    installed duet magnetic filament monitor and lost web control
    Filament Monitor
    • patterson6undefined
      patterson6
      Installed duet magnetic filament monitor v1.7 I had laying around and hooked it up to io_4. on a duet 3 mainboard 6hc. Pretty sure I had the wires hooked up in the correct pins. When I gave power to my printer the led would flash red and green on the filament monitor. I then put
      M591 D0 P3 C"io4.in+io4.out" R40:120 E3.0 S1; in config.g
      It asked if I wanted to reset the board and I said yes. Then I lost communication to the board via browser. I had to plug in the board with usb connected to yats and I can then get on web control but when I look at my config.g file its empty. My macros and jobs are still present. What happened? I have a backup config.g I could copy and past but wanted to ask first. Ip is still the same also when I looked on yats.
        jay_s_uk @patterson6
        @patterson6 What firmware version are you using?
        patterson6undefined 1 Reply Last reply Reply Quote 0
          patterson6 @jay_s_uk
          @jay_s_uk 3.4.4
