    Store location of stall detection to variable.
    Gcode meta commands
    • berniejundefined
      berniej
      Hi all,
      I am trying to figure out how I can use either sensorless homing or stall detection to measure the length of a single axis.
      Ideally, I trigger a macro that sends one axis away from the home position until it hits the end of its travel - then stores that location in a variable.
      I understand there will be limited accuracy due to the loss of steps, but that is ok for my application.
      Any help or direction would be greatly appreciated!
      • gloomyandyundefined
        gloomyandy @berniej
        @berniej You may be able to use a G1 H4 move for this (along with a stall detection endstop). So the process would be....
        0. Define an axis that is longer than the actual max axis length
        1. Home at one end of the axis
        2. define a stall detect endstop for the far end of the axis to test
        3. Perform a G1 H4 move beyond the length of the axis
        4. After the stall the current position will give the position at which the stall happened
        berniejundefined 1 Reply Last reply Reply Quote 1
        • berniejundefined
          berniej @gloomyandy
          @gloomyandy Thanks for the reply. I will try containing the G1 H4 in a macro with my settings for stall detection. I was not aware of the H parameter in RRF 3+.
