    Reboots/resets randomly - RRF 3.5.0-b4
    Beta Firmware
    12
    112
    7.3k
    • Exerqtorundefined
      Exerqtor @dc42
      After a couple days without any resets, it happend again twice yesterday:
      power up + 00:00:03 [info] Event logging started at level debug
      power up + 00:00:03 [info] Running: Duet 3 Mini5plus WiFi: 3.5.0-beta.4 (2023-06-08 23:40:14)
      power up + 00:00:03 [debug] Done!
      power up + 00:00:03 [debug] RepRapFirmware for Duet 3 Mini 5+ is up and running.
      power up + 00:00:04 [warn] WiFi module started
      power up + 00:00:07 [warn] WiFi module is connected to access point RV32-IOT2G, IP address 192.168.10.50
      power up + 00:00:09 [warn] HTTP client 192.168.10.100 login succeeded (session key 1366409378)
      2023-06-16 01:23:20 [warn] Date and time set at power up + 00:00:09
      power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 125510966)
      2023-06-16 10:24:14 [warn] Date and time set at power up + 00:00:08
      m122
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: FAP55-Q967A-G65J0-401GL-0S02Z-RF9TL
      Used output buffers: 1 of 40 (30 max)
      Static ram: 102996
      Dynamic ram: 124208 of which 16 recycled
      Never used RAM 11980, free system stack 180 words
      Tasks: NETWORK(2,nWait,126.9%,219) HEAT(3,nWait,0.5%,327) Move(4,nWait,0.1%,344) CanReceiv(6,nWait,1.1%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.2%,351) TMC(4,delaying,26.0%,108) MAIN(1,running,48.1%,704) IDLE(0,ready,8.9%,29) AIN(4,delaying,18.0%,266), total 229.7%
      Owned mutexes:
      Last reset 26:40:40 ago, cause: software
      Last software reset at 2023-06-16 10:24, reason: HardFault invState, Gcodes spinning, available RAM 10580, slot 1
      Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20011fa8 Task NETW Freestk 482 ok
      Stack: 000001ae 00000002 200014ec 00000000 2003335a 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 20032174 00000800 20035e68 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 b5ddc1d1
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 96040137, completed 96040137, timed out 0, errs 0
      MCU temperature: min 35.1, current 36.3, max 39.4
      Supply voltage: min 23.7, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/28, heap memory allocated/used/recyclable 2048/980/596, gc cycles 3588
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 33, reads 14596, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 33, reads 14596, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 147, reads 14596, writes 13, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 147, reads 14595, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6c
      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 150, reads 14595, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6a
      Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 14597, writes 10, timeouts 2, DMA errors 0, CC errors 0, failedOp 0x6a
      Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 14599, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Date/time: 2023-06-17 13:04:45
      Slowest loop: 22.78ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 18
      SD card longest read time 4.5ms, write time 4.2ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      === DDARing 0 ===
      === DDARing 1 ===
      Heater 1 is on, I-accum = 0.0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is doing "G4 S1        " in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x0000803
      Code queue 0 is empty
      Code queue 1 is empty
      === CAN ===
      Messages queued 864369, received 1920872, lost 0, boc 0
      Longest wait 3ms for reply type 6053, peak Tx sync delay 277, free buffers 18 (min 17), ts 480201/480200/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 22.24ms; fastest: 0.00ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      = WiFi =
      Interface state: active
      Firmware version 2.1beta4
      MAC address bc:ff:4d:e6:b1:62
      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42972
      WiFi IP address 192.168.10.50
      Signal strength -50dBm, channel 1, mode 802.11n, reconnections 0
      Clock register 00002001
        dc42 administrators @Exerqtor
        @Exerqtor that's interesting, it's not the same crash as before but it is the same task (NETW) and probably the same area of code.
        If your machine is not being used, please can you do a couple of things to increase the load on it, in the hope that this will make the problem occur more frequently. In particular, try these:
        • In the DWC Machine Specific config, reduce the polling interval e.g. to 100ms
        • Reduce the lengths of G4 delay commands that you have in daemon.g.
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @dc42
          Guess that's somewhat positive and it would help narrow down the search a little? wishfull thinking
          Ok I've set the "Communication update invervals" to 100ms now (if that's the one you were refering to).
          What do you suggest changing the daemon.g delay to? It's currently 1second, so reduce it to 300ms or something maybe?
            @Exerqtor I suggest you try 100ms. If that makes the response to console commands such as M122 excessively slow, increase it.
