
          Driver 0: pos 0, 568.8 steps/mm,standstill, SG min 0, read errors 1, write errors 0, ifcnt 18, reads 6905, writes 18, timeouts 7, DMA errors 0, CC errors 0, failedOp 0x6a, steps req 0 done 11548228
          Moves scheduled 134370, completed 134370, in progress 0, hiccups 2783, step errors 0, maxPrep 1186, maxOverdue 37230, maxInc 4375, mcErrs 0, gcmErrs 0
          Peak sync jitter -5/11, peak Rx sync delay 269, resyncs 0/1, no timer interrupt scheduled
          VIN voltage: min 23.3, current 24.4, max 24.7
          MCU temperature: min 41.1C, current 70.4C, max 80.9C
          Last sensors broadcast 0x00000012 found 2 52 ticks ago, 0 ordering errs, loop time 1
          CAN messages queued 1647766, send timeouts 0, received 878541, lost 0, free buffers 37, min 34, error reg 110000
          dup 0, oos 0/0/0/1, bm 0, wbm 0, rxMotionDelay 1023, adv 27487/74646
          I2C bus errors 0, naks 3, other errors 0
          The job file that breaks RRF.
          br7408undefined 1 Reply Last reply Reply Quote 0
          • br7408undefined
            br7408 @Exerqtor
            @Exerqtor This sounds similar to an issue I'm having in 3.45. My extruder (on a 1LC board) will just stop extruding randomly, but I am only seeing it happen at the very beginning of a print. It is almost like the stepper amperage drops so significantly that it cannot push filament. If I power down and and restart the printer, it works again.
            • Exerqtorundefined
              Exerqtor @br7408
              @br7408
              I didn't have any issues on 3.4.5 actually!
              I've continued to try zeroing down on possible reasons for this to happen, the "weirdness" at the end seems to come from not having M0 in the custom end G-code pared up with using M73/remaining time in the slicer(s). After adding back M0 it seems to behave when a print finishes (if the extruder don't act up).
              Other than that, I just finished another single object print without any issues during the print. BUT after the print had finished the printer restarted/crashed all by itself. Here is the debug-log as proof, and some more M122's taken with a "freshly" booted printer after the crash:
              2023-05-28 17:46:47 [warn] Started printing file 0:/gcodes/revo_nozzle_carrier-v2_0.2mm_ABS_0.4n_40m.gcode
              2023-05-28 17:46:47 [debug] File 0:/gcodes/revo_nozzle_carrier-v2_0.2mm_ABS_0.4n_40m.gcode selected for printing
              2023-05-28 17:46:52 [info] M291: - [no title] - Print started, preheating.
              2023-05-28 17:46:53 [info] G10 P0 S150 R150
              2023-05-28 17:46:53 [debug] T:57.6 /150.0 T0:57.6 /150.0 B:110.0 /110.0
              2023-05-28 17:46:54 [debug] T:57.7 /150.0 T0:57.7 /150.0 B:110.0 /110.0
              2023-05-28 17:46:55 [debug] T:59.9 /150.0 T0:59.9 /150.0 B:110.0 /110.0
              2023-05-28 17:46:56 [debug] T:64.9 /150.0 T0:64.9 /150.0 B:110.0 /110.0
              2023-05-28 17:46:57 [debug] T:71.4 /150.0 T0:71.4 /150.0 B:110.0 /110.0
              2023-05-28 17:46:58 [debug] T:78.5 /150.0 T0:78.5 /150.0 B:110.0 /110.0
              2023-05-28 17:46:59 [debug] T:85.5 /150.0 T0:85.5 /150.0 B:110.0 /110.0
              2023-05-28 17:47:00 [debug] T:92.5 /150.0 T0:92.5 /150.0 B:110.0 /110.0
              2023-05-28 17:47:01 [debug] T:99.4 /150.0 T0:99.4 /150.0 B:110.0 /110.0
              2023-05-28 17:47:02 [debug] T:106.2 /150.0 T0:106.2 /150.0 B:110.0 /110.0
              2023-05-28 17:47:03 [debug] T:112.7 /150.0 T0:112.7 /150.0 B:110.0 /110.0
              2023-05-28 17:47:04 [debug] T:119.1 /150.0 T0:119.1 /150.0 B:110.0 /110.0
              2023-05-28 17:47:05 [debug] T:125.2 /150.0 T0:125.2 /150.0 B:110.0 /110.0
              2023-05-28 17:47:06 [debug] T:131.2 /150.0 T0:131.2 /150.0 B:110.0 /110.0
              2023-05-28 17:47:07 [debug] T:136.6 /150.0 T0:136.6 /150.0 B:110.0 /110.0
              2023-05-28 17:47:08 [debug] T:141.1 /150.0 T0:141.1 /150.0 B:110.0 /110.0
              2023-05-28 17:47:09 [debug] T:144.5 /150.0 T0:144.5 /150.0 B:110.0 /110.0
              2023-05-28 17:47:10 [debug] T:147.1 /150.0 T0:147.1 /150.0 B:110.0 /110.0
              2023-05-28 17:47:25 [info] G10 P0 S150.0
              2023-05-28 17:47:26 [info] M291: - [no title] - Pre-print mesh probing enabled, probing new bed mesh!
