    3.5b4 DWC stops responding after canceling a job on 12864
    Beta Firmware
    • pfnundefined
      pfn
      With 3.5b4, both DWC & RRF, if I cancel a print job initiated from DWC using my attached 12864 display, DWC will stop responding. Refreshing DWC in the browser will get it to respond again.
      I have not tested other scenarios as starting a job from 12864 is annoying. I discovered this mostly through initiating a job on DWC (re-start a canceled job) and then aborting it on 12864 as I am inspecting the print startup.
      • chrishammundefined
        chrishamm administrators @pfn
        @pfn What board are you using and are you operating your board in SBC mode? If reloading DWC fixes it, I suspect there is a bug in DWC. In that case, please try to reproduce it and check the JS console for potential errors. If there are any, please share the output here.
        Duet software engineer
        pfnundefined 1 Reply Last reply Reply Quote 0
        • pfnundefined
          pfn @chrishamm
          @chrishamm the setup is not operating in SBC mode. I am using an octopus 429. Next time I encounter this, I will check the js console to see if there is anything interesting of note.
            droftarts administrators @pfn
            @pfn said in 3.5b4 DWC stops responding after canceling a job on 12864:
            This may be one for @jay_s_uk and/or @gloomyandy.
            jay_s_ukundefined pfnundefined 2 Replies Last reply Reply Quote 0
              jay_s_uk @droftarts
              @droftarts not sure it will be as we use the Duet provided DWC files
              • pfnundefined
                pfn @droftarts
                @droftarts my guess is 99% a problem in dwc especially with the changes in multi-stream input behavior handling, but I have not had a chance to repro and see what devtools says
                • pfnundefined pfn referenced this topic