            Exerqtorundefined 2 Replies Last reply Reply Quote 0
            • Exerqtorundefined
              Exerqtor @dc42
              Ok, then both have been set to 100ms. Now it's just to wait for a crash i guess πŸ˜…
              • Exerqtorundefined
                Exerqtor @dc42
                Don't look like the added stress we were able to muster up with those changes did much, only had one crash since they were changed:
                power up + 00:00:08 [warn] HTTP client 192.168.10.100 login succeeded (session key 775616360)
                2023-06-18 04:59:53 [warn] Date and time set at power up + 00:00:08
                M122
                Used output buffers: 1 of 40 (38 max)
                Static ram: 102996
                Dynamic ram: 125612 of which 12 recycled
                Never used RAM 10580, free system stack 180 words
                Tasks: NETWORK(1,ready,84.6%,219) HEAT(3,nWait,0.1%,327) Move(4,nWait,0.0%,344) CanReceiv(6,nWait,0.2%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,351) TMC(4,nWait,4.9%,108) MAIN(1,running,150.3%,704) IDLE(0,ready,13.1%,29) AIN(4,delaying,3.4%,266), total 256.8%
                Owned mutexes:
                Last reset 04:11:46 ago, cause: software
                Last software reset at 2023-06-18 04:59, reason: HardFault invState, Gcodes spinning, available RAM 9444, slot 2
                Stack: 000001af 00000002 200014ec 00000000 2003335b 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 2003217c 00000800 20035e70 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 ffffffff
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU revision 3, ADC conversions started 15106363, completed 15106363, timed out 0, errs 0
                MCU temperature: min 35.1, current 35.5, max 41.8
                Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1372/948, gc cycles 4666
                Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 63, reads 62550, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 63, reads 62549, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 166, reads 62549, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 165, reads 62549, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 168, reads 62550, writes 13, timeouts 0, DMA errors 0, CC errors 0
                Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 62553, writes 10, timeouts 0, DMA errors 0, CC errors 0
                Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 54, reads 62552, writes 10, timeouts 0, DMA errors 0, CC errors 0
                Date/time: 2023-06-18 09:11:30
                Slowest loop: 37.72ms; fastest: 0.14ms
                === Storage ===
                SD card longest read time 7.0ms, write time 5.6ms, max retries 0
                === DDARing 0 ===
                === DDARing 1 ===
                Daemon is doing "G4 P100        " in state(s) 0 0, running macro
                === CAN ===
                Messages queued 135965, received 302172, lost 0, boc 0
                Longest wait 3ms for reply type 6053, peak Tx sync delay 306, free buffers 18 (min 17), ts 75532/75531/0
                === Network ===
                Slowest loop: 22.11ms; fastest: 0.00ms
                = WiFi =
                Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42960
                Signal strength -55dBm, channel 1, mode 802.11n, reconnections 0
                • Exerqtorundefined
                  Exerqtor @Exerqtor
                  @dc42 Have you had any more time or luck with this David?
                  Mine havent had any news crashes sunday, and been sitting idle since then since it quite frankly ain't stable enough to be used for any duration of time πŸ˜‚
                    @Exerqtor unfortunately I haven't been able to reproduce it.
                    • Exerqtorundefined
                      Exerqtor @dc42
                      Haven't had any more crashes here either, though the printer has just been sitting idle since last time it happened.
                        @Exerqtor I'm wondering whether it could possibly be a hardware issue, because I haven't been able to reproduce it and nobody else has reported it. Which country are you in and which Duet3D reseller do you use?
                        • Exerqtorundefined
                          Exerqtor @dc42
                          Might be the case, this perticular board ain't a original duet3 board but a Fysetc "Big Dipper" (killed the processor on my Duet 2 so I needed a subsitute board ASAP, and couldn't justify cashing out for a original duet 3 mini & addon board to the mrs πŸ€¦β€β™‚οΈ).
                          It haven't had a single crash since the last one i reportet two weeks ago though. Even with the extra load we added.
                          Just started a 2.3hr print on it now to see if it wil act up again.
                            droftarts administrators
                            @Exerqtor Please be up-front about using clone Duet boards. It would save a lot of time supporting, and trying to resolve issues with, boards who's quality are beyond the scope of what Duet3D can control.
                            Regarding the Fysetc Big Dipper board, when the TeamGloomy devs took a look at it, they weren't that impressed. When looking at the schematics, it doesn't include as much filtering, and some other corners have been cut, compared to the Duet 3D Mini 5+.
                            Exerqtorundefined 1 Reply Last reply Reply Quote 1
                              @Exerqtor as I haven't been able to reproduce it, and nobody else has reported it, and it's a clone board, I'll park this issue unless/until someone else reports a similar issue.