              2023-05-28 17:47:26 [debug] Default grid: X10.0:340.0, Y10.0:340.0, Number of points: X12 Y12, 144 points
              2023-05-28 17:47:26 [debug] Adaptive grid: X124.564:233.264, Y156.5:196.668, Number of points: X4 Y3, 12 points
              2023-05-28 17:47:28 [info] G10 P0 S150.0
              2023-05-28 17:47:28 [debug] Z probe trigger height set to -1.409 mm
              2023-05-28 17:47:28 [info] M291: - Mesh Probing - Probing now! Please wait...
              2023-05-28 17:47:46 [info] G10 P0 S150.0
              2023-05-28 17:47:46 [warn] 12 points probed, min error -0.022, max error 0.019, mean -0.001, deviation 0.014
              Height map saved to file 0:/sys/heightmap.csv
              2023-05-28 17:47:46 [debug] 12 points probed, min error -0.022, max error 0.019, mean -0.001, deviation 0.014
              2023-05-28 17:47:46 [debug] Height map saved to file 0:/sys/adaptive_heightmap.csv
              2023-05-28 17:47:50 [info] M291: - Mesh Probing - Done
              2023-05-28 17:47:50 [info] G10 P0 S150.0
              2023-05-28 17:47:51 [info] G10 P{global.initial_extruder} R{global.hotend_temp} S{global.hotend_temp}
              2023-05-28 17:47:51 [debug] T:150.0 /255.0 T0:150.0 /255.0 B:110.0 /110.0
              2023-05-28 17:47:52 [debug] T:150.0 /255.0 T0:150.0 /255.0 B:110.0 /110.0
              2023-05-28 17:47:53 [debug] T:151.4 /255.0 T0:151.4 /255.0 B:110.0 /110.0
              2023-05-28 17:47:54 [debug] T:155.0 /255.0 T0:155.0 /255.0 B:110.0 /110.0
              2023-05-28 17:47:55 [debug] T:159.6 /255.0 T0:159.6 /255.0 B:110.0 /110.0
              2023-05-28 17:47:56 [debug] T:165.0 /255.0 T0:165.0 /255.0 B:110.0 /110.0
              2023-05-28 17:47:57 [debug] T:170.5 /255.0 T0:170.5 /255.0 B:110.0 /110.0
              2023-05-28 17:47:58 [debug] T:176.1 /255.0 T0:176.1 /255.0 B:110.0 /110.0
              2023-05-28 17:47:59 [debug] T:181.4 /255.0 T0:181.4 /255.0 B:110.0 /110.0
              2023-05-28 17:48:00 [debug] T:186.9 /255.0 T0:186.9 /255.0 B:110.0 /110.0
              2023-05-28 17:48:01 [debug] T:192.3 /255.0 T0:192.3 /255.0 B:110.0 /110.0
              2023-05-28 17:48:02 [debug] T:197.3 /255.0 T0:197.3 /255.0 B:110.0 /110.0
              2023-05-28 17:48:03 [debug] T:202.5 /255.0 T0:202.5 /255.0 B:110.0 /110.0
              2023-05-28 17:48:04 [debug] T:207.6 /255.0 T0:207.6 /255.0 B:110.0 /110.0
              2023-05-28 17:48:05 [debug] T:212.3 /255.0 T0:212.3 /255.0 B:110.0 /110.0
              2023-05-28 17:48:06 [debug] T:217.3 /255.0 T0:217.3 /255.0 B:110.0 /110.0
              2023-05-28 17:48:07 [debug] T:222.2 /255.0 T0:222.2 /255.0 B:110.0 /110.0
              2023-05-28 17:48:08 [debug] T:227.0 /255.0 T0:227.0 /255.0 B:110.0 /110.0
              2023-05-28 17:48:09 [debug] T:231.9 /255.0 T0:231.9 /255.0 B:110.0 /110.0
              2023-05-28 17:48:10 [debug] T:236.5 /255.0 T0:236.5 /255.0 B:110.0 /110.0
              2023-05-28 17:48:11 [debug] T:240.7 /255.0 T0:240.7 /255.0 B:110.0 /110.0
              2023-05-28 17:48:12 [debug] T:244.9 /255.0 T0:244.9 /255.0 B:110.0 /110.0
              2023-05-28 17:48:13 [debug] T:248.6 /255.0 T0:248.6 /255.0 B:110.0 /110.0
              2023-05-28 17:48:14 [debug] T:251.8 /255.0 T0:251.8 /255.0 B:110.0 /110.0
              2023-05-28 17:48:15 [info] M291: - [no title] - Purge location, X min: 99.564; Y min: 146.5; Purge move speed: 4.802495; Prepurge speed: 4.158004
              2023-05-28 17:48:26 [debug] ABS filament loaded & config applied
              2023-05-28 18:17:42 [debug] {"err":-1}
              2023-05-28 18:27:22 [debug] Done printing file
              2023-05-28 18:27:22 [warn] Finished printing file 0:/gcodes/revo_nozzle_carrier-v2_0.2mm_ABS_0.4n_40m.gcode, print time was 0h 40m
              2023-05-28 18:27:26 [info] G10 P0 R0 S0
              2023-05-28 18:27:26 [debug] ABS filament unloaded & pressure advance disabled
              power up + 00:00:03 [info] Event logging started at level debug
              power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.3+ (2023-05-09 10:59:17)
              power up + 00:00:03 [debug] Done!
