Increase Bed Mesh Size for SBC users
I would like the bed mesh size to be increased to 100 x 100 (10K points) for SBC users.
As far as I know we are limited to 441 points because of the memory limitations of the MCU.
@Hernicz, while I often wished for a larger mesh (although I run standalone), it takes me a solid two hours to do a 441 point mesh probe. With a 100100 mesh grid, that would be a 44 hour mesh probe run and I can pretty much guarantee a power failure, power spike or an inconsistent probe reading after 43 hours
Note that I am not saying that your suggestion is wrong, just that 10000 points seems a bit excessive. I don't think I would ever try and run a mesh bed probe larger than maybe 3030 or 900 points. But hey, that's just me ....
BTW, it takes 2 hours because my BLTouch is somewhat inconsistent so I am set up for multiple probes per location (up to 10) to make sure I get two successive readings that are close to each other. -
@Hernicz Mesh levelling is part of the planner, so we need the mesh in local memory. It would be cool to look-ahead and constantly swap the next relevant mesh points between SBC and Duet, but that's a risky idea.
I think preparations has to be made for faster probing methods.
BEACON - 2000mm/s bed probingI modified the firmware, just about to do a test print to check if I actually able to print anything with a mesh like this.
Took 1 hour 10 min at low (0.01 mm) precision with a BLTouch in fast mode. Fast BLTouch Probing
Absolutely insane! Alas, I am using a glass bed and RRF so no joy for me
@jens55 This is RRF, but I modified the source code and compiled a firmware .bin file.
@o_lampe Can the planner run on the SBC?
@Hernicz said in Increase Bed Mesh Size for SBC users:
That's already done in RRF 3.5.0-beta.4. We'll likely increase the maximum supported number of mesh probe points on Duet 3 boards too.
However, I question whether there is any need for as many as 10000 probe points even if you can scan them quickly.
@dc42 That's good to hear
I don't know what the future might bring, but I'm certain we will not need more than 10000 probe points for a while.
Also 10K is nice round number
Such a high count of probe points is almost begging for a 3D-scanner like setup. With cameras and flashlights you can produce a cloud of millions of probe points in no time...then filter out the polygone-planes that are equal to the neighbours to compress the file.
Some smartphones can do that too. Maybe add a phone gimbal to the printer and let the smartphone scan the bed... -
undefined yoshimitsuspeed referenced this topic
