    Driver 0 warning: over temperature warning"
    Using Duet Controllers
    • axiomundefined
      axiom
      although temperatures etc. look quite good when printing, I get the message: "Warning: Driver 0 warning: over temperature warning"
      what could be the cause and what can i do about it?
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun May 28 2023 15:23:44 GMT+0200 (Mitteleuropäische Sommerzeit)
      M550 P"DUKA1300" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S1 ; enable FTP
      M586 P2 S1 ; enable Telnet
      ;M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
      M92 X80.09 Y80.00 Z640 E322.58 ; set steps per mm
      ;M92 X80.00 Y80.00 Z640.00 E322.58 ; set steps per mm
      ;M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M566 X900.00 Y900.00 Z100.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      ;M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
      M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
      ;M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2)
      M201 X500.00 Y500.00 Z40.00 E250.00 ; set accelerations (mm/s^2)
      M906 X2500 Y2100 Z1800 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X750 Y650 Z1255 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      ;M574 Z2 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin zstop
      ;M574 Z2 S2 ; configure Z-probe endstop for high end on Z
      ;M558 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      ;G31 P1000 X-1 Y-61 Z2 ; set Z probe trigger value, offset and trigger height
      ;M557 X0:740 Y-27:611 S30 ; define mesh grid
      ; Z-Probe two of them
      M558 K0 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
      M558 K1 P8 A2 S0.2 C"!zstop" H5 F80 T3000
      G31 P1000 K0 X-1 Y-61 Z0.5; set Z probe trigger value, offset and trigger height
      G31 P1000 K1 X0 Y0 Z12.664 ; Second Z-offset
      M557 X0:740 Y-27:585 S35 ; define mesh grid
      ; Bed
      ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit
      M307 H2 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
      M143 H0 S280 ; set temperature limit for heater 0 to 120C
      ;Hotend
      ;M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M307 H1 R1.797 K0.742:0.000 D7.57 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S400 ; set temperature limit for heater 1 to 400C
      ;M950 F1 C"fan1" Q700 ; create fan 1 on pin fan1 and set its frequency
      ;M106 P1 S1 H1 T60 ; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q350 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1 T60 ; set fan 2 value. Thermostatic control is turned on
      ;M563 P1 S"Druckkopf 1" H1 F0 ; define tool 1
      M563 P0 D0 H1 F0 ; define tool 1
      G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets
      G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
      ; Filamentsensor
      M591 D0 P1 C"e1-stop" S1 ;R40:120 E3.0 S1 Filament Sensor
      ;Auto Z-Offset
      ;M42 P3 C"e0-stop" S1
      ;M574 Z1 S2
      ;M558 C"e0-stop" S0
      M501
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @axiom
        @axiom That usually means the driver is detecting it's over 100 degrees. Look at adding some cooling to blow across the underside of the board
        axiomundefined 1 Reply Last reply Reply Quote 0
        • axiomundefined
          axiom @jay_s_uk
          @jay_s_uk Thanks, but if you look at the screenshot you can see that the MCU temperature is at 33.1 degrees...is there any other source?
          jay_s_ukundefined deckingmanundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @axiom
            @axiom The MCU is different to the driver.
            • deckingmanundefined
              deckingman @axiom
              @axiom Driver chips don't report their internal temperatures - just a digital high if it's too high. What I did on one of my machines was to fix a bead thermistor to some of the drivers with a small dab of epoxy and use these to control fans blowing cold air onto the back of the board.
                dc42 administrators @axiom
                @axiom said in Driver 0 warning: over temperature warning":
                You are running driver 0 at 2.5A which is the maximum supported on your Duet 2. When running drivers at or near maximum current, fan cooling is required. Preferably, use a fan at the edge of the board, next to the VIN connector, to blow air across both sides of the board along the line of stepper drivers. See https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/Duet_2_WiFi_Ethernet_Hardware_Overview#cooling.
                Electriceyeundefined 1 Reply Last reply Reply Quote 0
                • Electriceyeundefined
                  Electriceye @dc42
                  I just ran into the same thing... 2 of my drivers were complaining about over heating...yikes!
                  This is on a Duet 3 Mini 5 with 6 active stepper motors.
                  So, I'm off to print a backing plate with taller stand-offs and a mount for a blower fan. My stepper motors are all fairly cool, but the amperage draw makes sense. My FLIR ONE camera came in handy yet, again! ; )
                  • Cheers!
