    12864 display Menu system
    • buttonundefined
      button
      Hi guys.
      Finaly have some time to fix some things in my Voron v0.1.
      I have 12864 display connected to Duet3Mini.
      I'm using Ultimate Duet Menu System and wanted to change some behaviors but discovered that is duet limitation, not menu system:
      ; Bed Temp
      image R14 C25 L"imgs/bed.img"
      alter R14 C40 N180 W20 H2
      text T" / "
      value N80 W20
      text T"°C"
      ; Hotend Temp
      image R26 C25 L"imgs/temp.img"
      alter C40 N100 W20 H2
      text T" / "
      value N0 W20
      text T"°C"
      When setting up bed heater active temp, bed getting active (from standby) When setting temp to 0 in web interface is showing -272 (and somehow i can set temp to -xxx value).
      When setting nozzle/tool active temperature tool not getting active (i must add extra button to make this took active). When i set temp to 0, took getting OFF. Why?
      Is there an option to:
      • use conditional Gcode in menu files?
      • adding extra behaviors to "alter" component? (If temp is lower then eg 20 put tool to standby, not off)
        dc42 administrators @button
        @button said in 12864 display Menu system:
        Yes, in RRF 3.5beta4. See the description of the N and V parameters at https://docs.duet3d.com/en/User_manual/Connecting_hardware/Display_12864_menu#menu-files.
        No.