              power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running.
              power up + 00:00:04 [warn] WiFi module started
              power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50
              power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 0)
              2023-05-28 19:14:17 [warn] Date and time set at power up + 00:00:08
              M122
              Used output buffers: 8 of 40 (40 max)
              Static ram: 101720
              Dynamic ram: 125120 of which 0 recycled
              Never used RAM 12360, free system stack 186 words
              Tasks: NETWORK(ready,19.0%,219) HEAT(nWait,0.0%,327) Move(nWait,0.0%,358) CanReceiv(nWait,0.0%,772) CanSender(nWait,0.0%,336) CanClock(delaying,0.0%,341) TMC(delaying,1.2%,108) MAIN(running,78.5%,444) IDLE(ready,0.5%,29) AIN(delaying,0.8%,266), total 100.0%
              Owned mutexes: HTTP(MAIN)
              Last reset 02:33:16 ago, cause: software
              Last software reset at 2023-05-28 19:14, reason: HardFault imprec, Gcodes spinning, available RAM 5556, slot 1
              Stack: 2002be78 00000000 200014e8 0000019d 20032c8a 0002f6d1 00034064 810f0000 0002f6bd 00000000 00000000 00000000 2003129c 00000800 2002be60 2002be60 00000001 2002bd05 20018250 2001e438 0002f857 00000000 00000000 00000000 20011c48 00000014 00000000
              Error status: 0x04
              Aux0 errors 0,0,0
              MCU revision 3, ADC conversions started 9196481, completed 9196480, timed out 0, errs 0
              MCU temperature: min 35.7, current 36.3, max 37.1
              Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1052/628, gc cycles 358
              Driver 0: standstill, SG min 2, read errors 0, write errors 0, ifcnt 215, reads 28756, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 215, reads 28756, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Driver 2: standstill, SG min 2, read errors 0, write errors 0, ifcnt 109, reads 28756, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Driver 3: standstill, SG min 2, read errors 0, write errors 0, ifcnt 110, reads 28756, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Driver 4: standstill, SG min 2, read errors 0, write errors 0, ifcnt 109, reads 28757, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Driver 5: standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 28756, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Driver 6: standstill, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 28757, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Date/time: 2023-05-28 21:47:24
              Slowest loop: 79.96ms; fastest: 0.12ms
              === Storage ===
              Free file entries: 18
              SD card longest read time 4.1ms, write time 39.0ms, max retries 0
              DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
              no step interrupt scheduled
              === DDARing 0 ===
              === DDARing 1 ===
              HTTP is ready with "M122 " in state(s) 0
              File is idle in state(s) 0
              Q0 segments left 0, axes/extruders owned 0x0000803
              === CAN ===
              Messages queued 2846, received 6320, lost 0, boc 0
              Longest wait 0ms for reply type 0, peak Tx sync delay 6, free buffers 18 (min 18), ts 1581/1581/0
              === Network ===
              Slowest loop: 19.94ms; fastest: 0.06ms
              = WiFi =
              Module reset reason: Power up, Vcc 3.40, flash size 2097152, free heap 42996
              Signal strength -53dBm, channel 1, mode 802.11n, reconnections 0
              M122 B121
              Never used RAM 4112, free system stack 38 words
              Tasks: Move(nWait,1.5%,93) HEAT(nWait,5.0%,57) CanAsync(nWait,0.0%,48) CanRecv(nWait,0.4%,74) CanClock(nWait,0.2%,67) ACCEL(nWait,0.0%,53) TMC(delaying,31.6%,57) MAIN(running,10.9%,346) IDLE(ready,0.0%,27) AIN(delaying,50.6%,142), total 100.0%
              Last reset 05:17:24 ago, cause: software
              Driver 0: pos 0, 568.8 steps/mm,standstill, SG min 0, read errors 1, write errors 1, ifcnt 46, reads 4821, writes 27, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x01, steps req 0 done 4396932
              Moves scheduled 68488, completed 68488, in progress 0, hiccups 2427, step errors 0, maxPrep 1404, maxOverdue 17166, maxInc 3246, mcErrs 0, gcmErrs 0
              Peak sync jitter -6/10, peak Rx sync delay 333, resyncs 0/1, no timer interrupt scheduled
              VIN voltage: min 23.3, current 24.3, max 24.7
              MCU temperature: min 43.3C, current 43.3C, max 80.6C
              Last sensors broadcast 0x00000012 found 2 181 ticks ago, 0 ordering errs, loop time 1
              CAN messages queued 384593, send timeouts 0, received 245172, lost 0, free buffers 37, min 36, error reg 220000
              dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 535, adv 35598/74648
              • Exerqtorundefined
                Exerqtor @Exerqtor
                I've let the printer sit alone (not homed or anything since it shit the bed and rebooted last time).
