Solved Duet 3 mini 5+ fan MOSFET blown out?
I have been cleaning a nozzle with a wire brush and I accidentally touched the nozzle heater wires and saw a little spark. After that, my hotend fan randomly stops spinning for a couple of seconds during the print. Is it possible that after that incident, my hotend fan MOSFET is blown?
@Arminas highly unlikely. When a MOSFET blows it tends to be fatal and often involves a crater in the surface of the MOSFET package. Sometimes you even get to see the life force (smoke) leave it's little body
@jens55 okay. Everything else seems to work fine. But maybe you have any options why does the hotend fan keeps stopping for a few secs?
This post is deleted! -
@jens55 I have tried to swap the hotend fan and blower fan slots, nothing has changed. But can it be a broken fan if it spins while the hotend is hot (but not printing) and sometimes turns off during the printing process?
@Arminas The two things that I would suspect are intermittent power connection (bad crimp ?) or, more likely, the end of the fan's useful life. I have been able to extend the life of a fan by pulling the sticker that covers the shaft bushing and adding a drop of sewing machine oil. This is mostly an issue with sleeve bearings rather than ball bearings and especially if the fan came from China.
@jens55 it's the default ratrig hotend fan. Ok, I will try to change it
@Arminas, fans are cheap and yes, changing the fan would be right up there in terms of trying to figure out what is going on. BTW, I have given up on sleeve bearings. Any new fans ordered are ball bearing fans. They just seem to be more reliable (for me anyway)
@Arminas said in Duet 3 mini 5+ fan MOSFET blown out?:
Magnetic fields can also affect fans. Is it by any chance a delta printer using magnetic joints?
@dc42 no, it's corexy. Looks like the wire was damaged inside the shield, it was not visible. Problem solved
