Unsolved Panel due
Hi all ,
I build an 1mX1MX1M and i have a 3 6h + 3hc + panel due firmware 3.4.5 and panel due 3.50 RC6 v3.0 i make the wiring fine TXx on in Rx on out 5V + GND on io 0 and i put M375 P1 S1 on Config but the panel due stay on connecting state , anyone have a solution plz ?
@Amagatth M375 is incorrect. It should M575 https://docs.duet3d.com/User_manual/Reference/Gcodes#m575-set-serial-comms-parameters
@Amagatth Ideally should be
M575 P1 S1 B57600
in config.g. See https://docs.duet3d.com/User_manual/Connecting_hardware/Display_PanelDue#firmware-configurationIan
@jay_s_uk my misstake sorry i already put m575 sorry config (1).g
@Amagatth ideally it should come at the end of the config.
could you post a photo of your wiring showing both ends -
@jay_s_uk i send it tuesday i try 2 câble length and and try to Switch TX and rx
@Amagatth photo of cable, connect it on io_0 on board and i already try to switch Tx and RX on the board side ![text alternatif]
@Amagatth its a fysetc screen for information
This post is deleted! -
I try to update 6hc 3hc and screen with version 3.5.0 same on the panel due with 3.5.0 rc3 nothing change always stuck on connecting ...
