    Driver problem
    • Amagatthundefined
      Amagatth
      Hi all,
      I have a problem of our printer i'm configuring a 1m/1m/1m with duet 6Hc + 3 Hc expension board.
      I put 3.4.3 / 3.4.5 and same result when i try to make a movement the dwc tell me driver 0.0 phase a short to vin
      I try to change motor to check all wiring all its ok i try an other 6hc same result
      I try to just drive Y with driver 0.1 and nothing wiring to driver 0.0 and when i moove Y ( driver 0.1) he tell me the same message
      Anyone know a solution ???
      m122
      RepRapFirmware for Duet 3 MB6HC version 3.4.3 (2022-10-05 09:06:36) running on Duet 3 MB6HC v1.01 (standalone mode)
      Board ID: 08DJM-9P63L-DJ3T8-6J1F8-3SN6N-TV7VA
      Used output buffers: 1 of 40 (19 max)
      Static ram: 152816
      Dynamic ram: 97580 of which 0 recycled
      Never used RAM 100276, free system stack 190 words
      Tasks: NETWORK(ready,29.8%,250) ETHERNET(notifyWait,0.2%,401) HEAT(notifyWait,0.0%,348) Move(notifyWait,0.0%,351) CanReceiv(notifyWait,0.1%,555) CanSender(notifyWait,0.0%,335) CanClock(delaying,0.0%,340) TMC(notifyWait,8.3%,91) MAIN(running,61.5%,1101) IDLE(ready,0.1%,30), total 100.0%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:02:12 ago, cause: software
      Last software reset at 2023-06-21 09:08, reason: User, GCodes spinning, available RAM 100316, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x00
      Step timer max interval 563
      MCU temperature: min 30.7, current 31.4, max 31.7
      Supply voltage: min 24.9, current 24.9, max 25.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
      Events: 2 queued, 2 completed
      Driver 0: standstill, SG min 0, mspos 946, reads 14299, writes 16 timeouts 0
      Driver 1: standstill, SG min 0, mspos 478, reads 14299, writes 16 timeouts 0
      Driver 2: standstill, SG min 0, mspos 8, reads 14301, writes 14 timeouts 0
      Driver 3: standstill, SG min 0, mspos 8, reads 14302, writes 14 timeouts 0
      Driver 4: standstill, SG min 0, mspos 8, reads 14302, writes 14 timeouts 0
      Driver 5: standstill, SG min 0, mspos 8, reads 14302, writes 14 timeouts 0
      Date/time: 2023-06-21 09:11:11
      Slowest loop: 21.06ms; fastest: 0.06ms
      === Storage ===
      Free file entries: 10
      SD card 0 detected, interface speed: 25.0MBytes/sec
      SD card longest read time 0.8ms, write time 1.2ms, max retries 0
      DMs created 125, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      HTTP is ready with "m122 " in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty
      === Filament sensors ===
      Extruder 0 sensor: no filament
      === CAN ===
      Messages queued 3564, received 1262, lost 0, boc 0
      Longest wait 2ms for reply type 6024, peak Tx sync delay 44581, free buffers 50 (min 49), ts 663/649/0
      Tx timeouts 0,0,13,0,0,7 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 5.58ms; fastest: 0.03ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions Telnet(0), 0 sessions
      HTTP sessions: 2 of 8
      = Ethernet =
      State: active
      Error counts: 0 0 13 1 0 0
      Socket states: 5 2 2 2 2 0 0 0
      === Multicast handler ===
      Responder is inactive, messages processed 0
      21/06/2023 09:09:52 m122 b1
      Diagnostics for board 1:
      Duet EXP3HC rev 1.01 or earlier firmware version 3.4.3 (2022-10-05 09:17:58)
      Bootloader ID: SAME5x bootloader version 2.4 (2021-12-10)
      All averaging filters OK
      Never used RAM 158932, free system stack 200 words
      Tasks: Move(notifyWait,0.0%,160) HEAT(notifyWait,0.0%,108) CanAsync(notifyWait,0.0%,69) CanRecv(notifyWait,0.0%,82) CanClock(notifyWait,0.0%,71) TMC(notifyWait,7.5%,99) MAIN(running,91.2%,441) IDLE(ready,0.0%,40) AIN(delaying,1.3%,263), total 100.0%
      Last reset 00:00:02 ago, cause: software
      Last software reset data not available
      Driver 0: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 11256, writes 11 timeouts 0, steps req 0 done 0
      Driver 1: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 11257, writes 11 timeouts 0, steps req 0 done 0
      Driver 2: pos 0, 80.0 steps/mm,standstill, SG min 0, mspos 8, reads 11258, writes 11 timeouts 0, steps req 0 done 0
      Moves scheduled 0, completed 0, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0
      Peak sync jitter 2/5, peak Rx sync delay 174, resyncs 0/0, no step interrupt scheduled
      VIN voltage: min 25.1, current 25.1, max 25.1
      V12 voltage: min 12.3, current 12.3, max 12.3
      MCU temperature: min 27.4C, current 27.4C, max 27.4C
      Last sensors broadcast 0x00000000 found 0 199 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 46, send timeouts 0, received 38, lost 0, free buffers 37, min 37, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 0config.g
        jay_s_uk @Amagatth
        @Amagatth what motors do you have (provide a datasheet)? how are they wired?
        What commands are you sending to try and move the motors?
        Amagatthundefined 1 Reply Last reply Reply Quote 0
        • Amagatthundefined
          Amagatth @jay_s_uk
          @jay_s_uk
          https://www.soprolec.com/shop/fr/moteurs-pas-a-pas/244-pas-a-pas-nema-23-23nm-57cm23-4a-o-16.html
          the motor
          and for the connector green a2 black a1 blue b2 red B1
          i already wiring this motor on my other customer printer, its just on this configuration who have this problem
          To moove i put m564 h0 s0 to moove without homing and try to moove with Y+ / Y - of dwc controler
          • Amagatthundefined
            Amagatth @Amagatth
            @Amagatth and i have an other problem, duet 3 hc dont drive motor too,
            I find solution for the 6hc Motor , the motor i swap with an other and its ok