                Thought i would check the debug log again now to see if it rebooted more since last time i looked at it, and sure it has. One more time yesterday evening without being touched:
                2023-05-28 21:47:29 [debug] Accelerometer: LIS3DH, status: 00
                power up + 00:00:09 [warn] HTTP client 192.168.10.100 login succeeded (session key 0)
                2023-05-28 22:17:44 [warn] Date and time set at power up + 00:00:09
                And some more M122's i just took:
                M122
                Used output buffers: 14 of 40 (28 max)
                Static ram: 101720
                Dynamic ram: 123656 of which 12 recycled
                Never used RAM 13812, free system stack 180 words
                Tasks: NETWORK(nWait,68.7%,219) HEAT(nWait,0.2%,327) Move(nWait,0.0%,358) CanReceiv(nWait,0.5%,772) CanSender(nWait,0.0%,336) CanClock(delaying,0.1%,341) TMC(nWait,11.7%,108) MAIN(running,6.8%,444) IDLE(ready,3.9%,29) AIN(delaying,8.0%,266), total 100.0%
                Last reset 14:08:27 ago, cause: software
                Last software reset at 2023-05-28 22:17, reason: HardFault imprec, Gcodes spinning, available RAM 12360, slot 2
                Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011bb0 Task NETW Freestk 488 ok
                Stack: 2002be78 20031a60 200014e8 00000000 20032c37 0002f6d1 0002f5e8 610f6000 20035760 2002be60 20018250 2002bd05 20018250 2001e438 0002f857 00000000 00000000 00000000 20011c48 00000014 b5dd9f97 00000002 da360050 640aa8c0 0800019b 00000001 00033f31
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU revision 3, ADC conversions started 50907946, completed 50907946, timed out 0, errs 0
                MCU temperature: min 34.5, current 36.7, max 39.2
                Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/916/532, gc cycles 1906
                Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 229, reads 40442, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 229, reads 40442, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 123, reads 40442, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 124, reads 40442, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 123, reads 40443, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 40445, writes 10, timeouts 0, DMA errors 0, CC errors 0
                Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 40445, writes 10, timeouts 0, DMA errors 0, CC errors 0
                Date/time: 2023-05-29 12:26:02
                Slowest loop: 27.00ms; fastest: 0.12ms
                === Storage ===
                SD card longest read time 4.2ms, write time 2.1ms, max retries 0
                === DDARing 0 ===
                === DDARing 1 ===
                === CAN ===
                Messages queued 458179, received 1018211, lost 0, boc 0
                Longest wait 3ms for reply type 6053, peak Tx sync delay 276, free buffers 18 (min 17), ts 254540/254539/0
                === Network ===
                Slowest loop: 20.34ms; fastest: 0.00ms
                Responder states: MQTT(0) HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                = WiFi =
                Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 36464
                M122 B121
                Tasks: Move(nWait,0.1%,93) HEAT(nWait,22.6%,57) CanAsync(nWait,0.0%,48) CanRecv(nWait,0.5%,74) CanClock(nWait,0.8%,67) ACCEL(nWait,0.0%,53) TMC(nWait,137.2%,57) MAIN(running,205.0%,336) IDLE(ready,0.0%,27) AIN(delaying,219.4%,142), total 585.6%
                Last reset 19:56:02 ago, cause: software
                Driver 0: pos 0, 568.8 steps/mm,standstill, SG min 2, read errors 0, write errors 0, ifcnt 48, reads 13903, writes 2, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 0
                Moves scheduled 68488, completed 68488, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
                Peak sync jitter -5/9, peak Rx sync delay 219, resyncs 0/1, no timer interrupt scheduled
                VIN voltage: min 24.3, current 24.3, max 24.3
                MCU temperature: min 41.8C, current 43.5C, max 80.6C
                Last sensors broadcast 0x00000012 found 2 235 ticks ago, 0 ordering errs, loop time 1
                CAN messages queued 1054423, send timeouts 0, received 474470, lost 0, free buffers 37, min 37, error reg 110000
                dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0
                EDIT 18:08 29/5:
                And the reboots keep happening, the 12:26:06 entry in the log is from the M122 B121 request i posted just above here:
                2023-05-29 12:26:06 [debug] Accelerometer: LIS3DH, status: 00
                2023-05-29 14:56:21 [warn] Date and time set at power up + 00:00:08
                • Exerqtorundefined
                  Exerqtor @Exerqtor
                  I hate to reply to my own thread, but is it any helpfull info contained in the diagnostics posts regarding this issue? Because it sure keeps happening, and lets just say these two issues sure renders any machines useless lol. Hope it's (still) on the radar for an fix or acknowledged as a persisting bug.
