    cube pro conversion, issues getting running
    • Dradleundefined
      Dradle
      bought a cube pro duo that seemed to be somebody's project. it was fitted with a dyze design extruder and hotend and came with two duet boards and listed as "just needs put together" ...... so here we are. the board that was in it when i got it was a duet 2 wifi clone that i thought was having issues when i got everything wired i go to home the all the home buttons control 1 axis and it was ignoring the endstop signal and would just crash the machine. it seems like the code that the steppers are receiving from the duet board just dont seem to match at all what is being commanded.
      then i bought a brand new duet 2 wifi from matter hackers and i get it all wired up, and set up with the setup tool and im running into very similar issues. ill run the home x file for instance and what happens is the z axis moves up 10mm or so, y carriage rapid moves 5mm over then the z goes back down to original position. then ill click home y file and the same exact moves will happen.. home z differs only in the fact that it has a 20mm movement up with no retraction at all. new board came with 3.1 installed which i couldn't get working so i update to the new 3.4 and still having the same issues. i'm confused and need a different set of eyes on this problem
      i can after the axis thinks its homed can control manually by typing in gcode at the top of the dashboard and that does exactly as commanded
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Mon Jun 12 2023 18:37:32 GMT-0500 (Central Daylight Time)
      M550 P"plastibot"                                  ; set printer name
      M551 P"7852492036"                                 ; set password
      M569 P0 S1                                         ; physical drive 0 goes forwards
      M569 P1 S1                                         ; physical drive 1 goes forwards
      M569 P2 S1                                         ; physical drive 2 goes forwards
      M569 P3 S1                                         ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                   ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E420.00                  ; set steps per mm
      M566 X900.00 Y900.00 Z60.00 E120.00                ; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00            ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z20.00 E250.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                       ; set motor currents (mA) and motor idle factor in per cent
      M208 X230 Y210 Z200 S0                             ; set axis maxima
      M574 X1 S1 P"xstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop"                                ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop"                                ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
      M558 P0 H5 F120 T6000                              ; disable Z probe but set dive height, probe speed and travel speed
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138     ; configure sensor 0 as thermistor on pin bedtemp
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin e0temp
      M143 H1 S480                                       ; set temperature limit for heater 1 to 480C
      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                     ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
      M563 P1 D0 H1 F0                                   ; define tool 1
      G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
      G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
      ; homex.g
      ; called to home the X axis
      G91               ; relative positioning
      G1 H2 Z5 F6000    ; lift Z relative to current position
      G1 H1 X-235 F1800 ; move quickly to X axis endstop and stop there (first pass)
      G1 H2 X5 F6000    ; go back a few mm
      G1 H1 X-235 F360  ; move slowly to X axis endstop once more (second pass)
      G1 H2 Z-5 F6000   ; lower Z again
      G90               ; absolute positioning
      m98 p"config.g"
      HTTP is enabled on port 80
      FTP is disabled
      TELNET is disabled
      ok
      this is all the info i get back on this with m98. i see others on here getting back the whole config.g file. could this be part of my issue??
      Dradleundefined 1 Reply Last reply Reply Quote 0
      • Dradleundefined
        Dradle @Dradle
        I also clearly misunderstood how to add the files in the little scroll box
          droftarts administrators @Dradle
          @Dradle I tidied it up for you!
          Check the endstop function. It may be that the endstops think they are triggered already. See https://docs.duet3d.com/en/How_to_guides/Commissioning#h-8-check-endstops
          It may help to draw a diagram of how the machine is arranged, with the direction the axes move for positive and negative inputs, and the position of the endstops. You currently have all the endstops set at the minimum end of the axes; for X this is the left side of the machine, for Y the nozzle is over the front of the bed, and for Z it is where the nozzle is touching the bed.
          • Dradleundefined
            Dradle @droftarts
            @droftarts wow! Simple fix I guess I just assumed since the light was coming on the board they were working. Got all the axis aligned right and switched the end stops with the ! In the config.g
            The other board must be fine good thing I have another printer laying around to use it on so it's not a waste
            Sure appreciate the help!
            • dc42undefined dc42 marked this topic as a question
