M579 issue - no motor movement
Hello there! Im trying to calibrate my CoreXY printer. The printer itself works as intended, but the parts beeing printed is not the correct scale.
From some searching I came over the "M579" command to compensate for this. I added in "M579 X0 Y1.01" in my config.g file, but adding this prevents the steppers from moving. Adding a little video of the issue: https://streamable.com/ebgf3
If I uncomment this command everything works fine again. Any idea what causes this, and how I could fix it?
Try changing X0 to X1.0 in that command.
Can't belive I missed that after calculating the values and reading the wiki o.o
Thanks!