                  dc42undefined 2 Replies Last reply Reply Quote 0
                    dc42 administrators @Exerqtor
                    @Exerqtor please post a few more M122 reports for the main board after this issue happens. There does appear to be some commonality but I haven't identified the exact issue yet.
                    The crash happens in the WiFi module interface code. Do you have just a single PC running DWC as wifi client, or are there multiple clients?
                    Are you able to run RRF 3.4.5 to see whether the resets happen with that version?
                    Exerqtorundefined Arminasundefined 2 Replies Last reply Reply Quote 0
                      @Exerqtor PS - please run M122 P500 S1 after reset (you can put this in config.g temporarily). This will reduce performance somewhat, but will provide more accurate reset data in the M122 report.
                      • Exerqtorundefined
                        Exerqtor @dc42
                        @dc42 said in Extruder stops extruding (again) & reboots randomly - RRF 3.5b3+:
                        Ok, good to see it's something happening that's traceable!
                        Uhm DWC is mainly running on one pc/unit at a time. Either i'm at the office while printing, then I use the PC to check in on the printer. If i'm not in the office i use my phone (the pc might or might not be on/in hibernation). So for sake of argument lets say two units at a time?
                        I've deployed to many 3.5 dependant scripts at this point to make that swap tbh 😮‍💨
                        Ok, i added it as the last line in config.g and rebooted the machine before going to bed yesterday, so i'll check after work and report back.
                        • Exerqtorundefined
                          Exerqtor @Exerqtor
                          The printer haven't restartet (yet), but i just tried another print (one object) and it stopped extruding again!
                          Now it stopped on more or less the first print line on the first layer, and started agian in the second layer (then i canceled the print).
                          M122's from when it's not extruding:
                          M122
                          Used output buffers: 4 of 40 (40 max)
                          Static ram: 101720
                          Dynamic ram: 130896 of which 228 recycled
                          Never used RAM 4860, free system stack 134 words
                          Tasks: NETWORK(ready,224.7%,179) HEAT(nWait,0.7%,327) Move(nWait,0.4%,270) CanReceiv(nWait,1.2%,772) CanSender(nWait,0.0%,327) CanClock(delaying,0.2%,341) TMC(nWait,30.8%,74) MAIN(running,62.8%,335) IDLE(ready,10.7%,29) AIN(delaying,21.2%,266), total 352.6%
                          Last reset 16:32:12 ago, cause: software
                          Last software reset at 2023-06-01 00:47, reason: User, Gcodes spinning, available RAM 13792, slot 1
                          Error status: 0x04
                          Aux0 errors 0,0,0
                          MCU revision 3, ADC conversions started 59533190, completed 59533190, timed out 0, errs 0
                          MCU temperature: min 33.9, current 45.6, max 46.0
                          Supply voltage: min 23.1, current 23.5, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                          Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 2048/1260/772, gc cycles 2264
                          Driver 0: ok, SG min 0, read errors 0, write errors 1, ifcnt 39, reads 38057, writes 51, timeouts 0, DMA errors 0, CC errors 0
                          Driver 1: ok, SG min 0, read errors 0, write errors 1, ifcnt 39, reads 38056, writes 51, timeouts 0, DMA errors 0, CC errors 0
                          Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 167, reads 38078, writes 29, timeouts 0, DMA errors 0, CC errors 0
                          Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 168, reads 38078, writes 29, timeouts 0, DMA errors 0, CC errors 0
                          Driver 4: ok, SG min 0, read errors 0, write errors 1, ifcnt 167, reads 38079, writes 29, timeouts 0, DMA errors 0, CC errors 0
                          Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 65, reads 38098, writes 10, timeouts 0, DMA errors 0, CC errors 0
                          Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 65, reads 38097, writes 10, timeouts 0, DMA errors 0, CC errors 0
                          Date/time: 2023-06-01 17:19:31
                          Slowest loop: 239.37ms; fastest: 0.08ms
