    Can I use a negative pressure advance value?
    3D Printing General Chat
    555
    • Arminasundefined
      Arminas
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @Arminas
        @Arminas i suppose the question is what are you trying to do and why do you think a negative value is a good idea?
        Arminasundefined 1 Reply Last reply Reply Quote 0
        • Arminasundefined
          Arminas @jay_s_uk
          @jay_s_uk just wondering what are the side limits of the value. Is it, let's say, from 0 to 1 or there are not actual limits?
          jay_s_ukundefined Arminasundefined 2 Replies Last reply Reply Quote 0
            jay_s_uk @Arminas
            @Arminas i don't believe there are any limits.
            A negative value would lead to more material being deposited at corners than normal
            • Arminasundefined
              Arminas @Arminas
              @Arminas So the higher the value = the less material deposited on the direction change? And also the more flexible filament the higher value should be set?
              • deckingmanundefined
                deckingman @Arminas
                @Arminas Suggest you read this to develop your understanding of the mechanisms at play https://docs.duet3d.com/en/User_manual/Tuning/Pressure_advance
                  dc42 administrators @Arminas
                  @Arminas said in Can I use a negative pressure advance value?:
                  No. RRF 3.5 will reject a negative pressure advance constant. RRF 3.4.x might accept it but I suspect that it woold make extrusion go seriously wrong.
                  • Arminasundefined
                    Arminas @dc42
                    @dc42 Okay, thanks. I have an issue with TPU corners, but PA does not help at all no matter I increase or decrease the value.
                    SJIundefined 1 Reply Last reply Reply Quote 0
                    • SJIundefined
                      SJI @Arminas
                      @Arminas
                      I predominantly print tpu.
                      I have my config with no PA, direct drive, 90A tpu. 45mm/s print speed, with retractions
                      What is the shore A?
                      Do you have bulging corners?
                      What's the print speed?
                      What's the extruder?
                      • Arminasundefined
                        Arminas @SJI
                        @SJI Direct drive BMG with e3d v6, 0.4 nozzle. TPU95 HF, 50 mm/s. Yes, I have bulging corners.
                          @Arminas for information, direct drive extruders normally need a very low PA value, normally less than 0.1.
                            deckingman @dc42
                            @dc42 said in Can I use a negative pressure advance value?:
                            I can add a couple of data points to that. For a Bondtech Lgx Ace/Mosquito combination and 0.5mm nozzle, PET-G needs 0.06, ABS and PLA both need 0.04 and TPU-HF95 needs none at all.