                              The SAME54P20A processor we use in the Duet 3 Mini has been almost impossible to purchase for the last two years, so I wouldn't rule out the possibility that the clone boards use reject/remarked chips.
                              • Exerqtorundefined
                                Exerqtor @droftarts
                                @droftarts It wasn't like I was actively trying to withold any info in that regard. Since it was a non-issue before the specific FW update I didn't even think about it possibly being and HW issue given the circumstances.
                                I'm in no way doubtfull of the original duets being of way superior quality all across the board, but the circumstances simply didn't allow for it when I had to replace the board i killed.
                                @dc42 Yeah I haven't had any more issues myself either (knock on wood) so I have no idea what was happening.
                                And just to be clear, I didn't mean or try to gasslight anyone with not specifying it being a clone board since I assumed it to "simply" being a FW issue introduced to the beta in question.
                                • Exerqtorundefined
                                  Exerqtor @Exerqtor
                                  @Exerqtor
                                  Just checked the printer and saw it had crashed again, about 30min after the job from yesterday was finished.
                                  Heres the M122 in case it might shine some new light on it πŸ€·β€β™‚οΈ
                                  5.7.2023, 18:19:11	M122
                                  Used output buffers: 1 of 40 (28 max)
                                  Static ram: 102996
                                  Tasks: NETWORK(1,ready,1261.8%,211) HEAT(3,nWait,9.0%,327) Move(4,nWait,0.9%,344) CanReceiv(6,nWait,17.5%,672) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,2.8%,351) TMC(4,delaying,423.1%,108) MAIN(1,running,2878.0%,704) IDLE(0,ready,1126.3%,29) AIN(4,delaying,293.3%,266), total 6012.7%
                                  Owned mutexes: WiFi(NETWORK)
                                  Last reset 19:08:33 ago, cause: software
                                  Last software reset at 2023-07-04 23:10, reason: HardFault invState, Gcodes spinning, available RAM 2364, slot 0
                                  Stack: 000001ae 00000002 200014ec 00000000 2003338a 0009d43d 00000000 600f0000 00000000 00000000 00000000 00000000 200321a4 00000800 20035e98 2002c558 20018670 2002c3f5 20018670 2001e920 0002fe6f 00000000 00000000 00000000 20012058 00000014 b5ddc1d1
                                  Error status: 0x00
                                  Aux0 errors 0,0,0
                                  MCU revision 3, ADC conversions started 68913225, completed 68913223, timed out 0, errs 0
                                  MCU temperature: min 34.5, current 35.5, max 41.6
                                  Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/796/372, gc cycles 21269
                                  Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 194, reads 38882, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 194, reads 38882, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 93, reads 38882, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 93, reads 38882, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 92, reads 38882, writes 13, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 5: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 38885, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 6: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 38885, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                  Date/time: 2023-07-05 18:19:11
                                  Slowest loop: 37.47ms; fastest: 0.14ms
                                  === Storage ===
                                  SD card longest read time 4.4ms, write time 3.7ms, max retries 0
                                  === DDARing 0 ===
                                  === DDARing 1 ===
                                  === CAN ===
                                  Messages queued 620226, received 1378327, lost 0, boc 0
                                  Longest wait 3ms for reply type 6053, peak Tx sync delay 273, free buffers 18 (min 17), ts 344566/344565/0
                                  === Network ===
                                  Slowest loop: 22.25ms; fastest: 0.00ms
                                  = WiFi =
                                  Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42780
                                  Signal strength -48dBm, channel 1, mode 802.11n, reconnections 0
                                    @Exerqtor that's a different crash from the previous ones but probably in the same area. Looks like a similar cause: a few stack words have been cleared to zeros during a DMA transfer between the WiFi module and the main processor.
                                    The only thing I can suggest (and it's a long shot) is to try reducing the SPI clock speed of transfers between the WiFi module and the main processor. You can do this by sending:
                                    M589 L{0x3002}
                                    M122 should then display the WiFi clock register as 00003002.
                                    • Exerqtorundefined
                                      Exerqtor @dc42
                                      Interesting 😢
                                      I'll try that later, is guess this something that needs to be done on every boot right (so I'll put it in config.g)?
                                        @Exerqtor it won't work in config.g because the WiFi interface isn't enabled until config.g completes.
                                        • Exerqtorundefined
                                          Exerqtor @dc42
                                          @dc42 noted πŸ™‚
                                            droftarts administrators @Exerqtor
                                            @Exerqtor if it is WiFi related as @dc42 suggests, I note you’re on WiFi firmware 2.2beta4 . Check you have the later version of this, as I think there was an issue with the early release of this. It might also be worth reverting to 1.27, in the RRF 3.4.5 release.