                          === Storage ===
                          SD card longest read time 9.0ms, write time 62.2ms, max retries 0
                          DMs created 83, segments created 29, maxWait 58897889ms, bed compensation in use: mesh, comp offset 0.000
                          next step interrupt due in 45 ticks, enabled
                          === DDARing 0 ===
                          Scheduled moves 364, completed 358, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                          === DDARing 1 ===
                          File is doing "G1 X181.195 Y162.316 E1.347" in state(s) 0
                          File2 is doing "M0" in state(s) 0, sync state 1
                          === CAN ===
                          Messages queued 538684, received 1190889, lost 0, boc 0
                          Longest wait 3ms for reply type 6053, peak Tx sync delay 275, free buffers 18 (min 14), ts 297665/297664/0
                          === Network ===
                          Slowest loop: 216.97ms; fastest: 0.00ms
                          HTTP sessions: 2 of 8
                          = WiFi =
                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43000
                          Signal strength -50dBm, channel 1, mode 802.11n, reconnections 0
                          M122 B121
                          Never used RAM 4232, free system stack 38 words
                          Tasks: Move(nWait,0.1%,93) HEAT(nWait,13.2%,57) CanAsync(nWait,0.0%,53) CanRecv(nWait,0.3%,74) CanClock(nWait,0.5%,67) ACCEL(nWait,0.0%,53) TMC(nWait,80.4%,57) MAIN(running,128.9%,346) IDLE(ready,0.0%,27) AIN(delaying,128.5%,142), total 351.9%
                          Last reset 16:32:19 ago, cause: software
                          Driver 0: pos 0, 568.8 steps/mm,standstill, SG min 0, read errors 0, write errors 1, ifcnt 67, reads 15903, writes 15, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 229311
                          Moves scheduled 2515, completed 2515, in progress 0, hiccups 133, step errors 0, maxPrep 1012, maxOverdue 4036, maxInc 2308, mcErrs 0, gcmErrs 0
                          Peak sync jitter -4/9, peak Rx sync delay 245, resyncs 0/0, no timer interrupt scheduled
                          MCU temperature: min 40.7C, current 68.1C, max 69.8C
                          Last sensors broadcast 0x00000012 found 2 202 ticks ago, 0 ordering errs, loop time 1
                          CAN messages queued 1191020, send timeouts 0, received 538754, lost 0, free buffers 37, min 36, error reg 110000
                          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 513, adv 35873/74646
                          Debug log (with the M122 info scrubbed:
                          2023-06-01 17:17:13 [warn] Started printing file 0:/gcodes/print_job_0.16mm_ABS_0.4n_1h23m.gcode
                          2023-06-01 17:17:13 [debug] File 0:/gcodes/print_job_0.16mm_ABS_0.4n_1h23m.gcode selected for printing
                          2023-06-01 17:17:16 [info] M291: - [no title] - Print started, preheating.
                          2023-06-01 17:17:17 [info] G10 P0 S150 R150
                          2023-06-01 17:17:17 [debug] T:140.5 /150.0 T0:140.5 /150.0 B:110.2 /110.0
                          2023-06-01 17:17:18 [debug] T:139.9 /150.0 T0:139.9 /150.0 B:110.2 /110.0
                          2023-06-01 17:17:19 [debug] T:140.8 /150.0 T0:140.8 /150.0 B:110.2 /110.0
                          2023-06-01 17:17:20 [debug] T:143.6 /150.0 T0:143.6 /150.0 B:110.1 /110.0
                          2023-06-01 17:17:21 [debug] T:147.3 /150.0 T0:147.3 /150.0 B:110.1 /110.0
                          2023-06-01 17:17:23 [warn] HTTP client 192.168.10.100 login succeeded (session key 0)
                          2023-06-01 17:17:27 [warn] HTTP client 192.168.10.226 login succeeded (session key 0)
                          2023-06-01 17:17:36 [info] G10 P0 S150.0
                          2023-06-01 17:17:36 [info] M291: - [no title] - Pre-print mesh probing enabled, probing new bed mesh!
                          2023-06-01 17:17:36 [debug] Default grid: X10.0:340.0, Y10.0:340.0, Number of points: X12 Y12, 144 points
                          2023-06-01 17:17:36 [debug] Adaptive grid: X160.918:189.082, Y147.261:202.739, Number of points: X3 Y3, 9 points
                          2023-06-01 17:17:38 [info] G10 P0 S150.0
                          2023-06-01 17:17:38 [debug] Z probe trigger height set to -1.361 mm
                          2023-06-01 17:17:39 [info] M291: - Mesh Probing - Probing now! Please wait...
