    Features menu
    Duet Web Control
    507
    • Auréundefined
      Auré
      Hello ! I updated my firmware with the help of jay_s_uk. Now when I use my Android tablet all the DWC features are no longer accessible. Before I could see the menu to control my hotend and now it's impossible. Is it possible to reorganise the windows please?
      Reprap core XY, Ender 3 upgraded.
      If you keep trying, you'll eventually succeed. So: the more you fail, the more likely you are to succeed.
      A quote from Jacques Rouxel
      Auréundefined 1 Reply Last reply Reply Quote 1
      • Auréundefined
        Auré @Auré
        Nobody have a probleme for show the feature menu? I can't use my printer with my tablet.....
          Does your tablet allow you to request the desktop version of the site?
          Auréundefined 1 Reply Last reply Reply Quote 0
          • Auréundefined
            Auré @Phaedrux
            @Phaedrux @Hi! I didn't know about the site version parameters. So I looked around and found a option that allows you to activate "display the computer version".
              what screen size and resolution is the tablet?
              • Auréundefined
                Auré @Phaedrux
                @Phaedrux said in Features menu:
                Screen size 10.1 and resolution 1280*800
                  What DWC version is installed? Which firmware version?
                  • Auréundefined
                    Auré @Phaedrux
                      I assume you're using an SBC. Beta 4 is out now, so you can try updating with sudo apt update and sudo apt upgrade and see if that makes a difference, otherwise it would be a question for @chrishamm on how the mobile view is flowing to that screen size.
                      • Auréundefined
                        Auré @Phaedrux
                        @Phaedrux Yes I use a PI 3B+. I try to update tomorow for get the Beta 4. I have send a message at @chrishamm for this problem. When "display the computer version" is activate I can use the hotend features menu. But the size is a little lower, but it's possible pinch-to-zoom. For information my tablet run with Android 7.
                        • Auréundefined
                          Auré @Auré
                          I have upgrade but the result is the same. So I continue with the computer version display on my tablet.
                          • chrishammundefined
                            chrishamm administrators @Auré
                            @Auré The menu is now at the bottom provided that's what you mean by "Features". You can switch back to the traditional menu by going to Settings -> General and disable "Show bottom navigation" there.
                            Duet software engineer
                            • Auréundefined
                              Auré @chrishamm
                                @Auré It is available but not on all pages. It's been moved to a separate "Status" page in recent DWC versions.
                                • Auréundefined
                                  Auré @chrishamm
                                  @chrishamm Hi thanks you for your answer. Ok I see now. I don't understand why this menu been moved on mobile version, It's not possible to control all the axis, the hotend and the bed on the same page.
