    steps of my x-axis are not correct
    Using Duet Controllers
    • axiomundefined
      axiom
      I have the suspicion that the steps of my x-axis are not correct. In the y-direction, radii print quite usefully, in the x-direction they become oval. I have already varied the belt tension and found no changes. Are the steps of the x-axis adjusted in the same way as with the extruder...so can I also use the E-Step Calculator or do I have to proceed differently?
      o_lampeundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
      • o_lampeundefined
        o_lampe @axiom
        @axiom I would start with the calculated value based on motor steps/turn , microsteps and pulley teeth.
        Depending on the type of printer (Delta or CoreXY) you also have to know some parameters for the kinematic model.
          xy_steps_per_mm = (motor_steps_per_rev ∗ driver_microstep) / (belt_pitch ∗ pulley_number_of_teeth)
          • deckingmanundefined
            deckingman @axiom
            @axiom said in steps of my x-axis are not correct:
            ,...............Are the steps of the x-axis adjusted in the same way as with the extruder..........
            No. Extruders are different because there are variables such as how far the teeth that grip the filament bight into it. With belts and pulleys, no such variables normally exist, so the calculated value based on known dimensions should be correct.