                          2023-06-01 17:17:51 [info] G10 P0 S150.0
                          2023-06-01 17:17:52 [warn] 9 points probed, min error -0.017, max error 0.005, mean -0.007, deviation 0.006
                          2023-06-01 17:17:52 [debug] 9 points probed, min error -0.017, max error 0.005, mean -0.007, deviation 0.006
                          2023-06-01 17:17:52 [debug] Height map saved to file 0:/sys/adaptive_heightmap.csv
                          2023-06-01 17:17:54 [info] M291: - Mesh Probing - Done
                          2023-06-01 17:17:54 [info] G10 P0 S150.0
                          2023-06-01 17:17:55 [info] G10 P{global.initial_extruder} R{global.hotend_temp} S{global.hotend_temp}
                          2023-06-01 17:17:55 [debug] T:150.4 /255.0 T0:150.4 /255.0 B:110.0 /110.0
                          2023-06-01 17:17:56 [debug] T:150.5 /255.0 T0:150.5 /255.0 B:110.0 /110.0
                          2023-06-01 17:17:57 [debug] T:152.6 /255.0 T0:152.6 /255.0 B:110.0 /110.0
                          2023-06-01 17:17:58 [debug] T:156.5 /255.0 T0:156.5 /255.0 B:110.0 /110.0
                          2023-06-01 17:17:59 [debug] T:161.4 /255.0 T0:161.4 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:00 [debug] T:167.0 /255.0 T0:167.0 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:01 [debug] T:172.5 /255.0 T0:172.5 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:02 [debug] T:178.2 /255.0 T0:178.2 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:03 [debug] T:183.6 /255.0 T0:183.6 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:04 [debug] T:189.0 /255.0 T0:189.0 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:05 [debug] T:194.0 /255.0 T0:194.0 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:06 [debug] T:199.3 /255.0 T0:199.3 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:07 [debug] T:204.5 /255.0 T0:204.5 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:08 [debug] T:209.7 /255.0 T0:209.7 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:09 [debug] T:214.3 /255.0 T0:214.3 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:10 [debug] T:219.3 /255.0 T0:219.3 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:11 [debug] T:224.1 /255.0 T0:224.1 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:12 [debug] T:228.9 /255.0 T0:228.9 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:13 [debug] T:233.7 /255.0 T0:233.7 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:14 [debug] T:238.0 /255.0 T0:238.0 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:15 [debug] T:242.3 /255.0 T0:242.3 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:16 [debug] T:246.4 /255.0 T0:246.4 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:17 [debug] T:249.8 /255.0 T0:249.8 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:18 [debug] T:252.4 /255.0 T0:252.4 /255.0 B:110.0 /110.0
                          2023-06-01 17:18:19 [info] M291: - [no title] - Purge location, X min: 135.918; Y min: 137.261; Purge move speed: 4.802495; Prepurge speed: 4.158004
                          2023-06-01 17:18:30 [debug] ABS filament loaded & config applied
                          2023-06-01 17:18:30 [debug] Maximum printing acceleration 5000.0, maximum travel acceleration 7000.0 mm/sec^2
                          2023-06-01 17:22:42 [warn] Resume state saved
                          2023-06-01 17:22:46 [warn] Printing paused at X179.6 Y161.4 Z1.4
                          2023-06-01 17:22:46 [debug] Printing paused at X179.6 Y161.4 Z1.4
                          2023-06-01 17:22:57 [debug] Done printing file
                          2023-06-01 17:22:57 [warn] Cancelled printing file 0:/gcodes/print_job_0.16mm_ABS_0.4n_1h23m.gcode, print time was 0h 5m
                          2023-06-01 17:23:03 [info] G10 P0 R0 S0
                          2023-06-01 17:23:03 [debug] ABS filament unloaded & pressure advance disabled
                            @Exerqtor the issue with extrusion on tool boards stopping (actually reversing) is a known issue in 3.5beta3.
                            • Exerqtorundefined
                              Exerqtor @dc42
                              Yeah i knew it was in 3.5b3, but i thought the patch in b3+ sorted it out 😬
                                @Exerqtor OK, I didn't spot that you were running the patched version. There are still some extrusion issues on tool boards in that version.
                                • Exerqtorundefined
                                  Exerqtor @dc42
                                  Ok, if you have any newer binaries thats supposed to fix said issues i would be more than happy to try them if we put it like that 😆
                                  • Exerqtorundefined
                                    Exerqtor @dc42
                                    Ok so i checked in on the debuglog now and the printer apparently restarted a couple times last evening (just been standing there collecting dust).
