    Flashing Panel Due firmware over DWC
    PanelDue
    • that guy Eundefined
      that guy E
      Looking to flash a panel due display current on 3.4.0 and I'm receiving "Error: Failed to communicate with PanelDue bootloader (no START signal received). Please try again or press the Erase and Reset switches on PanelDue." Has anyone found a solution?
      Everything I've found says I should be able to flash over DWC without physical erase and reset buttons.
        jay_s_uk @that guy E
        @that-guy-E you should be able to when above 1.24 but it doesn't hurt to press the buttons as suggested
        that guy Eundefined 1 Reply Last reply Reply Quote 0
          that guy E @jay_s_uk
          @jay_s_uk
          Unfortunately the buttons aren't accessible without removing the screen. Not the end of the world, but just wanted to see if there was something I was doing wrong.