                                    2023-06-02 20:55:23 [warn] HTTP client 192.168.10.100 disconnected
                                    2023-06-02 21:19:35 [warn] Date and time set at power up + 00:00:08
                                    2023-06-02 21:24:36 [warn] Date and time set at power up + 00:00:08
                                    2023-06-03 05:24:05 [warn] Date and time set at power up + 00:00:08
                                    Here is the M122:
                                    M122
                                    Used output buffers: 15 of 40 (30 max)
                                    Static ram: 101720
                                    Dynamic ram: 123664 of which 0 recycled
                                    Never used RAM 13816, free system stack 184 words
                                    Tasks: NETWORK(nWait,155.6%,219) HEAT(nWait,0.2%,329) Move(nWait,0.0%,358) CanReceiv(nWait,0.4%,772) CanSender(nWait,0.0%,336) CanClock(delaying,0.1%,341) TMC(nWait,9.8%,108) MAIN(running,107.8%,444) IDLE(ready,3.3%,29) AIN(delaying,6.8%,266), total 284.1%
                                    Last reset 07:13:36 ago, cause: software
                                    Last software reset at 2023-06-03 05:23, reason: HardFault imprec, Gcodes spinning, available RAM 13792, slot 1
                                    Stack: 2002be78 00000000 200014e8 0000019f ffffffff 0002f6d1 00034064 810f0000 0002f6bd 00000000 00000000 00000000 20031a6c 00000800 20035760 2002be60 20018250 2002bd05 20018250 2001e438 0002f857 00000000 00000000 00000000 20011c48 00000014 b5dd9f97
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    MCU revision 3, ADC conversions started 26016866, completed 26016866, timed out 0, errs 0
                                    MCU temperature: min 33.5, current 36.3, max 37.6
                                    Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/468/84, gc cycles 974
                                    Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 83, reads 5830, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 83, reads 5830, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 211, reads 5830, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 212, reads 5830, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 211, reads 5831, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 98, reads 5832, writes 10, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6f
                                    Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 98, reads 5833, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                    Date/time: 2023-06-03 12:37:44
                                    Slowest loop: 22.63ms; fastest: 0.12ms
                                    === Storage ===
                                    === DDARing 0 ===
                                    === DDARing 1 ===
                                    === CAN ===
                                    Messages queued 234159, received 520381, lost 0, boc 0
                                    Longest wait 3ms for reply type 6053, peak Tx sync delay 275, free buffers 18 (min 17), ts 130084/130083/0
                                    === Network ===
                                    Slowest loop: 19.72ms; fastest: 0.00ms
                                    = WiFi =
                                      @Exerqtor thanks. I made a mistake: the command needed in config.g is M122 P500 S0 not S1. Please make that change and send me the next M122 main board report after that. You can check that the setting is correct by sending M122 P500 without the S parameter - it should report "Write buffer is disabled".
                                      Exerqtorundefined 2 Replies Last reply Reply Quote 0
                                      • Exerqtorundefined
                                        Exerqtor @dc42
                                        Aha, cool changed it to S0 now and checked, now it's disabled ✌
                                        • Exerqtorundefined
                                          Exerqtor @dc42
                                          NOW i think "we" got it!
                                          2023-06-03 13:59:24 [debug] Write buffer is disabled
                                          power up + 00:00:07 [warn] HTTP client 192.168.10.100 login succeeded (session key 0)
                                          2023-06-03 15:52:38 [warn] Date and time set at power up + 00:00:07
                                          M122
                                          Used output buffers: 13 of 40 (28 max)
                                          Static ram: 101720
                                          Tasks: NETWORK(nWait,68.6%,217) HEAT(nWait,0.1%,327) Move(nWait,0.0%,358) CanReceiv(nWait,0.2%,772) CanSender(nWait,0.0%,336) CanClock(delaying,0.0%,341) TMC(delaying,4.4%,108) MAIN(running,22.0%,444) IDLE(ready,1.5%,29) AIN(delaying,3.1%,266), total 100.0%
                                          Last reset 02:09:59 ago, cause: software
                                          Last software reset at 2023-06-03 15:52, reason: HardFault bfarValid precise, Platform spinning, available RAM 13816, slot 2
                                          Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x0000001c SP 0x20011b98 Task NETW Freestk 482 ok
                                          Stack: 2002be78 20030218 200014e8 00000000 20032c37 0002f6d1 0002f5e4 610f0000 0002f6bd 00000000 00000000 00000000 20030224 00000800 20035760 2002be60 20018250 2002bd05 20018250 2001e438 0002f857 00000000 00000000 00000000 20011c48 00000014 b5dd9f97
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          MCU revision 3, ADC conversions started 7800185, completed 7800184, timed out 0, errs 0
                                          MCU temperature: min 35.7, current 36.9, max 40.4
                                          Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/1876/1492, gc cycles 291
                                          Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 97, reads 53695, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 97, reads 53695, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 225, reads 53695, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 226, reads 53695, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 225, reads 53695, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 109, reads 53698, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 109, reads 53698, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                          Date/time: 2023-06-03 18:02:30
                                          Slowest loop: 21.27ms; fastest: 0.12ms
                                          === Storage ===
                                          === DDARing 0 ===
                                          === DDARing 1 ===
                                          Daemon is idle in state(s) 0 0, running macro
                                          === CAN ===
                                          Messages queued 70207, received 156041, lost 0, boc 0
                                          Longest wait 3ms for reply type 6053, peak Tx sync delay 275, free buffers 18 (min 17), ts 39000/38999/0
                                          === Network ===
                                          Slowest loop: 20.23ms; fastest: 0.00ms
                                          = WiFi =
                                          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42288
                                            @Exerqtor thanks again. Please try the Mini5+ RRF file at https://www.dropbox.com/sh/in0t2j68ic66oa8/AADv_6WzRy07H6MhBOrkDt23a?dl=0. Leave the M122 command in config.g, and post the main board M122 main board if it resets again.
